Back to:
Tags:
Motorola DCT6200 DTV Receiver
No right channel audio when using HDMI connection...
posted by UncleJuno on Jan 27, 2007
I have no right channel audio when using the HDMI connection from Motorola DCT6200 cable box to my Sony HDTV. Have right channel audio on all other inputs on the Sony, including analog cable connection.
How do I tell if the problem is in the Sony HDMI circuits or the Motorola HDMI circuits? (I have no other HDMI source to test with.)
Comment by UncleJuno, posted on May 10, 2007
Comcast came and replaced the box, although the tech seemed pretty clueless about HDMI and HDTV. But it worked. Thanks to all.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 27, 2007
FixYa! (100)
tvtek
Rank:Wiz Wiz
Rating: 83%, 797 votes
Since it is easier to replace, I would go with the cable box first. Sometimes there are software upgrades for the TV's that fix such issues but, almost all HDMI issues are with the cable box not the tv.
Comment by tvtek, posted on Jan 30, 2007
Call Sony as wel to make sure you have the most current version of the installed software on the TV. The usually will send a memory stick or have a technician do the update for you. Cost depends on warranty.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on No right channel audio when using HDMI connection to HDTV:
I don't want to Accept this solution
Can you Help with these TV Receivers and DVRs problems?
I'm trying to set my remote controller for my Motorola DCT...
my son burn a new dvd. when playing this on my toshiba...
My reciever resets every so often when i am scrolling...
using hdmi cable and I turn on the tv first, a Toshiba HD...
just hooked up my dct6200, called my cable provider to...
Loading problems.
Repair Service
Find TV Receiver and. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
