Maytag MDB9600A Jetclean II Built-in Dishwasher
Problem for Maytag MDB9600A Jetclean II Built-in Dishwasher
I can't get my dishwasher to start
By oklahoma on Jan 27, 2007
The lights on the control touch panel are flashing on the clean cycle indicator as well as the Rinse Only, Normal Wash and Heated Dry. I can't get them to stop flashing and I can't run the dishwasher. I've tried pressing the 3 second lock /unlock button but that's not doing anything either. How can I get these lights to stop flashing and get my dishwasher to run?
Same Problem
Dec 06, 2008
-   I had the same problem with my MDB9750 dishwasher, but followed the directions to clean the 18-pin connector on the circuit board as suggested by SelfHelp3 posting. I used a cotton swab and rubbing alcohol. Since I had the hex-head sockets, the total repair took only about 45 minutes. I had to power down the dishwasher at the circuit breaker box since I didn't know how to disconnect the power otherwise. -   Guest
Aug 18, 2008
-   Try shutting off the power for 30 seconds and then push and hold the drain off button for 3 seconds. Problem cleared for me.-   Guest
Jul 28, 2008
-   I have followed all the recomendations on line but can't get my dishwasher to start and lights to keep from flashing. The Lock symbol with the number "three" in it flashes along with the heated Dry and Santize buttons. When I push the Heated Dry button, the lights flash about five times and then they just stay on. I have unplugged the unit and looked at all the connections after pulling off the front panel. This is a different style than the dishwashers I have seen on line with the same type problem. Can you please help?
Thanks,
AD-   Laurad222
Apr 04, 2008
-   We had the same problem (lights blinking/not operational) with our Maytag Dishwasher Model# MDB5100AWW. My husband took out the "pcb assembly" (panel control board) from the door panel. He then lifted the smaller circuit board up and then popped the lower circuit board out of it's plastic holder. At this point, he removed the rubber 9 button cover and cleaned the 18 little wires that this rubber 9 button cover makes contact with. He used an eraser to clean these areas. He reassembled the door panel, plugged in the unit and the lights were still flashing. He pressed the off button twice and the dishwasher was fixed for free. We pocketed the $130 (Canadian dollars) by NOT having to replace the entire "pcb assembly"!!! *NOTE: We were advised to unplug the dishwasher and let it stand for several hours, so as to drain all the electricity out of the circuit panels. Feel free to email me at vgriffiths@telus.net for more info. if anything seems unclear.-   selfhelp3
Jan 18, 2008
-   My dishwasher runs then stop, runs then stops and then the lights on the front flash. I have read the instructions that were posted and I want to know when I push the "Normal wash, heat dry" buttons does the door need to be opened because when I do this the dishwasher starts up with the door closed.-   wis_girl71
Best Solution
posted on Jun 02, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Part Number: 99002254 you may need this part depending on model no
SWTCH-DOOR View Larger Image
Solution #2
posted on Jan 21, 2008
Very Helpful)
StephenCar
Rank: Apprentice
Rating: 100%, 1 votes
Press and hold the "Auto Clean" button for 3 seconds and the press the "Drain Off" button. Hey, It worked for me.
Steve
Was this helpful?
Yes
No
Solution #3
posted on Nov 22, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Pressing [Normal Wash], [Heated Dry], [Normal Wash], [Heated Dry], [Normal Wash], [Heated Dry], [Drain Off] also cleared the flashing lights on model MDB9150.
Thanks for the tip. It saved me much aggravation.
This troubleshooting solution should have been in the manual in the first place. Boo Maytag!
Solution #4
posted on Jul 13, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
After you do that though, you have top press OFF (Drain Off) and then the lights will go out!!!
PERFECT SAVED ME SOME BUX!
Solution #5
posted on Feb 04, 2007
Helpful)
repman1
Rank: Master
Rating: 87%, 48 votes
try pressing normal wash, then heat dry normal wash then heat dry normal wash then heat dry. do it 3 times
Was this helpful?
Yes
No
Solution #6
posted on Aug 11, 2008
Very Helpful)
willyann61
Rank: Apprentice
Cannot get the water to pump in unless we use the hose that pumps the water out. please help!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #7
posted on Sep 21, 2008
Not Rated)
Beattitude
Rank: Apprentice
Rating: 0%, 0 votes
Look for the button with the 3 overlapping the Lock Oval. For me, it is the Heated Dry button. Hold that button in for 3 seconds to unlock it. You can also hold it in again for 3 seconds to unlock it.
ALSO THESE INSTRUCTIONS ARE ON THE INSIDE OF THE DOOR WHEN YOU CRACK IT OPEN
Was this helpful?
Yes
No
Popular Solutions for Maytag MDB9600A Jetclean II
Questions and Unsolved Problems for Maytag MDB9600A Jetclean II
Do you recommend Maytag MDB9600A Jetclean II Built-in Dishwasher?
Answer
Answer
I am looking for a dishwaser with a short cycle time. About a half hour or so. Are there any... (More)
Answer
Need to take apart the sprayer arm to get lime deposits scraped out. How do I do it
Answer
arms do not turn even though dw goes through water filling and emptying routine.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Maytag MDB9600A Jetclean II...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
