Question about Acer PH110 Multimedia Projector
Acer PD125 incorrect start up
When projector is switched on the picture freezes on the initial "Acer" screen. NO SIGNAL is displayed, no matter what input is plugged in.
No buttonsfunction, except HIDE and POWER, so it is not possible to access the menu pages
4 Suggested Answers
Marrie
  • 563 Answers
SOURCE: 3M MP7740i Projector no input is detected
Hi mrus821
If the signal won't go through you will have to either have your Mainboard Repaired or Replaced.
This is unfortunatelly a common Mainbaord problem , and the above is the only way to get it fixed.
Posted on Apr 23, 2008
SOURCE: toshiba portege m600 cannot connect to projector ACER PD525
you can extend the display to the projector through desktop settings
Posted on Jul 15, 2008
  • 452 Answers
SOURCE: When I plug in the projector to the mains and to
Hi ;
  1. click right botton on your desktop
  2. choose Nvidea control pannel
  3. configure multiple displayer
  4. choose the second displayer projector and apply the change
Posted on Oct 19, 2010
I have an Acer One netbook and tried to connect it to a projector but the normal looking lead from the projector did not seem to fit. The lead has those two wee screws at the side, and no place for them...
The Acer One netbook has a mini-VGA port on its left side. Page 10 of Acer's QuickGuide shows the port as item 3 External display (VGA) port. But unfortunately, the description shown for it is incorrect.
From your description, your projector's lead likely has a mini-VGA connector on the end as pictured. The connector can simply be plugged into the mini-VGA port but there are no holes beside the port for screws so it would just be a friction fit which should be sufficiently secure for most puposes. The connector and port are mini-DB 15 male and female respectively and can only fit one-way. The port has the wide side of the D on top so you would have to turn the pictured connector over to be able to plug it into the port. Windows XP should be able to detect the projector via plug-and-play installing any display drivers if required. Page 8 of Acer's UserGuide describes Hotkey + Display toggle which switches display output between the display screen, external monitor (if connected) and both. Pressing + with the projector plugged in will bring up a window in the middle of the screen allowing the selection of internal display, external display, both, or a 800x600 VGA projector. If the display is on the projector, unplugging the cable should automatically revert display back to the internal screen. For VGA see http://en.wikipedia.org/wiki/VGA_connector splines.jpg
Jan 26, 2011 | Acer Aspire One Netbook 8.9" Notebook
HDMI inputs do not show a picture. They worked but now do not. They display the setup program from the Onkyo AV receiver via HDMI output, but not when the receiver is pushing any other signal via the...
This is likely a problem with the receiver not the projector. If the setup screen from the receiver is displayed through the projector, then the projector is functional. If the actual signal is not displayed, then the receiver is not sending the signal. The setup screen is generated inside the receiver and is injected later in the video path than the input signal. Try a direct connect from the signal source (other side of the receiver) to the projector. Again, if that works, then the problem is the receiver.
Dan
Aug 21, 2010 | Panasonic PT-AX200U Projector
How get a colour wheel for a ACER PD125 projector
Call Encompass Parts Distrubtion 1-800-638-3328
Look on E-Bay if you know part number.
Electronics/Parts- Color Wheels
Feb 22, 2010 | Televison & Video
What settings should I use for acer x1260 to dell d520 laptop? Projector says "no signal" - have changed avg cable - no difference.
The max resolution on the projector is 1024x768. But the problem you're having sounds suspiciously like the laptop not sending out a video signal...you have to *tell* the laptop to send out an image to an external display. On one of the function keys, like F4 or F8, there will be a small TV screen symbol. You have to press and hold "alt" and then press the key with the symbol. The initial setting is obviously for the laptop only. When you press the keys for the first time, you tell the laptop share the picture with an external display (your projector). Press the keys a second time, and the laptop ONLY displays an image from the projector. And, press the combination again, you're back to just the laptop.The DLP projector should have a menu selection for "auto" under the input menu...that is the easiest and most trouble-free setting. Whatever you connect to the projector, it automatically seeks out the signal and connects to it.---Rick
Sep 06, 2009 | Office Equipment & Supplies
Infocus X1 picture freezes and dissapears and then comes on again
your display settings may be off, so change settings to factory reset and you may have to drop the resolution on your computer. you may also have a bad cable, so try a different cable.
Jul 03, 2009 | InFocus X1-RE Projector, Factory...
No signal
Hi and welcome to FixYa,
Initially, the "No Signal" error message indicates just that, it is not receiving anything or that the signal it receives is beyond its capacity. With this in mind, pls check:
  • the cable connection from PC to Projector;
  • that the PC is set to display on a 2nd monitor, TV or Projector depending on the capability of the PC's video card (Twin View or Dual View); or
  • as main monitor;
  • lower down the computer's Screen Resolution and/or Screen refresh rate.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 26, 2008 | Dell 2300MP Multimedia Projector
"no signal " on the screen
After half a day of tinkering around with my new Acer I fixed my problem, which I think is yours also. I connected it to my notebook, it read the signal 'D-Sub' or something like that, and after my notebook finished startup, it reverted to no signal. I tried it with my desktop and it worked just fine. The display will only show up on one output device. It worked fine on my desktop because I was unplugging my monitor in order to hook up the projector. Hooking the projector up to my notebook left the display panel still active and that was where it displayed. In case I'm not making sense, the solution is this: After setting everything up, hit Control+Alt+F1 to switch display from your screen to the projector. To switch back, hit Control+Alt+F3
Oct 15, 2008 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
Projectile motion
Dear Sir,
I have NEC 42vR5 HW Plasma monitor, this plasma goes off with in 1 Minute, pls. give solution
thanks
pramod
Feb 24, 2008 | NEC - 42" Commercial Plasma Screen ****(no...
Acer projector
My Acer PD125projector was working perfectly but has been out of use for 6 months. When I connect it now, I get:- 1. "ACER - Empowering People" screen, then 2. After a short delay the message "The Lamp is approaching the end of its useful life at full power ........." is displayed for a short time, then 3. The initial screen returns, together with a "No Signal" message. After this warm up none of the controls on the actual machine nor the the remote controller, except for the power button, will do anything. What can I do about this?
Dec 06, 2007 | Acer PH110 Multimedia Projector
Acer PH110 Multimedia Projector Logo
113 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
