Question about Samsung ML 2010 Laser Printer
Printer not printing
Problem with setup of printer. Test doc worked but no applictions with print. Message says, "printer stopped" - I have a iMac OSX. I have reinstalled everything many times. Thanks for your help. Artma
  • 2 more comments
  • martha crepeau Jan 27, 2007
    Yes, thanks for your help but I did try all that before. It does the test print but all the jobs are stopped from the applications. I have just switched from a PC to the iMac, so thought there is something about the iMac that is confusing to a PC'er.
  • martha crepeau Jan 30, 2007
    Thanks for your help. I did remove and reinstall the driver (after checking for any updates) and unplugged and all but it still won't behave. I will see if they will check it out at the shop in town, perchance equiptment is faulty. artma
  • cvc4 Jun 21, 2008
    I have the same problem as listed above. Have there been any solutions.
  • Anonymous Jul 14, 2008
    the printer does not print. I have checked cables,try to print again but to no avail.
DOES NOT PRINT SAYING THERE IS PROBLEM WITH SET UP.
Posted on Jul 14, 2008
  • 102 Answers
Remove driver, reboot, reinstall driver again, unplug printer then re-plug it again... check if there is any resource using the printer (just in case)
Posted on Jan 27, 2007
I have a iMac G5 with 10.4.1. I try to print coupons on my hp laserjet 1320 and they stay in the que. Word docs print fine but any time i try to print any kind of coupon from any site, it messes up the...
If you are printing PDF coupons, that is probably the case, you need to upgrade the memory on the printer if you want faster printing on those types of documents.
Mar 22, 2011 | HP LaserJet 1320 Printer
My HP stops printing after accessing any type of webmail or online study courses,e tc. I can send a doc to print and the printer works but it prints blank pages. The ink cartridges are fine.
Step 1:-
First of all go to the printer--> Press setup button on it --> use the Arrow keys --> choose the tools option --> now choose the option Print a test page--> If the test page prints fine--> The printer is fine. No problem in the printer.
Else take out the cartridges and clean it with a lint free cloth. ( Remember when cleaning the cartridges DO not touch the nozzel of the cartridge. Just clean the out side of the cartridge nozzel.)
Step 2:-
Try to change the color of the font on the document you are printing and then try printing. You will get to know if it is actually printing or not. If it is not printing in color also then try this ...!
Click on start--> go to control panel--> go to printers and faxes or printers option and then right click on the printer and choose properties option. Click on the print a test page button.--> Check if it works.
Let me know if it works..!
May 07, 2010 | HP Officejet 7210 All-In-One InkJet...
HP CM1312 on small office network.
do you have a printer server setup in the network,if so try restarting the server when it happens and see if the prints will print, check with your network administrator, the printer spooler might be at fault, also try adding more memory to the printer.
Mar 25, 2010 | HP LaserJet CM1312 All-In-One Printer
HP Laserjet won't print with iMac
It might be a case of the printer software you have may not be compatible with the version of the operating system on your new iMac. Check http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00341096/c00341096.pdf for information.
Jul 26, 2009 | HP Office Equipment & Supplies
I have a Epson TM-U220 Printer. The status reads: Not Available. If I print a test page it goes to the que but does not print.
If you can browse your printer, then try to delete the printer queue and re-add it. You do this from your Mac's System Preferences, Print and Fax application.
The C6180 is connected through a wired network. Funny thing is that I can print a test page....but when I go to print the document never leaves the print queue.
I get the following message from the print queue....the retry goes from 5 seconds to 10 seconds through 30 seconds but stops at 30 seconds.
you could try to get into your system setup to check whether USB ports are disabled by default (you will probably see during system startup a brief message saying something like "Press F2 to run system setup", or perhaps some other key like F1, ESC, etc.) When you see your docs in the print queue, do you see some error/warning message associated to that job? You could make right button click on that job and see its properties. You could check whether you should restart that job or whatever else option you may find there.
As for the installation CD, you could investigate on that disk to see whether there exists a file with whatever name ended in ".PPD" (without quotes). You could use that file: in System => Admin => Printers, see the properties of the corresponding printer and then use the option "Change driver". You will be asked for your printer model or provide a .PPD file. Use the one you found in your installation CD.
Jul 04, 2009 | Office Equipment & Supplies
Printer will not print
does it print a test page from the computer or from the setup on the printer itself.
make sure your USB cord is ok, connected to a functioning USB port.
make sure you have installed the right drivers for the right operating system, XP , Vista, 32 bit , 64 bit, anything makes a difference.
Mar 26, 2009 | HP Office Equipment & Supplies
Brother 2140 Printer Problem
It is most likly not linked to word. Word is likly sending the prints to the wrong, obsloete or wrong copy of the printer.
When printing check to see where the doc is being sent to print.
Then go to printers to see which printer is your 2140 active and ofcourse do a test print. If the test print is good this is the correct link to your printer.
Dec 19, 2008 | Brother HL 2140 Laser Printer
Printer queue is full
This problem seems to be related to USB printers and print queue issues are very common in Mac OS computers and Windows 2000 PCs.
You don't say if you are using a USB connector, but they're pretty common these days. You also don't say if you're using a Mac or PC, but most people use PCs. I did find a solution for this issue that says it's related to Windows 2000 and a USB printer, but may apply to other operating system platforms:
Print Jobs are Stuck in the Print Queue
The first step to this solution is to download and install an HP diagnostic software utility. There's a separate page at HP that describes the utility and lets you download it:
HP Printing and Diagnostic Utility
I didn't find any information that specifically said that you "can" print a test page but "can't" print a document.
Another reason why you might be able to print a test page but not a document isn't related to the printer but the application that created the document. If you are having trouble with Word or Excel or whatever office application you used to create the doc, it might not print. That's why it is helpful to try to print a variety of different docs, created with different apps.
It could also be the individual document. Occasionally, a document becomes corrupted and while you may be able to open it (and sometimes you can't do even that), it doesn't print. If you haven't tried printing more than one document, you can test this by creating another doc in the same app and seeing if it'll print.
Try doing test prints with different docs and then with docs created in different apps. If those work, it's doc/app related. If they don't, try the links I suggested above.
Good luck.
Sep 21, 2008 | HP Officejet 5610 All-In-One InkJet...
Brother MFC6800 not printing
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Nov 20, 2007 | Brother MFC 6800 All-In-One Laser Printer
Samsung ML 2010 Laser Printer Logo
61 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
