I have a HP G60-120 that only sporadically responds when I press the power button to boot up. The first time out of the box it happened, and I spent 2 hours on the phone with HP only to be told to remove battery and power cord, hold power button down for 2 minutes, replace everything and try again. It worked that time but it continues to be a problem, and that fix does not always work. All the trouble it was to set up on my wireless network, I really don't want to exchange for fear of having to go through THAT drama again...any ideas?
  • Anonymous Mar 04, 2009
    omg, i have the exact the same problem. this lap top i just received yesterday came on twice out of 20 tries. i am returning the product for repair...
    Novelist:
    Champion:
  • 233 Answers
This is a brand new computer? If it is HP needs to make arrangements to repair or replace. This should not happen with a new computer. Something is defective. This is their problem not yours.
Posted on Dec 29, 2008
Officejet pro 8500a premium power light on but touch screen is off and will not respond and the power button will not respond either
hi, Mr Justin Becker
i think its a power supply problem, first you should try another dc adaptor, if your printer works fine with the new one, you have to replace it or take it for repair.
if it is a DC Adaptor problem it cost about: US $29.74
HP OfficeJet Pro 8500 AIO GSA printer power supply ac adapter cord...
Mar 06, 2014 | HP Office Equipment & Supplies
My 50 inch Philips Plasma TV is normally connected to a Virgin Media HD Box in order to watch TV programmes. Tonight my TV is showing a box that is called Information, and it has the wording No signal or...
Unplug both the set and box from power for a while--either may have caused a glitch---power both back with everything already connected and see if the reboot that will happen helps or not--a lot of times the box causes this by confusing the set it is connected to.
Nov 06, 2012 | Philips Televison & Video
Printer sporadically displays a red light three successive flashes error and will not respond to till / keyboard. What does this mean?
PUT PAPER INSIDE PRINTER POWER OFF THE PRINTER.
THEN PRESS & HOLD THE BUTTON ON TOP OF PRINTER
BY HOLDING THE BUTTON NOW SWITCH THE PRINTER ON & WAIT UNTIL THE SIZE OF PAPER IS SCANNED .
IT WIILL BE DONE.
Feb 08, 2011 | Epson TM88II Thermal Printer
My hp 2100 presario laptop in not booting
Startup problems
If the notebook doesn’t respond when you turn it on
• Connect the AC adapter.
• Reset the notebook by inserting the tip of a paper clip into the reset button on the
bottom of the notebook. Then press the power button to turn it on.
• If the notebook still doesn’t respond, remove the battery and AC adapter, remove
any PC cards, and undock the notebook if docked. Then plug in the AC adapter
again, and reset the notebook using the reset button.
If the notebook won’t boot from battery power
• Make sure the battery is properly inserted and fully charged. Check the battery
charge by removing it and pressing the pad on the side of the battery. The lights
show the charge level.
• If available, try another battery.
If the notebook won’t boot from the floppy disk drive
• Make sure the floppy disk drive is selected as the boot device.
• If you’re using a USB floppy drive, use the BIOS Setup utility to make sure
Legacy USB Support is enabled. If your notebook also has a built-in floppy
drive, use the BIOS Setup utility Boot menu to make sure the USB floppy drive
is the first device under Removable Drive.
If the notebook stops responding after booting
Check whether you are connected to a TCP/IP network with no DHCP server. This
can cause a long delay at startup because DHCP is enabled. Contact your network
administrator to determine the proper TCP/IP configuration
***IF THE NOTEBOOK HAS POWER BUT WONT BOOT INTO OPERATING SYSTEM-
Press F2 when you start it to enter BIOS to check your BOOT ORDER to make sure your HD is listed first on the list.
If it is not listed remove it and reinsert it and then try again.. GREAT LUCK!! Please Rate Me, K? Thanks- Lucky4lynn2
Mar 06, 2010 | HP Compaq Presario 2100 Laptop
Our Hp zd8000 starts up, gets the password, some of the icons show up, then the screen gets blue with some other colors in bars a message comes up saying could not recover from a hardware deadlock, using...
Try restarting into safe mode and using another computer (if one is available) to download Display Drivers for your laptop. These drivers should be available from the HP website free of charge. Copy these drivers to the CD or floppy (depending on which your laptop uses) and if you could boot up in safe mode, install the new drivers and restart the computer. To restart your computer in safe mode, the computer should say a F key (F1-F12) to press during the post to enter safe mode, or you could hold the power button down while windows is first booting to interrupt the boot, and the next time you power on the computer it should ask you if you want to start up in safe mode 'because Windows could not start normally'. If this does not work please respond again! Thank you.
Dec 02, 2009 | HP Computers & Internet
How do i reboot
If your unit was freeze and did not respond to any key you press, you may try to press the power button for 5 seconds, the unit will automatically turn off, on this state press again power button once.
Hope this helps
Nov 29, 2009 | HP Pavilion dv6000z Notebook
Not responding for power button when i press
Hold it down for 15 seconds,if it goes totally off,change your power setting in the control  panel
Oct 10, 2009 | HP Compaq Presario R4000 Notebook
Difficult to boot. I must try 5-10 times or press the mainboard.
When rebooting or shutting down, hold the power button for at least five seconds.
Aug 31, 2009 | HP Compaq nx8220 Notebook
Printer will not respond
Canon S330 Turn off printer
Hold down Resume button and press Power button.
Keep holding down Power button and let Resume button go.
Press Resume button 2 times then let BOTH buttons go.
Green lights will flash and then stop blinking.
When green lights are solid, press the Resume button 4 times.
Press the Power button and the printer should turn off, if not, press the Power button once more.
Your printer should respond as normal
Jul 22, 2008 | Canon S 330 InkJet Printer
Printer will not finish 'booting up'
remove the power cable directly from the back of the printer, press and hold # and 9 while holding both these buttons put the power cable back to the printer. now let the buttons go when the on light starts flashing
Dec 28, 2006 | HP OfficeJet 7410 All-In-One InkJet...
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
