Question about E-Machines (308714) Motherboard
My coole fan is work and system is not comeup what do i do?
My system is not comeup and it use to write no signa.another one is not comeup
    Problem Solver:
  • 11 Answers
Go into setup....delete......set the fan temperatures.
Posted on Oct 16, 2009
My ac is not working I have a Chevy Tahoe 2005 the fans won't turn on either .
Hi Maria , The A/C system wouldn't keep the fans from running but none working cooling fans will keep the A/C from working ! This is a fairly complex system if your not familiar with this sort of thing ! I will add the description from the factory service manual.
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 electrical cooling fans and 3 fan relays. The relays are arranged in a series/parallel configuration that allows the powertrain control module (PCM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block.
During low speed operation, the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan s/p relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the PCM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the PCM supplies a ground path for the high speed fan relay and the cooling fan s/p relay through the high speed cooling fan relay control circuit. This energizes the cooling fan s/p relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time the high speed fan relay coil is energized closing the relay contacts and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit to the right cooling fan. During high speed fan operation, both engine cooling fans have there own ground path. The result is a parallel circuit with both fans running at high speed.
Do you have a check engine light lit ? The thing to do would have it check at the dealer or a ASE certified repair facility ! They could hook up a advanced scan tool an diagnose fairly quick ! Or you could find a wiring diagram an try testing with a volt meter yourself ! But watch yourself so you don't short out the PCM - engine computer !
May 01, 2015 | AC Cars & Trucks
Cooling fan for a 1998 GRAND MARQUIA
check to see if there is voltage coming to the fan, check to see if it changes when the engine gets warm indicating that the sensor is working and sending a signal to the fan, if it does change and the fan does not come on then it is the fan itself
Sep 20, 2014 | Sony Cooling Fan with CPU / GPU Heatsink...
Cooling fans dont work
If the fans don't turn when you first put power to the system, most likely the fans need to be replaced.
Sep 13, 2014 | Dell (6F858) Cooling Fan
My alienware m11x has this problem everytime i turn it on it beeps and doesnt stop beeping lights comeup and fan but no display either
* Make sure the laptop is using the AC adapter
* Turn on or restart the computer
* When the Dell logo appears, press F12 immediately. If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft Windows desktop, and then shut down the computer and try again
* Select Diagnostics from the menu and press Enter
* If a failure is detected, the computer stops and beeps, press Y to retest the component that failed
Oct 14, 2013 | Alienware PC Systems Computers & Internet
Fan comes on when switch ignition on instead of when hot Tazz
If the fan not turning on when car engine getting hot,then car will notice overheating.Click this link below for troubleshooting:---http://technoanswers.blogspot.in/2012/02/car-running-hot.html--------To know how engine cooling system works ,click the link below :----Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works? http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
------------How to Replace Engine cooling Fan:-- http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-engine-cooling-fan-on.html
-----------Replace Fan Relay but still Radiator cooling fans not working? http://schematicsdiagram.blogspot.com/2011/12/replace-fan-relay-but-still-radiator.html
----------DIC says "COOLING FAN FAULT"? http://schematicsdiagram.blogspot.com/2011/12/dic-says-cooling-fan-fault.html
---------Where Is Radiator Fan relay and Fuse Located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radiator-fan-relay-and-fuse.html
This will help.
Thanks.
Feb 09, 2012 | Cars & Trucks
Recently replaced radiator after finding cracks in original unit, after assembled engine coolant temperature would not comeup to operating range 185-195, replaced thermostate--no help-replace water...
Replacing all of thoes things will only make it run even cooler yet. Check the ignition timing and Try using Hotter Spark Plugs. Also try a higher octane of fuel. Turn engine off and make sure the clutch fan will turn Freely by hand, if the bearing is seased up that could cause an over cooling condition. Good Luck and have a happy new year. From Ernie @ RedDeer, Alberta,Canada.If these things do not help you could also try changing the engine coolant temperature Sensor.
Dec 27, 2010 | 2001 Chevrolet S-10
When i turn on my pc a orange light starts blinking and the fan is not working and i'm not seeing anything
run a diagnostics on the system, press and hold "fn" key and then turn on the system it will go to the diagnostics mode and then it will comeup with and error or it will show you the malfunctioning component
Oct 26, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
The fan speed controller box is not working,that mean the radiator cooling fan is not working to .
does the fan work when connected directly to power? is there power present at the fan connector, what about at the fan speed controller?
Oct 31, 2009 | Gigabyte 3D Galaxy II CPU Water Cooling...
Left turn signa on 1999 malibu does not work when
I need more detail, but look in to the turn signal switch. it controls head lights turn signals ect.
Sep 04, 2009 | 1999 Chevrolet Malibu
Why Is the Cooling Fan not working?
Check the Following:
1. Thermostat
2. Water Level in reservoir
3. FUSES
4. Water Pump
Apr 21, 2009 | Compaq Presario 1626 Cooling Fan Case...
E-Machines (308714) Motherboard Logo
136 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
