Question about Kenwood KDC-C717 10-Disc CD Changer
Can't eject cd magazine - E-99 error message
I can't eject the cd magazine from the cd autochanger Kenwood KDC-C717 (car radio model is KRC-758R). I get an E-99 error message and when I try to eject the cd magazine I only hear a noise but nothing happens.
Thanks
    New Friend:
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Posted on Aug 25, 2009
Try turning on the head unit and holding the on/off button for 6 seconds, worked for me!
Posted on Dec 26, 2008
Kenwood 6 disc cd changer
screw needs to be replaced and making sure the bracket it not bent... thus , not allowing the cartridge to come out,,,
May 12, 2014 | Kenwood KDC-C465 6-Disc CD Changer
Need to get the security code for Kenwood KDC-608OR
ok I just found this info online and they say it came from the service manual for that stereo so I hope it helps:
You will need a Kenwood RC-410 remote control. This remote works on KDC-519, KDC-X859, KDC-319, KDC-4019, KDC-MP919, KDC-X759, KDC-419, KDC-X459, KDC-MPV619, KDC-MPV7019, KDC-2022, KDC-2022V, KRC-435, KRC-535 and KDC-X959
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Above information source = http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Jun 19, 2011 | Kenwood Car Audio & Video
My eurovox radio/cd/tape player displays error message E-99 when i switch to cd
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
Oct 03, 2009 | Car Audio & Video
When I select the CD mode on the setup, Error 99 appears. there is nothing wrong with CD's inserted in the changer
The loader can not load the cd's due to a worn out plastic gear. The plastic gear drives the loader and locks it in place. Have a qualified person check it out and replace the gear.
Gerald,
Kenya
May 10, 2009 | Kenwood KDC-C717 10-Disc CD Changer
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
Need a wiring schematic KDC C717
Black typically goes to ground.
Red goes to battery (+) (+ all the time)
Yellow typically goes to switched power (+ when ignition in run position)
Mar 06, 2009 | Kenwood KDC-C717 10-Disc CD Changer
Kenwood KDC-C717 - E-99 error
Reset the unit ithe reset button is on the cd changer
Dec 01, 2008 | Kenwood KDC-MP205 CD Player
Car cd changer
yes. open it up and find the small motor that performs the eject process. Then turn it by hand to eject the magazine.
Jun 13, 2007 | Kenwood KAC-729S Car Audio Amplifier
Kenwood KDC-C717 10-Disc CD Changer Logo
1,754 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
