Question about Frigidaire Affinity ATF7000E Front Load Washer
E-20 after washer is filled , how do I fix it?
  • 640 Answers
Check your drainage,,,check for kinked hose ,,check for clogged waste pipe,,last check pump...onthejob
Posted on Feb 01, 2009
My washing machine wont start,its opening and turning on, all the lights are on but it wont run. Can you help me please
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
A broken washer means disaster in most homes which is why we've created this repair guide to help you fix a washer that won't start. While a washing machine ...
What to do when your washer won't fill, start or run - YouTube
? 2:00
https://www.youtube.com/watch?v=Atd5YHbRh7M
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't fill, start or run ... Front Load Washer Won't Drain or Spin Video: Washing Machine Tips from Sears ...
Troubleshooting a Washing Machine That Won't Start ...
www.doityourself.com/.../troubleshooting-a-washing-machine-that-wont...
If your washing machine won't start, begin by looking at the power source. ... mywashing has filled with water,now it wont agitate,it's like it is dead,could this be ...
Jan 14, 2016 | Washing Machines
Outlet has power,circuit breaker is good. Has power to machine, able to see light on circuit board inside machine.
? 2:00
What to do when your washer won't fill, start or run .... In case awashing machine does not start and is ..
Oct 31, 2015 | Washing Machines
Code f 20 what does that mean and how can I fix it.
A possible solution to an f 20 fill error for a whirlpool duet washing machine. Blow out the pressure hose that connects to the pressure switch.
Before doing any of these fixes first ask yourself if you have over loaded the machine. Too many Bulky - heavy items will cause this same message.
How to fix Whirlpool Duet F20 Error:
Whirlpool uses a flow meter that detects the flow of water entering the washer. If this flow meter does not detect the correct amount of water entering the washer it will sound the F20 error code. Often this repair can be made with out calling an appliance repairman and without ordering parts. Start by removing the washer fill hoses; both the cold and the hot water hoses. Check for proper water pressure from the house. To do so, turn the water on and put the hose inside the washer or a bucket.
If water pressure is good, check the water valve inlet screens. Most residential washing machines have inlet screens. The screens prevent minerals from clogging the solenoid. With the hoses removed, you can visually inspect the water inlet screens. If the water valve screens are clear the inlet valve with the screens itself will need to be replaced. To replace the water valve, remove the top of the washing machine. Three screws hold the top down. The screws that hold the top down are on the back of the top panel. Once removed the top will slide back and off. Now remove the wire harness that connects to the valve. One screw holds the valve to the washers cabinet. Removing the screw and sliding the valve over will release the valve from the back panel enabling you to complete your repair.
One last thing to check is the fill hoses. These front load duet washers call for a lot of water quickly. So if you have stainless steel braided flood-safe hoses, they will trip for no reason at all. Replace these flood safe hoses with more traditional hoses.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-sport-error-code-f20-washer-repair-troubleshooting/#sthash.zTyr5Yy1.dpuf
Oct 16, 2014 | Whirlpool duet Washing Machines
F 20 Error code washer won't fill up.
http://www.fixya.com/support/r3608632-f20_error_code
Jun 03, 2010 | Kenmore Elite 45986 Front Load Washer
My GE Washer model # WDSR2080DAWW is overfilling unless I take the hose off the side that controls the load indicator switch and blow air into, once I do that, it will stop filling and work perfectly, how...
I fixed my washer by taking off the hose that controls the load indicator switch and blew air into it and it works like a charm, so please don't charge me 20 dollars cause i fixed it myself, thanks
May 13, 2009 | GE WBSE2090A Top Load Washer
Washer fills to level during the off cycle.
You need a new fill valve
The diaphram in your current one has split and is allowing water to flow past.
You cannot fix them , you have to replace them
Most times it is a 20 minute job to do so
May 11, 2009 | GE WBSE3120B Top Load Washer
Whirlpool washer pours water on right side
The pumps on these washer wear out over time and leak.
While replacing the pump, you should replace the direct drive coupling also. That is part of the torn rubber gasket you are referring to.
This video will show you access to the parts.
Apr 22, 2009 | Whirlpool Washing Machines
Maytag MAH20PD washer does not do the High Spin Cycle
with what you have described the problem should be in the door lock unit. there is a check switch that gets pressed down and sends a signal to the computer board telling it that it is locked. if the switch isn't working then that signal will not be sent and the washer will just turn and never enter spin. replace the switch and this will clear up the problem
Jan 03, 2009 | Maytag MAH20PD Front Load Washer
HE3 front-loading automatic washer
Sounds like the water valve is not turning off 100%. Replace the inlet water valve. (where the hoses connect onto the machine)
Aug 28, 2008 | Washing Machines
Washing machine won't drain
replace the lid switch. that's what i have to do with mine. i researched it a few weeks ago. Simple cheap fix - i think it was about $20
Mar 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Frigidaire Affinity ATF7000E Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
