Question about Apple iPod MA446LL/A MP3 Player
30GiPod has no sound
My ipod has no sound. I usually only use it in my car and it would not output any sound for a while. Then when I turned my car on it started to play again but only for a moment. I have tried other headsets and docking stations but none have worked. I got the cover off but I am not able to find any info on the web and I do not want to send it in for repair and get a different one back
    Problem Solver:
  • 6 Answers
First, make sure that the small bar near the top isn't switched to the "Locked " position. If this is the case, there should be a little red showing in a small divot near the slider. If this isn't the case, make sure that you haven't set any volume limit. If this is the case, when you try to turn up the volume, a little padlock icon will show up next to the bar. I hope this helps. ;)
Posted on Jan 31, 2009
My daughters high school dance team uses a samson 308i speaker/pa system. it is only 6 months old but the music will cut out from one of the speakers. It is not the speaker (we switched them) not the...
You have to double check the cable from Ipod to PA system. Most probably the audio out cable from ipod is not correclty fitting the output port of ipod. If you are using any cover for ipod., remove it and check. If the output pin is not correctly fit in to ipod both chanels will mix and output will be like karaoke sound....Use good quality output cable for ipod. Its a suggestion...
Jan 10, 2018 | Music
My iPod only outputs sound to one ear bud, how can I fix it?
Have you tried multiple pairs of headphones?
try a soft reset (hold power button and home button until screen flashes white and turns off)
Reboot ipod from Itunes
Apr 05, 2011 | Apple iPod touch
I have an Apple iPod accessory -- Model A1121-- that doesn't output any sound.
I can help you troubleshoot your A1121 iPOD docking station.
First of all, can you confirm that your iPOD is seating correctly and securely in the docking port?
For example, when the + or - buttons are pressed on the top, does the green light on the front blink, eventually going red after several pushes?
& Is there any indication that the unit is controlling your iPOD, but simply not outputting sound?
Apr 15, 2010 | Audio Players & Recorders
Car amplifire when conected to nokia mobile music player and when sound level increases of the mobile device the output sound cuts and plys also plys very low sound
Mobile r not good for playing music in a heavy system because Mobile has not a good sound quality as iPOD and others players have, also all mobile has not a capacity to play with amplifier, and the sound output of your mobile is low there fore u r getting low sound. If your amplifier has its own volume control then u can increase it from there. It is best to use iPOD. Thanks
Nov 25, 2009 | Sony XM-222 Car Audio Amplifier
The aux input is only outputing sound on right speaker with my ipod. tried ipod in different car works fine.thanks
Sounds as if the LEFT Channel of OUTPUT IS Burned out this Happens MORE With Children Around to Plug Inapropreate Things into it
Jul 24, 2009 | Car Audio & Video
Use of AV2 input sound socketsto play ipod
The sound is muted unless a video signal is detected on this TV. The only work around would be to connect the camcorder or some other active video to tha input but using the IPOD for the audio.
Jul 23, 2009 | LG RZ-17LZ21 17 in. LCD Television
No output from ipod
are you using the holder things that are supposed to hold the ipod steady in the dock, if so take it out. my ipod only works in there if its by itself.
although now it wont play any sound from my ipod (movies or videos) but will play sound from dvd and tv. any suggestions?
Jan 02, 2009 | Televison & Video
Hooking up an ipod to the stereo
hi
cord from ipod should connect into amplifier input socket.....the headphone on front of most stereos is an output socket....thats like trying to go in thru the out door ...if you get me,
your stereo might not have a separate input.....they are usually on rear of stereo amplifier in older units
Nov 15, 2008 | RCA RS2656 Shelf System
Audio cable for lcd monitor for cpu
A USB cable????? How about just a regular audio cable. Plug one end into the audio input on the monitor and the other one into the audio output (usually green) on the back of the tower.
One just like this.
Jun 23, 2008 | Audio Players & Recorders
Radio has sound but not the CD player or iPod
Your amp is not turning on - what you should do is connect the "blue/white - remote turn-on lead" to whatever wire you have the "blue - power antenna" output from the Alpine connected to now. That should solve your problem.
Mar 07, 2008 | Alpine CDA-9883 CD Player
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
