Question about HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 "Doesn't turn ON"
I'm having trouble with my Hp/Compact Presario V2000. When I went back to work on it after 3 weeks, It kept shutting down on me (mostly when I moved the whole laptop). However the fan was working and the laptop was plugged in to the power. I had to take the battery out and tried to turn it back on. It worked for a few times. The problem now is that it doesn't turn ON at all even when it is plugged to the power. I appreciate if anyone can help me with that. Thanks Ava
  • Anonymous Jan 15, 2008
    after returing from my holiday i found that on that notting is been seen on screan.
1) Unplug the laptop. 2) Press and hold down the standby switch under the lid in the upper left hand side of the laptop while pressing down the power key. You should have full power startup now. Let me know if it worked..
Posted on Jan 31, 2007
SOURCE:
I was able to connect to my HP Compaq Presario V2000 Laptop to my WiFi Network using NetGear. When I reconfigured the network I could connect to all other network like Dell Lptop , Nokia Smart Phone and HP...
Hi!
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Bogdan
Sep 25, 2011 | HP Compaq Presario V2000 Notebook
My hp laptop model is compact presario v2000
If you are looking for the device drivers for your Compaq then -
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Apr 14, 2011 | HP Compaq Presario V2000 Notebook
I want to download audio output driver of windows vista for compact presario2000
There are 3 models of hp that starts with Compaq Presario V2000 PC Notebook, they are
» Compaq Presario V2000 CTO Notebook PC
» Compaq Presario V2000T CTO Notebook PC
» Compaq Presario V2000Z CTO Notebook PC
Go to the below link and select your laptop model from the 3
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=Compaq+Presario+V2000+PC+Notebook&submit=Go+%BB
Click the correct link of your computer, in the next page select dyour operating system that is windows vista, if there is no vista there then the driver for vista is not released by hp,if i am right there are drivers for 2nd and 3rd but not the first.
After selecting the operating system click next and select the link to driver-audio and click download
Jun 25, 2010 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 won't power up!
you may, and i say MAY have accidentally dislodged the battery, remove it competely and reseat it.
unplug the power unet and reinsert all its cables to make sure nothing it loose.
try starting the laptop with battery removed but mains power plugged in.. (if this works : you got a faulty battery...aftermarket HP part suppliers or HP on the net..
anything else is serious and then i pray you got a warranty or insurance....
Dec 08, 2008 | HP Compaq Presario V2000 Notebook
Drivers for HP Compaq Presario V2000 laptop
Directtly from the HP site www.hp.com
Just click on the drivers and download links.
Aug 06, 2008 | HP Compaq Presario V2000 Notebook
Compaq presario v2000 sound
If you could give much more detail on your model.See below your laptop you should have like 2102tu or something like this..
then go up to here..
http://www.hp.com/#Support
and put your model to download the driver.
goodluck,takecare.
May 04, 2008 | Computers & Internet
link to v2000 CTO
link to V2000 support page, you select which series, click on it then select which operating system you are using.
Apr 07, 2008 | HP Compaq Presario V2000 Notebook
I cant Install Modem and other divices for my Laptop
did you formatted the hard disk? this depends on your OS. what are you using? it is important that the driver you downloaded and installed is for the OS you are using.
Apr 02, 2008 | HP Compaq Presario V2000 Notebook
pls send compaq notebook presario v2000 audio driver
Jan 08, 2008 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
239 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
