Question about Xerox Phaser 8560DN Laser Printer
LCD Panel replacement
I am going onsite to replace an LCD Panel on a Phaser 8560 and want to know if you would replace the entire control panel or just the LCD Panel. Can you provide instructions on how to do this?
Thanks!
Pat
    President:
  • 2,072 Answers
Did you contact Xerox concerning that ? That is a known problem and they will replace them for free. You replace the entire panel and the instructions come with it.
Just a pop out and pop in unit. But that is a known problem where they will send a replacement UI for no cost.
Posted on Dec 01, 2008
Display not working properly on printer panel. how do I reset the printer panel on my xerox phaser 8500
Unfortunately, the Phaser 8500/8550/8560 are known to have failures on the control panel. Xerox were replacing them free of charge at one point, but I don't think they do it anymore on the older models. There isn't a lot you can do once the panel has failed. If it is intermittent you could try going into 'System Setup', 'Control Panel Setup'. From here, turn down the brightness to zero and the contrast to 5. It was believed that overdriving of the lamps was causing the problem, but to be honest, I think if it has already started showing signs of failure, it will eventually fail altogether. If you can't justify replacing the panel at cost, it is worth remembering that you can see what the printer is doing from inside Centreware on your computer (networked machine only). Quite often, if your printer LED is flashing either red or amber, it is usually something simple like paper tray empty, ink sticks need refilling or wrong paper type selected. Centreware will tell you what these problems are or you can visually inspect the printer. Basically, if you don't replace the control panel, it is not the end of the world, you can still use the printer to its full functionality. Hope this helps.
Feb 06, 2011 | Xerox Office Equipment & Supplies
Control panel is blank even though power is on
Had experienced the same problem with a Phaser 8560DN, the only solution for that is to replace the panel. You can buy one off Ebay for $50: http://cgi.ebay.com/Xerox-Phaser-8500-8550-8560-LCD-Control-Panel-Display-/110649342908?pt=LH_DefaultDomain_0&hash=item19c336fbbc
Dec 18, 2010 | Xerox Phaser 8560DN Laser Printer
8560 DN Replace Maintenance Kit
the maintenance kit keeps your melted crayons from sticking to the roller. You know the smell... and no you need a new one.
Sep 15, 2009 | Xerox Phaser 8500/DN Printer
LCD blanked out on my 8560
check the contrast dial on the copier
Jun 24, 2009 | Xerox Phaser 8560MFP Laser Printer
LCD screen blank on our Xerox 8560 Printer
You should replace the control panel yourself 802K93650. It's a 5 minute job.
-Whit :)
Xerox phaser 8560 close control panel error
Bad control panel. Xerox will replace for free (800 635 8100) call and ***** to get it for free (They had a "LOT" of defective panels)
User installable.
Jun 14, 2009 | Xerox Phaser 8560DN Laser Printer
P/N FOR pHASER 8560 DISPLAY PANEL
P/N for Phaser 8560 printer is 802K93650
Apr 21, 2009 | Xerox Phaser 8560DN Laser Printer
Phaser 8560 LED panel has no indication, although it appears lit
Contact Xerox @ 1 800 835 6100 and once you get to a person on the prompts. tell them your serial number and inform them your control panel is not working. They will send out a new one free of charge.
Dec 23, 2008 | Xerox Phaser 8560DN Laser Printer
Phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
Jul 11, 2008 | Xerox Office Equipment & Supplies
Xerox Phaser  8560DN Laser Printer Logo
183 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
