Question about Dell OptiPlex GX260 PC Desktop
No display I noticed there was two monitor settings and i disabled both on accident, and now can't see anything, how can i enable them again
  • bcjohn Dec 01, 2008
    there is only one PCI slot
  • 160 Answers
Remove the video card then start it up and let i run for about 20 mins or so then shut it down then out the video card in a diff slot then start it up
Posted on Dec 01, 2008
    Scholar:
  • 160 Answers
Restart, and before windows starts press the f8 key to enter set-up mode (or it may be f5), select last known good configuration, press enter. this should reset it.
Accidently disabled display screen on my laptop and also disabled the external Vga, how can I enable them now that I cannot see anything, ps...they both show in setup utility. Compaq Pressario V6000.
Normally you can switch between internal and external screen by holding the fn-key Down while hitting one of the function keys with a Screen symbol on (f7 or f8)
Sep 22, 2013 | HP Compaq Presario V6000T Notebook
Disabled monitor display adapter
Try to hold down shift several times and reboot your computer. As soon as you see the lenovo sign shift again till you get to safe mode.. This might allow the monitor to stay on to trouble shoot ...If not you will have to call lenovo.
Jan 05, 2018 | Lenovo 3000 C100 Notebook
My monitor is displaying sideways on a hp montior
It sounds to me like you have Hotkeys enabled and accidently pressed them.
To rotate screen view you can do the following using the keyboard arrow keys in conjunction with pressing CTRL key and ALT key at same time:
Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
To locate HotKeys and disable navigate here:
Start >> Control Panel >> Display >> Settings >> Advanced
Subject to your monitor/graphics card you may need to click a few mor tabs to see HotKeys.
Hope this helps. Best Regards -md
Nov 10, 2009 | HP dx2250 Monitor Personal computer AMD...
My tft hpl1908w,is not starting up immediately when i switch on my pc.you have to switch off and on again several times so that it can start up.but onece started up there is no problem untill you switch it...
HP SUPPORT COMMUNICATION - CUSTOMER NOTICE Document ID: c01764371
Version: 1
Notice: HP Flat Panel Monitors - Pressing Menu Button Or Power Button Has No Effect Other Than To Display A Warning Message NOTICE: The information in this document, including products and software versions, is current as of the Release Date. This document is subject to change without notice. Release Date: 2009-06-05
Last Updated: 2009-06-05
DESCRIPTION Many newer HP monitors have a feature that allows users to disable the front panel Menu and Power buttons. When they are disabled, pressing them has no effect other than to display on-screen warning messages.
DETAILS If the Power button is disabled; pressing it displays this message:
Power Button Lockout
If the Menu button disabled, pressing it displays this message:
OSD Lockout
The buttons can be re-enabled as follows:
If the Power button is disabled, press and hold it for 10 seconds to unlock it.
If the Menu button is disabled, press and hold it for 10 seconds to unlock it.
NOTE If the Power or Menu buttons are not disabled, pressing and holding them for 10 seconds will disabled them. Here's the site.....
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3548687&prodTypeId=382087&objectID=c01764371
Jun 28, 2009 | Computers & Internet
Laptop problem
can you see the bios screen then follow the following
when you laptop is booting press F 8 then select boot in safe mode then from device driver you can enable the display adapter.
post your findings
Jun 25, 2008 | Acer Aspire 3680 Laptop
Changed graphics card-then disabled the monitor by accident, now black screen.Not even safe mode works now!
That's pretty funny (apart from the suffering)! It's doing exactly what you asked and displaying nothing to that monitor. Even if you safe-boot, the VGA thing might try to honor the setting (though it shouldn't if you have WinXP SP3.)
Booting to a command prompt 'only' from the safe boot choices and importing some regedit settings from another machine's video might just do the trick. (As well might adding a 2nd monitor on some machine and seeing what changes in the registry using a monitor program for that.... Some 'display' key probably contains 'disabled 1' instead of 'disabled 0'.... )
If you can get a LiveCD or bootable USB key of any sort (WinXP, Knoppix, Kevin's Rescue CD, etc.) you can probably just enjoy graphics settings by booting to that, and edit the registry or use WINCONFIG a little more freely than Safe Boot offers.
Feb 22, 2008 | Gateway FPD2275W LCD Monitor
How to re-enable VGA display it was disabled accidently
in bios settings there is a option enable or disable onboard display card check , one more option is there press F8 key when you are restarting the system some options is come their select enable vga mode
Feb 08, 2008 | Dell Latitude C640 Notebook
No signal to monitor
  1. Verify card is seated properly.
  2. Check bios settings. ie. disable onboard video, enable PNP OS installed, enable "assign IRQ to vga", disable shadowing and caching, enable passive release, enable delayed transaction, vga boot sequence: AGP, set graphics aperture size to 128MB, disable turbo modes.
  3. Verify power supply is at least 350 watts.
  4. Reboot into safe mode (press F8 right after the BIOS POST screen and before the windows loading screen) and use the program, Driver Cleaner Pro to remove Nvidia video driver remnants. Don't select all of the options, just the Nvidia driver and the plain ATI selection.
  5. Verify the monitor cable is securely connected to both the monitor and the computer.
  6. Verify that you have connected the cable to the vga port on the card and not the onboard vga port. (I'm not implying that you are dumb or anything like that, but sometimes even the best of us, overlooks the simple things... especially me! LOL)
  7. Verify the monitor cable is good.
  8. (Last but not least), try using another monitor to test. (Could be an incompatibility with the monitor.)
Jan 02, 2008 | ATI RADEON X1650 Graphic Card
Dell OptiPlex GX260 PC Desktop Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
