I have a 20 year old Maytag washer. It is in EXCELLENT condition. We have never had a problem with it! A few weeks ago, the spin cycle began to have a growling noise resembling a bearing. It sounds like a freight train. This only happens in the spin cycle. Any ideas. I am suspecting a bearing .
  • phforest Dec 01, 2008
    Thanks. I was afraid that it might required a "special tool" to remove the agitator. Do you know if the agitator release is from under the drum or inside the drum? I could n't find anything except a small 1/8 inch hole on top of the lower part of the agitator.
    Thanks for your help. The word on the street for the new front loaders is not good - expensive and unreliable! We also have a main floor laundry room.
  • 1,543 Answers
Your old Maytag is a much better machine than the new Maytag's, but replacing the drum bearing and seal is a somewhat expensive and rather difficult job, requiring a couple special tools. Not usually a do it yourself job. Unless you really love that machine, it's time for a new one. The average life of a washer is about 9 years. Look into the front load models which use much less water and spin out over twice as fast as your old top load machine. LG is the top rated by consumer reports, but you don't have to buy the top of the line models to get the the direct drive motor with 7 year part warranty. Other companies make a pretty good product also.
Don't bother rating this "solution" as anything but a FixYa lowers my rating.
Posted on Dec 01, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Dec 01, 2008
    The agitator is locked down with a set screw, usually a 1/4 hex head about 1/3 of the way down from the top of the agitator. You will need the special tool plus a hammer or mallet, to remove the nut holding the inner tub, or break it. (it is a left hand thread) Top cover of outer tub needs to come off before inner tub can be removed.
Why is my maytag bravos mvwb750wq washer so loud on spin cycle?
Is it moving around? I am guessing not so guess would be the drum is out of balance.
Jul 21, 2014 | Maytag Bravos Top Load Washer
Maytag Centennial Washer - NO SPIN
OK so it sounds to me like your clutch is just slipping sometimes. Because the issue is sporadic it's hard to test for certain what the issue is, but I would recommened ordering and replacing the clutch to fix the issue. Below is a link to a video that shows you how to replace the part if you'd like.
https://youtu.be/tVc6SZ2DD4U
Jun 01, 2017 | Maytag Washing Machines
Why is Maytag Centennial 3.2 cu. ft. SuperSize Capacity Plus Top Load Washer shaking during spin cycle
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Jan 02, 2012 | Maytag Centennial 3.2 cu. ft. SuperSize...
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer (model PAVT244AWW). Won't spin. Don't know how old it is or its history, as it came with a home we purchased in October. Several times it's "walked" during the spin cycle. About 6 weeks...
Its the clutch ,And it sounds like it time for a new washer,the clutch is expensive and washer are cheap try a second hand store that sale scratched or almost new machines
Jul 05, 2010 | Maytag PAV2300 Top Load Washer
Maytag washer will not agitate
A Maytag A412 is well over 20 years old....
Best guess is a corroded upper drive shaft, the one that the agitator is mounted on. Certainly it can be called a transmission problem.
Jun 28, 2017 | Maytag Washing Machines
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore 80 Series won't spin out
if the unit washes ,,and dont spins check your lid switch first...
Oct 25, 2008 | Kenmore 24902 Top Load Washer
Will not spin out heavy loads, stated by not balancing 2 mos ago
the transmission is shot after 20 loads a week for 4 and a half years
Oct 03, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
139 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
