Question about GE Microwave Ovens
No lights - no action - no work! And waited 30 minutes on the phone waiting for a rep to speak to after calling and getting a very pleasant person who told me I a "carry in appliance and had to call the local repair service. They told me I had to have a GE person come as they were not allowed to fix appliances under warranty! HELP!
  • GE Master
  • 9,098 Answers
If it's less than one year old, it should be fully covered under warranty and the the manufacturer will fix it free.
They may want you to carry it in to the shop, or they may provide in-home service, depending on the terms of your warranty, found in your owner's manual.
GE Customer Service is here and they should be able to give you info on the nearest GE-authorized servicer.
While you're waiting to get that sorted out, you can check to be sure the outlet is fine.
If so, and it's still dead, i
t may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Posted on Dec 02, 2008
When door open light flashes and relays clicking. unplugged and waited reset still does same action
This could be an error code indicating a bad primary door switch, bad cavity thermal protector, or a bad fuse.
It would depend on the brand of oven.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
May 28, 2016 | Microwave Ovens
I have a fault code, NTC open call for service, on my whirlpool microwve WMH1163xvs. What to do?
Whirlpool Customer Phone Number Shortest Wait Best Support
Nov 20, 2014 | Whirlpool Microwave Ovens
Getting an "EE" and it
Check this against your code, but iff EE is flashing you may have an internal electrical fault that needs to be checked out by a repair person.
  1. Frigidaire
  2. GE
  3. Panasonic
  4. Sharp
  5. Whirlpool
Sharp commercial grade microwave codes....
EE Mode Reason Action Required EE 1, EE 2 Magnetron failure
Call for service*
EE 3 Both magnetrons failed Call for service. EE 4 R-23GT, R-24GT and R-25JT only
Voltage too high Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 208V to 230V. If problem is not corrected, call an electrician. EE 5 R-23GT, R-24GT and R-25JT only
Voltage too low Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 230V to 208V. If problem is not corrected, call an electrician. EE 6, EE10, EE16 Thermistors failure Call for service. EE 7 Exhaust air temperature too high
Check that nothing is blocking air intake openings on oven back or that oven exterior is very hot. Correct. Wait a few minutes and try again. If problem persists, call for service.
EE 8 Circuit failure Call for service. EE 9 Maximum time is exceeded
Check page 11 in the Operation Manual. Touch STOP/CLEAR pad, and reprogram correctly.
EE 0 Fan lock error Call for service. EE17 Magnetron temperature too high
Touch STOP/CLEAR pad. Wait a few minutes and try again. If problem persists, call for service.
* EE 1 and EE 2: Can continue to use oven before service; however, check food carefully as additional cooking time will be needed.
Any time the EE is flashing, the servicer should be called. When EE is not flashing, check the reason and correct. Service is not necessary.
Aug 20, 2011 | Microwave Ovens
We have a Mr Coffee 10 cup thermal programmable coffee maker COF FTTX95-1 The clean light is blinking and I can't figure out what else to do. HELP!
When the clean light is blinking it is saying that the tubes are blocked up with mineral deposits. If you waited until the light in blinking then it is going to take some time for a vinegar clean to work.
Just put vinegar where you normally put the water, and let it perk about 1/3 of the water through, and then shut it off for 30 minutes. Then restart and let it perk another 1/3 through. Let set for 30 minutes. Then let it complete the cycle.
Take a look at the output vinegar, if there is a lot of chunks in it, strain it using a coffee filter and then reuse the same vinegar and do it again. Keep repeating until the light is out and the vinegar no longer get the chunks.
Jul 13, 2011 | Microwave Ovens
The microwave shuts off after 10 minutes and takes 30 minutes to come back on. Help!!!
It indicates the magnetron is getting to hot "that heats the food" when that happens the thermal fuse opens to protect the magnetron from over heating and shuts it down and waits until it is cooler before it resets. The other problem could be the fan not working or not properly that blows on the magnetron, it helps keeps the temperature regulated so it can run hard. If it turns out the fan is fine, then the magnetron is slowly breaking down until it becomes unusable, which means it will need to be replaced "pricey" or buy new "probably cheaper"
Jan 20, 2011 | Danby DMW139 Microwave Oven
When pushed, the 30 sec button says 3 minutes. none of the display buttons work.
Have you inadvertently programmed your microwave for "autostart"?
Your model microwave has the ability to be programmed to go on at any given time of the day/night, even when you're not home so that you can have a defrosted and cooked meal waiting for you when you get in.
I know that if you hit the 30 sec button or the minute button when your micro is programmed to autostart it will tell you the time that it's programmed to autostart or the amount of time that's left for it continue cooking.
Have you tried unplugging it for a few minutes?
This should clear it's memory and then all you'll have to do is set the time on the regular clock if you want.
Here's where you can download and read your owners manual for further instructions on how to use the autostart feature and everything else:
http://www.fixya.com/support/p113437-emerson_mw8107wa_1000_watts_microwave/manual-11318
Dec 26, 2009 | Emerson MW8107WA Microwave Oven
Microwave Problem:
It may have overheated. Wait 30 minutes and try again. I suggest contacting the manufacturer for repair or replacement. This unit is essentially new and should not do this.
Sep 08, 2009 | GE Microwave Ovens
Panasonic Microwave Convection Oven Model NN-8501Vstops after one min. of operation-Display goes to all
If you unplug the ac power cord , wait between 30 and 60 seconds and then replug the cord in, push the reset button and then select the time ot cook desired followed by the start button, it seems to work fine for a while (days) and then for some unknown reason it stops after one minute of operation and returns to all eights on the display. A real mystery as to why this is happening and what is really wromg with the unit.
Jul 25, 2008 | Microwave Ovens
Microwave Ovens Logo
41 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
