Question about Kenmore Elite HE4 Electric Dryer
Dryer won't start when press button. If you hold it, it runs.
When I hold the button, it will run....but if you don't hold it, it doesn't run. We replaced the computer board, and it didn't help. Any thoughts?
  • 3 more comments
  • mdhaines Dec 11, 2008
    Actually, that is what the guy at the shop said. He was 90% sure that was the problem and we replaced it. It worked for about 5 minutes. Than the switch wouldn't stay on again unless we held it (or put something heavy on it to hold it down which is what we are doing now.) It heats fine...it's just the switch. The model number is 110.64982300 Kenmore electric dryer. Any other thoughts?
  • Anonymous Dec 13, 2008
    Our 15 year old Kenmore elite electric dryer has been doing the same thing- last night it would only stay on if you held it, now this morning, it works fine
    It seems like it may be the protection overheating as it seemend very hot last nbight-- I also noticed the outside vent was blocked by link against a screen
    Should I replace or see if it goes on another few years?
  • macdonaj Dec 21, 2008
    I seem to have the same problem, but it's not this exact dryer. It's a Kenmore (110.C60952990). I hold the start button and it runs ... let go of the start button and it stops.
  • mikeanddeedi Jan 28, 2009
    same exact problem, and same exact dryer, only when I held the button,the dryer did not get hot, just cold air. My cmputer board seems to have been "burned" by a bad resistor...there are burnt marks by one of the resistors
  • ray-d-man Mar 05, 2009
    Kenmore dryer by sears..110.....Replaced the thermal switch yesterday and it's gone again.... It appears its bypassing the first cut off switch which is for 250f.... what the solution?
    Guru:
  • 462 Answers
The problem could be the centrifugal switch in the motor. In the normal operation this switch is open when off and closes after the motor reaches 80% or better running speed. The "start" switch is a momentary switch. and the centrifugal switch is parallel to the momentary switch. After the motor centrifugal switch is made it continues to run until the door, timer, or a safety switch opens the circuit. Now all this is assuming there isn't something different in your circuitry but it is a basics of how it starts and runs.
The reason for the centrifugal switch is that it also allows the power from one side of the circuit to proceed to the motor and elements. If your using the start switch instead all this power has to transfer from these contacts to the rest of the circuits. they are most likely rated a few amps under the centrifugal start switch and could burn out the start switch on top
Hope this helps everyone please rate me accordingly and GOOD LUCK!
Posted on Mar 10, 2009
  • rebecca bishop Nov 11, 2013
    can someone tell me where to buy just the centrifugal switch now that i have figured out the problem?
    Sergeant:
    Champion:
  • 291 Answers
Sound like your even heat board has gone out / send me the complete model number from the panel inside the door and i will see if i can help out / larryyb
Posted on Dec 05, 2008
2 Suggested Answers
  • 146 Answers
SOURCE: dryer shuts off.
Did you get this fixed? If not can you hear the timer motor still humming? I'll need to know a bit more to help. Sorry it took so long to get back to you I have been sick for the past few months.
Posted on Sep 06, 2008
Aeq6700fso dryer dryness button won't change the
E68 is a stuck button on th control panel
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 06, 2012 | Dryers
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore 70 Series Dryer won't turn on. I don't think it is a door switch problem because when I hold down the door switch to make the dryer light turn off, the dryer still won't start. I...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 19, 2011 | Kenmore Dryers
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
DRYER CHIRPS WHEN IT'S OFF, LEDS DON'T GO OFF, PUSH THE START BUTTON IT DOESN'T START
heatman101
Aug 13, 2011 | Maytag Neptune MDG6800 Gas Dryer
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
My dryer won,t start. When you set the timer and turned the starter on you hear a sound that seems it will run but when you let go the starter it just won/t run
You have a bad motor. There should be a button you can press to make your dryer go while the door is open. Hold that and push the button in and then turn the drum. if that doesn't make it go then it is your motor
Apr 18, 2011 | Frigidaire Dryers
Press start button and dryshuts off when start button is released
There is a switch assembly on the motor that activates when the motor is running. Centrifugal switch. It keeps it running when you release the switch. That is where to start. Eric
Jun 11, 2009 | Kenmore 74992 Gas Dryer
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Sep 14, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 73954 : Only runs when the START button is continuously pressed
The start button starts the motor heater and energizes a relay that latches closed to keep the motor and heater running untill the timer switch or door switch cut the power to the relay and the relay opens.
The latching relay has failed or disconnected
if all the cables are attached to the relay
replace relay
not an expensive item, usualoly good for 10years
dryer circuits look like this, the start switch and relay are drawn just to the right of the motor, this diagram has no relevance to the physical position of the parts
Aug 22, 2008 | Kenmore 63942 Dryer
Kenmore Elite HE4 Electric Dryer Logo
391 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
