Question about HP iPAQ HX2415 Pocket PC
My Wireless in the iPAQ hx2415 doesn't work anymore
Hi people, my wireless connection doesn't find any networks, not anymore... i tried formatting my pocket pc but it still doesn't work... i even tried it near other hotspots and other accesspoints but nothing is working... and it even can't be discovered i once heard about a fix for that , some update or firmware update, even googled about it and nothing came up. please help me i can help you too
  • Mohammad Abumuailek
    Mohammad Abumuailek Jan 30, 2007
    I've already done that, but no GOOD !!!
    still, the WiFi can't find any AP !!
    Novelist:
  • 198 Answers
Hi man. Yes you should first upgrade/reinstall the ROM. That includes your firmware, OS and drivers. Go to HP's web site and download these uprgades. Here's a dirrect link. http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=443063&prodTypeId=215348&prodSeriesId=421399&swLang=8&taskId=135&swEnvOID=2067 Select your OS from the list first. Follow the instructions that come with these files. If after this it still doesn't work please let me know.
Posted on Jan 30, 2007
SOURCE:
Adapter inactive
It is not the problem with the router. It is the problem with the wireless adapter on your computer. Open Network connections and look for Wireless network connection. If it is not there then open the Device Manager and look for Wireless network adapter under Network adapters. It seems that wireless adapter on your computer is not working or it is not detected by your computer. If you have external wireless adapter then unplug it and replug it.
Nov 30, 2011 | Cisco Linksys E1000 WirelessN Broadband...
On a new iPAQ 111, I can't connect to a network wirelessly
Have you tried resetting your iPAQ? You do that by pushing the little button on the side with the stylus. The screen will go blank for a bit, and then windows will restart. I had bought mine used, and when I got it, I had the same problem in that I never got the screen that let me select the wireless network. It fixed mine. Once it is working again, try selecting "View WLAN Networks" again, and you will see a list of networks that it can hear. If the SSID Brodcast is enabled on your wireless access point, you will see your network there. If SSID is not enabled on your WAP, you will need to type in the name of your network before it will find it.
Hope this helps. Sorry it was so late in being posted.
Jun 30, 2010 | HP iPAQ 111 Classic Pocket PC
I'm running Vista and I'm having trouble with my HX2415.I have Windows Mobile Device Center Installed. When I plug the unit into a USB port it doesn't find the hardware. It worked fine on XP with Active...
Hi
Thanks for using FixYa. HP ipaq HX2415 is compatible with Windows Vista Mobile Device center Version 6.1. Please check if you are using version 6.1, you can download the Windows Vista Mobile Device center Version 6.1 from this link--
Windows Vista Mobile Device center Version 6.1 Link
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Sep 07, 2009 | HP iPAQ HX2415 Pocket PC
IPAQ RX3715 can't log on to home network
Try upgrading the firmware on the router and then connect the IPAQ and computer to the wireless network
Jun 11, 2009 | NetGear RangeMax Dual-Band Wireless-N...
Hi, my hp ipaq hw6950 won't connect to my wireless router. It endlessly says connecting... connecting... connecting... Thanks
try resetting the router and try connecting check whts the wireless standards in the router and the ipaq and config according to that for instance if ur router can support b then try entering the setting manually it will work try entering the correct wireless key
Nov 01, 2008 | Computers & Internet
HP iPAQ H4150 Pocket PC
Go to Settings-Connections-Connections-advanced-Network Card.
You will see all available wireless networks in your area. Double click the desired wireless network and tap connect. Note whether the desired network has been connected.
Hope this help,
Harit
Jun 26, 2008 | HP iPAQ H4150 Pocket PC
IPAQ wireless connectivity
always start with the simplest answer first so make sure you have WiFi turned on. Think back, have you changed the wireless security on your router? If so you may need to re-enter the network details or add your iPAQ's MAC address to the access control list on the router. In the bottom right-hand corner of the home screen you should have a small HP Wireless symbol, if you tap it you should get your HP Wireless control panel on screen and can 1: turn WiFi on and off, 2: manually enter the WiFi network details and 3: search for WiFi networks in range.
Aug 16, 2007 | HP iPAQ H5555 Pocket PC
Connecting a Ipaq RX3715 to a wireless router
First, you have to be sure your ipaq has wi-fi feature is on and you can check on network connectivity option for any wrong setup there. According to your information, your ipaq is not recognized by your router and I agreed that your router is working normally. Try to reboot your ipaq and be sure to get wi-fi to turn on and try to connect it again. I have my Dell Axim also used Windows Mobile like Ipaq and it connected easily with no issue. The message in your to show me that you need first to identify your ipaq before you you can get it to connect to your network. I hope this help.
Mar 05, 2007 | HP iPAQ RX3715 Pocket PC
Wireless Internet on iPAQ 2215
You will be wanting an SDIO wireless 802.11b card.
Sep 15, 2005 | HP FA162A for iPAQ 2215/4155 Keyboard
How to get a CD-ROM program to run?
You're probably going to have to set up an ActiveSync connection between your PC and your 2415, then run the program installer on your PC while you're connected to the iPaq.
Sep 11, 2005 | HP iPAQ HX2415 Pocket PC
HP iPAQ HX2415 Pocket PC Logo
216 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
