Question about Brother Office Equipment & Supplies
Printer won't work. Message says, "Data Remaining". Instruction book says, "click Stop/Exit key". I did with no result.
  • 435 Answers
Are you there?
Posted on Dec 01, 2008
How do I disable InCognito mode turn off
First, open the registry editor:
  1. Open the Start menu
  2. In the search box, type "regedit"
  3. A program called regedit.exe will appear, click on this
  4. If a warning comes up click Yes
Next, navigate to the Policies key:
  1. Start by double clicking on "Computer"
  2. Then, double click on "HKEY_LOCAL_MACHINE"
  3. Next, double click on "SOFTWARE"
  4. Finally, double click on "Policies"
Next, create a new entry called IncognitoModeAvailability:
  1. Right-click on "Policies" and select New >> Key
  2. Enter "Google" (without the quotes) as the name of the key
  3. Right-click on "Google" and select New >> Key
  4. Enter "Chrome" (without the quotes) as the name of the key
  5. Right-click on "Chrome" and select New >> DWORD (32-bit) Value
  6. Enter "IncognitoModeAvailability" (without the quotes) as the name
  7. Right-click on "IncognitoModeAvailability" and select "Modify..."
  8. Type a 1 in the "Value Data" text box
  9. Click OK and exit the Registry Editor program
Restart Google Chrome and now if you open the settings menu, the "New incognito window" option will be disabled.
https://www.internetsafetyproject.org/wiki/how-disable-incognito-mode-chrome
Dec 18, 2014 | Acer AC700-1099 Chrome book Wi-Fi
I did not install the driver or anything. i just set the encryption key and thats it. it works fine for a long time and suddenly, it goes cuckoo. i get the message: "application has encountered an...
While it is working get whatever data you need copied back to your main drive then format it with fat32 and copy it back you shouldnt have a problem..........plz vote
Jan 25, 2011 | Western Digital My Book Elite 2TB External...
There is a message showing on My Canon MX310 "Check Printer 5B00", how do I fix it? Right before the message showed up I copied a document that printed with a line down the middle.
Try these procedure:
Go to START MENU
Choose RUN
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Dec 08, 2010 | Canon PIXMA MX310 All-In-One Printer
My brother printer DCP135C have to following error message how to clear it "clean unable 46 see troubleshooting and routine maintenance chapter to user's guide"
Try to reset DCP printers without numeric keypad.
Follow this:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Don't forget to vote Thanks!!!
Oct 29, 2010 | Brother DCP 130C All-In-One InkJet Printer
Failed to overwrite all data bizhub 250
the overwrite data function is supposed to take about 35 hours but the ones that i have done took about 20 hours and ounce the process is started you should never interupt it this function overwrites all the data on the hard drive HD-504 you could try formatting the hard drive first then overwrite again
1touch the utility/counter button then details
2 press stop,0,0,stop,01
3 enter 00000000 touch end
4 touch tech rep mode
5 touch function
6 touch hard disk format
7 touch yes
8 touch enter when the message the hard disk format completed.result:ng appears touch ok
9 touch hard disk format
10 touch yes
11 touch enter this starts the formatting procedure
12 when the message "the hard disk format completed. result:OK appears touch OK
13 press the reset key
14 touch exit on the tech rep screen
if the format fails replace the hard drive the format process takes about 30 minutes if you need further instructions on how to replace the hard drive post it
Dec 04, 2009 | Konica Minolta Office Equipment & Supplies
Error message is "data remaining" and does not print - what does this mean?
Open the temp folder and select all and delete and this should take care of it,It is just some temperary files being held in memory
Jul 16, 2009 | Brother MFC-5440CN All-In-One InkJet...
Cannot print with Lexmark x4875, Windows Vista OS.
You need to cancel all print jobs for a printer, you must have permission to manage documents on the printer.
1. Open printers by clicking the "Start" button , clicking "Control Panel," clicking "Hardware and Sound," and then clicking "Printers."
2. To open the print queue, double-click the printer you are using.
3. Click the "Printer" menu, and then click "Cancel All Documents." Depending on the printer, the item currently printing might finish, but the remaining items will be cancelled.
Next, you may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 4800 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
Apr 17, 2009 | Lexmark X4875 All-In-One InkJet Printer
Hp scanjet will not copy to print
FROM HP, searched and found after three or four weeks of unresolved solutions .. and that's fixed the problem !!
Solution Follow the steps below:
  1. Click Start , then Printers and Faxes .
  2. Right-click the system default printer and click Properties .
  3. On the General tab, right-click the default printer and click Copy .
  4. Click Cancel to exit.
  5. Click Start and then click Run .
  6. In the Run dialog box, type regedit and click OK . WARNING: Using Registry Editor incorrectly can cause serious problems that may require you to reinstall your operating system. Hewlett-Packard cannot guarantee that problems resulting from the incorrect use of the Registry Editor can be solved. Use Registry Editor at your own risk. It is strongly recommended that you make a backup copy of the Registry before you edit it. For information about how to edit the Registry, view the "Changing Keys And Values" help topic in Registry Editor (Regedit.exe) or the "Add and Delete Information in the Registry" and "Edit Registry Data" help topics in Regedit32.exe.
  7. In the Registry Editor window, click Edit , then click Find... , and search for the following key: HKEY_CURRENT_USER\Software\Hewlett-Packard\DigitalImaging\hpfccopy .
  8. Double-click Printer in the right pane.
  9. In the Edit String window, paste the printer name as it appears in the Registry under Value data (for example, hp photosmart 8400 series) .
  10. Click OK and close the Registry Editor.
  11. Press Copy on the scanner. The default printer connected to the system should normally print the scanned document.
Cause This issue occurs when the default printer or the list of printers is not recognized on the hpfccopy function in the Current User section of the Registry.
Mar 28, 2008 | HP Scanjet 4370
152 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
