I just bought a new Ampeg 200 r Bass Amp and am having a lot of feedback and clicking noises when adjusting controls on my Bass. I am playing a Traben Chaos and have had no previos problems running it through a house PA and a Peavey Data Bass Amp. Is this a problem with the amp?
    Sergeant:
  • 217 Answers
As u said the device is new it is advisable to get it replaced because the other device which you have been connecting have no such problems.just get the amp replaced.
Posted on Dec 01, 2008
  • 19,396 Answers
THERE SHOULD BE NO NOISE WHE YOU ADJUST SOUND, THIS CAN BE CAUSED BY A FAULTY COMPONENT (EG. A CAP THAT HAS BLOWN)IN THE AMP FINAL.
  • 6,487 Answers
That is an indication that the AMP has some problem inside it since this is a new device better if you have it replace....
Where can I get a user's manual for an Ampeg SB-12 Portaflex bass amp?
Contact trhe Ampeg Service Department at 800-898-3211 for a hard copy.
Sep 30, 2014 | Music
My rumble 30 bass amp makes a lot of bad noise when i plug it in. it started off when i first started playing it and it worked fine, then after a few minutes it started making the noise. i've tried...
How new is the amp?
A single faulty solder can do that...I'd try returning in to the seller.
Have you tried a different amp with the same equipment?
Sounds like a wiring issue.
Hope I've helped
PvT
Sep 25, 2011 | Fender Rumble 30 30watt Bass Guitar Combo...
While playing, the power cord was accidentally pulled out. When plugged back in, the amp cuts on, but there is no sound and the led lights for peak and tone selection flash.
You have probably blown a tube. This amp has one 12ax7 and one 12au7 in the vintage preamp. You can try replacing the preamp tubes, but it can be quite dangerous if you don't know what you're doing!
Sep 20, 2011 | Ampeg BA600-210 Bass Combo (with )
Power to my Ampeg BA-115 quit suddenly whilst playing. Back of amp was hot - there was a crackle immediately before it quit. I allowed it to cool down and then turned it on, but it was dead.
Here is your schematic. Likely the fried components are visible.
http://elektrotanya.com/ampeg_ba-115.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
When repairs have been done, start this up using a 100 or 150 watt incandescent lamp in series with the power cord to act as a fuse... There likely are several components blown and you may not get them all the first time. The lamp acts as a resettable current limiting fuse so you don''t blow out what you just replaced.
Aug 05, 2011 | Ampeg BA115 1x15' Bass Combo Amplifier
My ampeg BA115HP is dead. I suppose it is the fuse. Where is the fuse located?
it's the black thing sticking out of the circuit panel on the back of the amp
May 22, 2011 | Ampeg BA115HP 1x15' Bass Combo Amplifier
All the inputs on my ampeg bass amp are not working even the RCA input is not working. the amp still turns on
If none of the inputs work, then you may have lost part of the power supply. DO NOT go into this amp under any circumstances !!!!...there is enough voltage in here to kill you crispy !! I would strongly recommend that you take it to a respected repair shop that specializes in guitar amps. Possibly visit the ampeg website for an authorized repair center. It might cost a few bucks, but the Ampeg is highly sought after by musicians everywhere !!!....thanks... Rob
Sep 01, 2010 | Ampeg Classic Series Svtvr 300watt Tube...
Amp turning off
protection mode,,.amp getting hot? have you got your settings proper on amp.like not having the gain cranked? Is it drawing to much from your vehicle electrical.all possibilitys. make sure u have all wires connected correctly and tight.
Sep 20, 2009 | 3Com SuperStack II advanced RPS...
My subwoofer on my philips 5.1 speaker system is constantly generating lots of bass noise even on mute.
I assume you are using XP. Try these steps.
1. Open 'Sound and Audio devices' in Control Panel.
4. Start playing a sound.
5. Set the volume control of the subwoofer to the middle position.
6. Open volume control and adjust Master volume to a comfortable level (i.e. until there is no hum).
Also make sure you haven't muted any sound device except microphone. I think your problem is you have set it to the maximum level. So decrease it.
7. Mute the sound and check.
Good luck! Let us know the result.
Jul 07, 2009 | Audio Players & Recorders
Popping noise while computer is powering down. Any suggestions?
Lower your main sound volume. Double click the speaker icon in the bottom right hand corner of your windows.(was it maxed out?)
go into control panel /sounds and select a lower bass setting in your sound settings. You usually have a choice of rock & roll ( lots of bass) opera setting, classical etc.. choose one with less bass.
Make sure your LINE IN is DISABLED. It may be causing this static feedback.
You may have blown your speakers by playing sound way too loud. You may need to buy new speakers.
Thank you and Good luck. *s*
Oct 24, 2008 | EliteGroup P4M800PRO-M478 Motherboard
Quick question, amp problem
make sure you ground wires arent shared, meaning run each ground wire from each amp to its own grounding point
Sep 08, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
26 people viewed this question
 Grubhead
Grubhead
