Question about Kenwood Audio Players & Recorders
I have a KR200HT Receiver that came with a KS200HT speaker package. The KR200HT shows a powered subwoofer but the KS200HT is not powered. I am looking for a diagram to connect the speakers.
The outputs for main R and L are routed through the subwoofer where the crossover network passes the higher bandwidths to the main speakers.
Posted on Mar 02, 2014
2 Suggested Answers
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
My subwoofer will not work with my receiver.
I had a similar problem where the subwoofer was working during calibration but not on TV viewing. Here is what I found:
  • That some listening/surround modes did not support the subwoofer.
  • Some receivers only support subwoofer with digital inputs.
  • Might also want to double check the speaker config and make sure it's has the subwoofer enabled.
  • I assume you're using the sub-pre-out to drive the powered subwoofer.
  • Have your tried a CD or FM radio station to see if you're getting the sub output from these sources?
Jan 08, 2015 | Yamaha RX-A840 AVENTAGE home theater...
Why do I blow fuses?
Hi Pete
Are you blowing fuses in the receiver/amp or speakers? Without knowing what device you're referring to, I would guess that you have a problem with your speakers not having enough power handling capability for the amp that's driving them (which would blow your speaker fuse) OR (if you're blowing receiver/amp fuses) too many speakers wired in parallel showing your receiver/amp far less than the 8 ohms or even 4 ohms impedance that it is rated for. For example, two four-ohm speakers wired in parallel shows a 2-ohm load to the receiver/amp. Not many consumer devices have the capability to load down to 2 ohms.
Hope this helps.
Nov 13, 2014 | Audio Players & Recorders
Need remote control code bell 6131
It is in the owner's manual that was packaged with your receiver.
Sep 01, 2014 | Bose Cinemate Digital Home Theater System...
Why won't my a102 speakers from jamo witch came
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Sep 01, 2014 | Audio Players & Recorders
My a102jamo surround sound speakers and working
Aug 31, 2014 | Audio Players & Recorders
I brourt a jamo sub 200 and five a102speakers but
My model is RX-V665...not sure what the BL stands for... anyway...no sound from the subwoofer. Pull the RCA wire from the back of the receiver and touch it with my finder and you hear a buzz from the...
HI,
first of all select ur sub woofers auto mute (auto power off ) switch to off position.
then connect the mic and calibrate ur system one more time. after calibration select it to on position. u will surely get it work. if need any further assistance feel free to contact through fixya.
ok
Dec 31, 2010 | Yamaha RXV665BL Receiver
Voltage on subwoofers input
Is the subwoofer a self-powered unit? If yes, it would have a minimal voltage showing on a meter. If the input is a line input, it would not have a problem taking in a line output (not speaker - never!) from your receiver. If the only output you have from your reciever is a speaker out, then purchase an L-Pad type speaker to line matching transformer. You can also take one of the input channels coming from the source and Y out a side to the sub pre receiver, but you then you would need to be able to adjust levels on the subwoofer independently from the receiver.
Jul 24, 2009 | Audio Players & Recorders
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
Subwoofer doesn't turn on
I felt supid this morning.
I bought a high end cable for my subwoofer.... and it did not work but a regular RCA Cable did. When I went to put the cable back in the package I saw an arrow pointing one way, I turn the cable and it works great.
Dec 12, 2007 | Kenwood VR-405 Receiver
200 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
