I have a SanDisk Sansa Clip MP Player, and I cannot get my computer to recognize that the devise is plugged in to a USB Port. My battery is completly dead and im trying to recharge but it wont recognize it...Please help.
-   okay...i was really happy when i found this info..but there is one problem. In your first solution you say in the middle to, Pull down the drop down menu underneath the Sync tab by moving yourcursor over the Sync tab and left clicking on the little black arrowunderneath the Sync tab.However, i can't find the little black arrow under the sync tab. There is no black arrow.
-   j_95
Apr 15, 2009
-   j_95
Apr 08, 2009
-   I just bought the Fuze sansa and the Cd will not download into my computer nor when I use the cable my computer does not locate..Help-   Guest
Apr 07, 2009
-   I cant format the music off my Sansa 1 GB -   GT011
Dec 29, 2008
-   I received a ScanDiskSansa Clip MP3 player for Christmas, and now cannot seem allow my computer (PC/Win XP-SP2) to recognize the existence of the player, nor does it appear to fully charge the unit, despite the computer being on, and plugged into the USB 2.0 port for 4+ hours, such that the player only played for approximately 15 to 20 minutes prior to indicating "low battery" and subsequently shutting down. Yes, my computer was on while attempting to charge this unit... -   Synergist01
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced. Download the Sansa Recovery Tool from the Sansa website. Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version). You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer. -Tha Mp3 Doctor
Was this helpful?
Yes
No
Popular Solutions for SanDisk Sansa Clip MP3 Player
Hi. I just charged my sansa using the USB port and it turned on and everything looked normal but...
(More)
Hi. I just charged my sansa using the USB port and it turned on and everything looked normal but when it was charged I unpluged it and now it won't turn on. I tried plugging it back into the computer and it isn't reading on there either. What should I do?
I was trying to go from one feature to another in order to a choose a different artist and the mp3...
(More)
I was trying to go from one feature to another in order to a choose a different artist and the mp3 just locked up on me. It will not do anything; it's straight locked up on a song. I can't even turn it off. What in the world do I do?
When Im using earphone it feel like the sound is far away, like when you dont enter the earphone...
(More)
When Im using earphone it feel like the sound is far away, like when you dont enter the earphone deep enough. I tried several earphones but the the same problem happened again and again. Also tried to shift songs, want help. so, I need your help? Im using Sansa Clip the 2GB ver.
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
