Question about Canon imageCLASS MF4150 All-In-One Laser Printer
CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
It prints one page then stops the error light flashes red and the message 'load correct paper cassette : ltr ' appears on the LCD screen. I have tried resetting the paper size thickness etc also the manual feeder is set at a4 - help?! CANON MF4150 'LOAD CORRECT PAPER CASSETTE : LTR' problem It prints fine and then stops after 10 or so pages, with the above error. Settings are correct both on printer and on software running. Vista driver was reloaded as well, still problems printing.
  • 1 more comment
  • Anonymous Dec 03, 2008
    I just purchased the imageclass printer and keep receiving the message charge paper adequat I hope that by changing my paper it will solve the problem!
  • kwasha
    kwasha Nov 03, 2013
    @therizbo, thanx, I have sorted out the problem that I had with the imageRUNNER 2420. I just needed to match the paper sizes. You have unquestionably helped. Bravo!
  • Anonymous Mar 14, 2014
    Error 4102
    The media type and paper size are not set correctly.
    Action
    Press the machine's Stop button, to cancel printing, change the media type or paper size setting, then print again.
    Will not print 8 x 10 photos.
I had the same cr@p of the problem yesterday. The problem was not in the paper. You have to do 2 simple things, from which one will solve the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect paper format. Solution is very simple. Open MS word or something similar, file->print.. and before you print open Properties menu. There for the Output Size will be selected "Match Page Size". you don't want that (i don't know why it doesn't work), but the solution is manually select A4, or whatever your page size is.
Posted on Dec 27, 2008
AFter we tried everything, the paper we bought was apparently not quality controlled and mixed with different weights of paper that caused the error. We purchased another brand and have had no problems so far...
Posted on Dec 02, 2008
  • kwasha
    kwasha Nov 03, 2013
    Thanx, I have sorted out the problem. The match of paper size was all that I needed to do. Bravo!
3 Suggested Answers
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had the same cr@p of the problem yesterday. The problem was not inthe paper. You have to do 2 simple things, from which one will solvethe problem.
And the more important thing, the problem occurred due to incorrectpaper format. Solution is very simple. Open MS word or somethingsimilar, file->print.. and before you print open Properties menu.There for the Output Size will be selected "Match Page Size". you don'twant that (i don't know why it doesn't work), but the solution ismanually select A4, or whatever your page size is.
And there it is... printer starts throwing pages out like crazy :)))
the problem is from Word.
Change the settings: File-Page Setup-A4 (not letter).
IT'S WORKING!!!!
Posted on Feb 08, 2008
My printer is i-sensys MF4150. It prints one page then stops the error light flashes red and message 'load correct paper cassette : ltr ' appears on the LCD screen.I print 1 page then I...
Dear
Pl. select the paper size ( as mentioned on the paper packet) on computer on click START-PRINTER AND FAXES(new window opened)-(right click on printer icon) PRINTING PREFERENCE(new window opened)-select PAPER -paper option (here the paper size to be selected- APPLY. This may set the paper size default.
Thanks.
Feb 03, 2015 | Office Equipment & Supplies
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
Oct 01, 2011 | Canon PIXMA MX340 Wireless Office...
Whenever I try to print anything or copy anything on the Cannon MF6530 it will print the first page then make a beeping noise and the red light starts flashing and it says change paper size - casette 1 LTR...
try to set the proper size for the paper in the printer.
press [Additional Functions] button (right of the LED display)
navigate to Common Settings
use [<-] and [+>] buttons to navigate to Select Paper Type and press and press OK
Confirm that Cassette 1 i selected (or Cassette 2 if you have optional installed)
and Set the paper type
next navigate to Reg. Paper Size, press OK, confirm again the cassette (1 or 2) and using the arrow buttons, set the paper size (should be LTR if you using LTR)
Sep 20, 2011 | Office Equipment & Supplies
The red light is on and appear this message: LOAD CORRECT PAPER CASSETTE. What should I do?
if this happens when you send the print job, you need to choose correct paper size under the printer properties on your pc.
Go to the printers, choose your mf4150, right click and properties, under tab preference, under page size choose correct one i.e. A4.
Turn MF off and back on and try again to print
Aug 04, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Dec 06, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon MF3240 printer error message.........
I think I solved my printer problem: Chang the paper size to LTR in the printer panel. then go to compter printer setup and choose printing preferences and choose page setup and chang the paper size to Letter (LTR) also. hope this is helpful.
Nov 13, 2007 | Office Equipment & Supplies
I had same thing happen after a fresh Windows install. It was hard to figure out since it had been working fine until then, but luckily it is simple to fix. Open the Start Menu > Settings > Printers and Faxes folder. Then right-click on the Canon MF4100 Series printer and choose Printing Preferences. In there, change the Paper Size to Letter (instead of A4). You may also have to do this in the Print setup for whatever program you're using to print.
Sep 11, 2007 | Canon i-SENSYS MF4140 All-In-One Laser...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
4,955 people viewed this question
old marine
old marine
