Question about Dyson DCO7 Animal Bagless Upright Cyclonic Vacuum
Dyson dc04 motor runs but has no suction.
Hi, I hope you can help me.
My Dyson dc04 suddenly stopped having suction and makes a high pitched sound, it seems to me that the motor is running disengaged or some O ring slipped. Does that sound reasonable?
I've started to open the engine unit but can't seem to get it open, is there a short explanation or manual on opening the unit, there is something that I'm missing.
Thanks.
    Scholar:
  • 55 Answers
I would make sure it is the motor first by isolating the sounds to just the motor. Take off the dirt cup, both filters, and belt, then run it and see if the sound is still there. If it is, you need a new motor. If it isn't, you need to look for a clog, or bad roller bearing.
To take the motor out first undo the wiring running down the backside of the unit inside of the switch housing. Then take the four screws out that hold the outer motor housing on, and the rest pops apart. Once you get inside, the gaskets make it a really tight fit, so you might have to hit the motor shaft with a rubber mallet to get it out and use penetrating oil on the bottom gasket to get the new motor to slide back in.
I guess there is no easy explanation. Let me know how it goes.
Posted on Dec 01, 2008
The cleaner will not click down to stand up unaided. Any ideas
Hi Lynette, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson DC04. From what you've described, it sounds like the valve carriage needs to be realigned. This is quick and easy to do by following the steps shown in our video guide:
I hope this helps, but if you'd like some further advice from our experts after giving this a try, just call the Dyson Customer Helpline on 0800 298 0298 (UK) or 1800 239 766 (AU).
Jun 03, 2015 | Dyson DC04 Upright Vacuum Cleaner Pre...
I have a Dyson DC04 Zorbster. Sometimes there is very little suction & the motor runs slower than normal. If I give it a little shake or push down on the bin (my wife tends to give it a kick) the motor...
Hi David, it's Jack at Dyson.
The issue you're describing sounds very unusual. If the motor seems to be changing speed in use, this could suggest a fault with the motor. DC04 is one of our very oldest machines, and unfortunately due to its age we're no longer able to support it with servicing or spares. However, it would be worth giving our experts a call so we can help confirm if the motor is the cause of the issue - and we can also discuss other the options available to you.
When you have your machine to hand, please give us a call on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
We'll look forward to speaking to you.
Feb 25, 2015 | Dyson Vacuums
Dyson dc04
Hi there, it's Jack at Dyson.
Like most Dyson vacuums, DC04 is equipped with a thermal cutout, which will shut the vacuum off for protection if it starts to overheat. This could be due to a blockage - the pre-filter may also need a wash. It should automatically reset after it's had at least 2 hours to cool down. You can prevent this from reoccurring following the steps below.
To wash the pre-filter, use cold water without detergent, as shown in the video below. Allow at least 12 hours for both parts of the filter to dry completely before replacing it.
To check the vacuum for blockages, just follow the steps shown in our online Support guide: http://www.dyson.co.uk/support/dc04/dc04-standard/my-machine-is-not-working/machine-won-t-switch-on-or-cuts-out/machine-won-t-switch-on-or-cuts-out/my-machine-cut-out-whilst-i-was-using-it/how-to-wash-filters/machine-not-sucking-picking-up-as-well-as-usual-dc04/wand-suction
If you'd like further advice after giving these checks a try, please give our experts a call directly on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
Jul 29, 2014 | Dyson DC04 HEPA Bagless Upright Cyclonic...
When upright makes high pitched noise - like a release valve is blowing out excess pressure and wont **** through tube
I'm sorry to hear you're having difficulty with your DC14. From what you've described, it sounds as if the relief valve is activating because the wand, hose or U-bend is blocked. This is easy to resolve - please follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=626&product=DC14-ALLFLOORS_US
If you need any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US) so we can help.
Best wishes,
Jack
Dyson Online Customer Support
Jan 13, 2012 | Dyson DC14 All Floors Upright Vacuum...
When running it makes a very loud quite high pitched long clicking sound . What can I do about it as I do not want to continue to use it like this
If the noise is continuous from switching on and slows down to a stop when machine is tured of it has to be some thing on contact with the motor or the brush roller the brush roller is easy to check the motor isnt but is less likly to go wrong
Jul 25, 2010 | Dyson DC04 HEPA Bagless Upright Cyclonic...
Was hoovering when my DC04 made a funny high pitched noise then a whirring noise, this was accompanied by a smell of burning and a puff of smoke! Almost sounds like it might be a clutch slipping, is this...
OK... the DC04 doesn't have a clutch. My best guess is that the belt that drives the brush roll has broken. The smell of burning and smoke puff were probably caused by the motor suddenly speeding up when freed of its burden of driving the brush roll. For illustrated guidance on checking (and if necessary changing) the belt, go to www.dysonmedic.com then scroll to the bottom of the page and click on "DC04 Belt Change Guide".
I hope this helps. If so, please remember to rate this response. If not, please post a reply and I'll try again. Good luck!
Feb 05, 2010 | Vacuums
My dyson vacuum motor is sounding very high pitched... The tubes are all clear and there is suction with the tubes not not real good suction on the beater brush area....
Your dirt path is clogged, probably not far from the brush area. This is the reason you noticed the hi-pitch sound coming from the motor.
You may have to remove the hose to clear it.
Jan 19, 2010 | Vacuums
Decreased suction and high pitch whine in motor
clean out suction tubes ther is something caught in them
Dec 13, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Vacuum making high pitched noise and smells like motor is burning
try repair first for quote and if too expensive then replace. 5 years is about the average life span.
Jul 01, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson DCO7 Animal Bagless Upright Cyclonic Vacuum Logo
526 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
