Double check each connector to be sure it is installed (aligned on pins) properly. Also check wiring diagram for a safety limit thermal switch. If it has one, push to reset it.
the oven lock is controlled by a microswitch. it is not working so you have to go in and manually unlockl it. take top front panel off and look for 2 wires that are going to to lock jump these wire and it will lock
look at a diagram to do this on the web
Hello cfrisz,
I am new to the fixya and I saw that you were looking for a manual. I hope that this information can help you find one if you still are looking.
At this web they have a similar users manual or if you type in model (if there is another number on oven) number maybe they'll have it.
in the contact us section there is a form to fill out and maybe you can get one that way. I'm not sure on response time. Most company's do not mind giving people replacement manuals.
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
