Question about Maytag MDB9600A Jetclean II Built-in Dishwasher
No-spin Top arm will not spin when others will.
  • 4 Answers
The spinning of the arms is created by the force of the water shooting out of the holes. your top arm may have debris build up in it that prevents proper water flow. u can also remove the arm and see it there is build up on the contact point were it rotates. clean it if its dirty. "dishwasher magic" is good for cleaning mineral build up in your system. also, make sure your not putting dishes on the top rack that are too tall and prevent the blade from rotating
Posted on Feb 22, 2009
Dishes in top not clean- arm in top does not spin
Hello bue.... The top arm spins due to water pressure. pull your top drawer out and inspect the rubber tube that feeds water to the top arm. Usually they have a split in them so the water does not get to the arm to spin it. The fix is to replace that rubber tube. You will need the model number of your machine to order the correct part. I usually get my dishwasher parts from searspartsdirect.com
Joe
Thanks for choosing Fixya!
Jan 30, 2011 | KitchenAid Dishwashers
The upper arm is free spinning by hand, but from all indications, it is not spinning. Water is flowing freely and drain is excellent. Is the upper arm problem a major repair.
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are oopen. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and youl'll need a Torx driver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Jan 01, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
Whirlpool DU1301XTV dishwasher - the top rack started cleaning woefully a few months ago. The bottom seems OK. I checked wash arm action by starting the washer and opening the door several times. The...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Nov 04, 2010 | Whirlpool DU1301XTV Builtin Dishwasher
My top shelve sprayer arm does not spin
its just clipped over the cap remove and clean also check the seal is not damages on the pipe that goes into case.
Jun 18, 2017 | KitchenAid 24 in. KUDI02IRBS Stainless...
Spin cycle not working properly
On the transmission there are two shift arms. One shift arm controls the agitator and the other shifts to spin the cloths. If the washer has been making a "clicking" sound when it trys to spin, the solenoid that shifts the spin shift arm is not catching and the drum will not spin. The other possibility is the spin clutch is slipping and make a "grinding/ratcheting" sound. Neither, unfortunately are inexpensive to fix.
If you can describe the sound and when it occurs, I might be able to get closer.
Let me know.
Regards,
May 15, 2009 | Maytag Ensignia MAV4757AWW Top Load Washer
Figidare dishwasher
It seems other posts were correct - The upper arm doesn't spin all the time. Once I learned that, and let the dishwasher cycle through, I saw that the upper arm does spin. So, there wasn't a problem with the upper arm afterall. That doesn't solve my crusty dishes problem, but that may have something to do with the soap we're using. We're going to try changing that next.
Dec 27, 2008 | Dishwashers
GE Triton arms don't spin
Peace,
Cut off the power at the breaker for 5 minutes and then turn it on and see if the system resets!
How old is the machine?
Other wise you need hands on service! And a new machine will pay for itself in only a few years!
Bless You!
Sep 06, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Top rack remains dirty
spin the top rotary arm to make sure it spins freely also take it off to see if its blocked (run it under tap) check all other filters too and when you load dishes make sure they do not obstuct top rotary arm if none of this works then it's time for an engineer im affraid good luck
Jan 26, 2008 | KitchenAid 24 in. KUDK02CR Built-in...
TUW model - not cleaning fully, top sprayer does not spin
make sure the wash arm holes arent obstructed and the wash arm seams arent cracked.
Sep 17, 2007 | Champion 24 in. UH-150B Built-in...
Maytag MDB9600A Jetclean II Built-in Dishwasher Logo
266 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
