Question about Dishwashers
Bosch smu 7000 series dishwasher. On/Off button stuck. Was fixed 2 years ago. Same problem again now. How do I open panel to fix?
I sprayed some WD40 around the buttons. Lossened them and they now work OK.
Posted on Aug 25, 2009
Bosch dishwasher is not filling with water and detergent is not being released.
The soap wont come out if there is no water. Does the detergent flap open? If so, the dispenser is OK. If not, you need a new dispenser. If the machine is not filling, check the pressure switch and or the tubes that go to the pressure switch, they may be blocked, tricking the machine into thinking its already full of water.
Feb 27, 2015 | Bosch Dishwashers
How do i run a test / diagnostic mode for the bosch sge63e05uc (evolution series) dishwasher?
Are the instructions on how to run the diagnostic test listed in the manual? FYI, I couldn't run the test on my Bosch DW because it was just too broken. Over the years the dishwasher essentially fried its own circuit board with excessive heat, which I learned is a problem common to Bosch DW's. Bosch told me the lifespan of my model was 10 years; mine was 11 years old (but was repaired once or twice). I replaced it with a Miele; no problems yet after 4 1/2 months.
May 22, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
Hi, we have a Bosch SHU53EO6UC/14 dishwasher. It is getting stuck in wash and isn't advancing. We think it may be the timer but there are lots of references to running a test program. Unfortunately...
My Bosch DW SHU5302 also got stuck during a cycle and ran and ran. Turns out this is a known problem with these DW's. The problem is that a trace on the main board burns off that controls the heater. If the heater doesn't come on then the DW keeps running waiting for the water to heat up. Re-soldering this trace fixes this problem. If you get a repair guy out, he will only change the board. They are not allowed to re-solder which doesn't fix the problem for long as the same trace will burn off. Did this about 8 years ago and it is still fine.
Aug 29, 2011 | Bosch 24 in. SHU53 Built-in Dishwasher
My Bosch smu 3036 will not turn on. The ON/Off button compresses but does not turn red and nothing happens. I have tried turning the dial around again, but the button will not do anything.
I have the same problem on my Bosch SMU3036 dishwasher. I have determined that the problem is likely a failed contact on the on-off selector switch part (it's the module that contains those 4 mechanical buttons). I believe that the main contact is still working and that the failed contact simply connect all components to neutral. The proper fix would be to replace the entire on/off switch 4-button module. A cheap fix would be to have a handy person install a jumper from any brown wire to the neutral wire (white) where the power connects. I believe the only side effect is that you'll never see the orange ON indication when the dishwasher is running. The on/off switch should still work.
Dec 04, 2010 | Audiovox Bosch 718 World Cellular Phone
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
Bosch SMU7052UC gets stuck in wash cycle. Pressing alot of buttons, on/off, I can move it to rinse where it sticks again. No drying either. Any suggestions?
I have a 10 year old Bosch SMU 7000 and the drying function has ceased. Dishes are wet after all cycles. From what Ive read this isn't worth fixing because Bosch are so difficult to get into.
Jan 23, 2010 | Bosch 24 in. SMU70 Built-in Dishwasher
Cycle doesnt stop
STUCK TIMER MANUALLY ADVANCE TIMER THEY HAVE NOT MADE THE SMU MACHINE FOR OVER 12 YRS MIGHT BE TIME TO REPLACE MACHINE OR GET A QUALIFIED TECH TO LOOK AT
Jul 20, 2009 | Bosch Dishwashers
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Machine cycle stuck on drain
check to see if there is water in the bottom by the water valve and pump.
Jan 07, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
579 people viewed this question
Top Dishwashers Experts
