Question about Macromedia Flash MX 2004
I am trying to install my hp 4850 photo scanner which was earlier installed on my Windows XP laptop on my new laptop running Widows Vista Business....The scanner came with a CD which had Windows XP drivers. But with 'plug & play' the scanner is supposed to have installed correctly. But when i try to instal the imaging software from the CD i keep getting an error that 'macromedia projector has stopped working'..and windows will inform me when a solution has been found. This is so frustrating as I can't go beyond this for the last 1 1/2 hours
  • 59 Answers
Hp scanjet4850 won't install on windows 7
This fix below will work for Windows 7 and Windows 8 and 8.1 guaranteed, the original software was for Windows XP only. HP have the necessary drivers and Vuescan is a third party scanner program, that is every bit as good as the OEM software, in fact I think it is better.
(1) Download and Install HP Scanjet 4850 Driver: setup_basic_4800_14-5.exe from
(2) Download and Install Vuescan 64 bit: download from
Sep 19, 2012 | HP Scanjet 4850
Just got a new laptop. Tried to install HP Photosmart C 6280. Installation failed because new laptop has Windows7 and v.9.0.2 uses 2000, xp or Vista. Is there a fix?
Try using the compatability tool that is integrated with Windows 7. Do a right click on the Setup.exe file of Photosmart and select Troubleshoot Compatability. Then select, This program worked with an earlier version of Windows, and then select Windows XP SP2. Run the program and if it works choose the option that tells the system the program installed properly. Hope this helps
Aug 18, 2011 | HP Photosmart C6280 Printer
My cd for Umax Astra 4800/4850 does want to work anymore
Click on one of the links below to download the software.
Run the software after downloading, it is the same software contained on your CD.
UMAX Astra 4800/4850 Scanner
Note:this scanner does not have Vista drivers, but it works fine on XP.
Feb 25, 2009 | Umax Astra 3400 Flatbed Scanner
I have driver cd but USB driver dose not support to window vista
dear windows vista not support this driver .please install widows XP and install usb driver.
Feb 08, 2009 | Acer Scan to Web 3300U Flatbed Scanner
Widows XP
(1) go to - load load the necessary Xp drivers for your unit - burn them to cd - then aquire a replacement hdd - install Xp on that - install the required drivers and walla you have one hdd with vista and another with XP
Jan 21, 2009 | HP Compaq 6720s PC Notebook
Installing HP c3180 on windows vista
Here's the link ro download the Vista driver for your Printer/Scanner:
You should uninstall the XP driver for the Printer and install this instead: HP Photosmart Full Feature Software and Drivers
You should use the uninstaller utility on the HP support page on the link provided, and after installing the new driver.
You can also scan and copy in Vista by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP C3180) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 14, 2009 | HP Photosmart 3180 All-In-One Printer
Need Windows XP Driver's For My Laptop
There are several versions of the Presario C700. Pls try here and select one appropriate ti what you have. Thereafter, clicking on the exact model number would open a new page with drivers for several Operating System, pls select Windows XP. If there are no specific drivers, download and install the HP Software Update.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 17, 2008 | Compaq Presario 700 470024-192 Notebook
Won't recognize scanner when installed
First, make sure your computer has been updated to at least Windows XP Service Pack 1....Service Pack 2 is even better. You can check this by right-clicking on my computer and selecting Properties from the menu. If you're using Service Pack 1 or would be a good idea to run through the Windows Update process a few times.
Try downloading a new Scan Wizard file from this page on the MicroTek web site. When you do the install, it should remove any previous drivers and clean things up.
If this doesn't help, try to find the Windows Scanner and Camera Wizard...usually located under Start>All Programs>Accessories. It may work even if the MicroTek software doesn't.
Good luck...and I hope this is helpful!
Jan 13, 2008 | Microtek SCANMAKER 4850 Flatbed Scanner
Installing widows XP
first, have a WIN XP startup disk...created by (in windows)  inserting floppy and right clicking choosing format and select option "create MSDOS startup disk"
first backup all personal files...then restart and bypass to DOS screen at startup...try using F8 key just after BIOS screen...then select startup to DOS prompt only...then run (from the floppy disc) format c:
now you should have a nearly bare hard drive. repeat above steps and this time choose "startup using CDROM drivers"...then insert CDROM and redirect to that drive letter (d drive?) and run setup.exe.
Oct 30, 2007 | Compaq Presario C552US Notebook PC
Macromedia Flash MX 2004 Logo
109 people viewed this question
Top Macromedia Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
