My syncmaster 2232bw keeps blanking out - Computers & Internet
  • 90 Answers
Check the power connection on your screen.
If this doesn't solve the problem, you will have to contact Samsung.
Posted on Dec 02, 2008
I have a SyncMaster 2232BW monitor hooked to my pc, the blue power button comes on when power on, my computer POST appears for about a second then vanishes leaving only bright lights on display, none of...
Seems that you may have the wrong type of video selection theres a button for auto sensing the type of connection. if your video cable is blue then you have an analog connection, white video cable is a digital connection you just need to ensure that the monitor is set to the proper selection.
Sep 05, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
I have Syncmaster 2232bw. When I first switch it on it flashes for about 1 minute before it stopsa flashing. After that it runs fine until I switch off and it cools. Is this the backlight dying?
This happened with my 2232bw also. The problem was that the 5 820uF capacitors that had burnt out so I replaced them with 5 1000uF capacitors and it's now working like a dream.
Hope This Helps
Slick2160
Oct 15, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
How do you remove the back on a samsung syncmaster 2232bw computer monitor? There are no screws I can see and prying with a screwdriver just scratched it. I need to get in there to replace a lamp or...
toolman6872, Didn't you visit YOUTUBE and see some video clips about "lcd monitor disassembly" and or "lcd monitor repair" ? Let me know if you don't find some info there or at www.ccl-la.com/badcaps.htm Also try using very, very DULL butter knife, not screwdrivers. If you found this helpful, rate it on fixya! 12fixlouie
Dec 31, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
My samsung syncmaster 2232bw wont turn on at all, and the pilot light(blue light surrounding power button) is flashing repeatedly at a fast pace, much much faster than the norm?????????
Solution for Samsung SyncMaster 2232BWplus:
The problem is bad capacitors: 5 pcs. 820microFarad – 25v and 1 pc. 330microFarad -25v. Replace these capacitors. Then re-solder the two transformers of inverter side. Also re-solder the power transformer and the inductor coil.
To open the casing:
At the bottom of the stand just twist the knob to unlock. Then, use a small flat screw driver beginning from the bottom (left or right) then using a hard credit card (or alike) then slide/glide it in between the cover plastics.
Roan
Triangle Tech Whiz
Dec 01, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Flashing screen when i first turn on my SamsungSyncMaster 2232 bw
I had a similar problem with my LCD computer screen. I took it apart and noticed a capacitor that was raised up on the flat end and appeared to be leaking a substance. Replaced it with a similar capacitor and works fine, for three years now.
Jul 05, 2017 | Samsung SyncMaster 2233BW 22" LCD Monitor
Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Sep 02, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Blank screen, flashing led power light
this sounds exactly like what happened to my 2232BW. I took screenshots of the fix and posted them on my webpage:
http://www.alexdemo.site90.com/#samsung2232bw_fix
Jun 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Any suggestions ?
hello,
firstly you check this monitor to another pc. it the same problem accure then
i thinks this problem due to falure of power supply or dead of flurocent tube. or any the vga cable is faulty.
ok
bye
Oct 29, 2008 | Samsung SyncMaster 920N 19" LCD Monitor
Samsung monitor and mac os
Please do not adjust RGB unless you know what you are doing.
For critical color work, you will need to use a photospectrometer and calibration software to analyze what your monitor is spitting out.
There are a million obvious reasons you should not trust your eye making arbitrary RGB adjustments off the hip.
Feb 15, 2008 | ViewSonic VX2255 Monitor
Computers & Internet Logo
267 people viewed this question
David Payne
David Payne
