Question about Sony DAV-SB100 System
No picture i was fiddling with the set up. i believe i hit something in progressive scan area. now i have audio but no picture. i followed the directions and pressed stop for five seconds, but the picture has not returned. i have no picture while dvd plays.
  • undrunk Nov 29, 2008
    How can we reset it to not send out progressive scan?
I FOUND THE ANSWER. TURN YOUR PLAYER ON. ON THE PLAYER ITSELF, NOT THE REMOVE PRESS AND HOLD THE PAUSE AND STOP BUTTONS AT THE SAME TIME. VOILA! LET ME KNOW IF IT WORKED...MRSHANER@HOTMAIL.COM
Posted on Sep 17, 2009
  • Heri Mart Dec 12, 2011
    I pressed both the pause and stop button on the unit itself and I was able to get my video back. I was able to see videos again!
    I pressed both the pause and stop button and was able to get video again. Thks!
I was playing around with the set up and i pressed a button that made me loose my image .but the sound works fine what do i do to get the picture back?
Posted on Feb 21, 2007
I ahd the same problem. If you are using red yellow and white cables, they can't transmit progressive scan. You need a progressive scan TV and the red blue and green cables. Plug the rd blue and green in under the red yellow and red ones at the back of the player, and it should work. Then go to your menu and turn progressive scan off, so you can use the player through the red white and yellow. Hope this helps
Posted on Jul 24, 2007
I was playing with settings on my Zenith xbv342 and set the menu to progressive scan. I now have a blue screen with the words "progressive scan mode" I cannot get a picture and it is stuck in this m
Progressive scan mode is used by DVD players to artificially scale standard resolution DVDs to HD resolution, usually 720i. Is your set capable of receiving HD resolution? If not, that is probably why you are getting the blue screen.
Dec 18, 2014 | Zenith XBV342 DVD Player/VCR
My xbv410 is stuck on progressive scan mode. I
press the set up button on the remote...the word "set up" should appear on the unit. then press and hold the stop button for 5 seconds...problem solved.
Mar 13, 2010 | Zenith XBV442 DVD Player/VCR
I cannot get video picture,But ican hear all audio functions.
put a disc in the player and once it starts to play press stop, then press and hold the stop button for 5 seconds this will turn off the progressive scan feature.
Apr 26, 2009 | Zenith DVT412 System
Do I have Progressive Scan on my TV?
component video is HD of sorts lower end of the scale. Your set has progressive scan..
Mar 26, 2009 | Televison & Video
How to set the "Progressive Scan" to "off"
I did the same thing. Hit progressive scan and now I have sound but no picture. I can't get to the menu to turn progressive scan off! Help!
Feb 23, 2009 | Sony DAV-SB100 System
I accidently hit the progressive scan button and now I can't get a picture when I try to watch a dvd.
just talked to LG Customer support and got them to send me a manual.
to turn off the progressive scan insert a disk and once it starts playing press stop, then press stop again and hold for 5 seconds this will turn off the progressive scan mode.
Dec 09, 2008 | Zenith DVT412 System
My dvd is in the progressive scan mode
Refer to the problems and solutions list...we had the same problem and following their steps resolved it!
Aug 29, 2008 | Zenith XBV442 DVD Player/VCR
Showing red image
Make sure red is matched up to red, green to green, and blue to blue first. Then, try a different set of YPbPr (component) cables if you have a set available. If it still shows up red, then read this:
If you are using a Progressive Scan TV
(TV must indicate Progressive Scan or
ProScan capability), to activate TV
Progressive Scan, please refer to your TV
user manual. For DVD system Progressive
Scan function, see page 28.
Helpful Hint:
– If your TV does not support Progressive
Scan, you will not be ab le to view the picture.
Press and hold OPEN/CLOSE button and
press ‘1’ to deactivate progressive scan.
Progressive Scan - turning on/off
To select this item, you must set “Video
Output” to Y PR PB and ensure that your
TV has progressive scan (See page 11.)
Follow the steps of “Using the Setup
Menu” and select :
> PROGRESSIVE
OFF
ON
PROGRESSIVE SCAN OFF
TV SHAPE
TV SYSTEM
VIDEO OUT
PROGRESSIVE
SCR SAVER
SMART POWER
OFF
Select this to disable Progressive scan
function.
ON
These are pp. 11 and 28 of your owner's manual for the HTS
If these methods still fail, try turning your TV's progressive scan off or on.
-Tha Mp3 Doctor
Jan 08, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
DVD recorder: Changed the settings, now
we could go through the setting like, you can see the monitor. using the remote do the following steps:
Step 1. press set up button.
Step 2. press down arrow once. ( playback)
Step 3. press OK.
Step 4. press down arrow once. (video (selection))
Step 5. press OK. (progressive scan)
Step 6. press OK, again.
Step 7. press down arrow once. (progressive scan off)
Step 8. press OK
you have now turned progressive scan off.
Dec 19, 2007 | Philips Magnavox MWR10D6 DVD Recorder
DVD player wont show picture
to turn it off select connection method 3 above and progressive scanning mode, to set the mode, set progressive to off in the display menu so that the p scan indicator light on the front panel goes out. do all of this in interface mode. you can also do this by pressing and holding PLAY > on the front of the unit for more than 5 seconds, still watch for the p scan indicator to go off. this works best when the unit is connected directly to the television.
Dec 04, 2007 | GoVideo Go Video DVD/VCR Combo
Sony DAV-SB100 System Logo
269 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
