Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My machine quits working during the rince cycle
My machine begins filling and washing normally. However, when it hits the rinse cycle, the water quits filling after a few seconds. I can hear the buzz the washer makes, so I know it is getting electricity, but no water is filling.
  • mgilman Dec 01, 2008
    I figured out the problem. I read somewhere that the washer uses just cold water in the rince cycle. I pulled off the cold water supply and it was totally blocked. I tried it again and it didn't work. I remembered that a my husband was working on plumbing last night and found that he didn't turn on the cold water supply to the washer. Problem solved.
  • 103 Answers
The safety switch could be the culprit on this because anytime you open the door on top it triggers which turns it all off. so what i would start with is either bypassing that switch or replacing it.
Posted on Aug 15, 2009
Maytag ensignia makes a great deal of noise during rinse cycle
"If you dont have a noisy spin cycle and the noise you hear is only on the rince cycle, dont be worried, as this is totally normal. Water sprays onto the drum while the spin cycle is in progress and rewets the clothes to allow any existing soap to be desolved. This noise is in effect the water hitting the drum during the rince part of the cycle.
Sep 03, 2010 | Maytag Ensignia 3.3 cu. ft. Top Load...
Water will not fill during rinse cycle water just keeps runningg?
That is quite normal. When the rince cycle is on, it sprays water into the tub while spinning. In that way, it removes small traces of residule soap still on the clothes.Of course it should stop once the spin cycle is finnished.
Aug 20, 2010 | Maytag MTW5600TQ Top Load Washer
I have a Miele W1918 washer which has worked perfectly for a decade. Now there is not enough water to fill the tub during the first 'rinse' phase of normal cycles or the 'separate rinse' cycle. The machine...
I have exactly the same problem. I am currently getting around the issue by letting the machine do the washing then at the end of that cycle do a manual rinse cycle.
Jun 04, 2010 | Miele Novotronic W1918A Front Load Washer
The cold water keeps running in the rinse cycle. it nrver fills up it drains out as it flows in
you kind of lost me with that one, but the washer should spray in cold water when in the rince cycle , spining , draining, and spray of cold water. Thats a normal rince.
Dec 12, 2009 | Whirlpool LSQ9600L Top Load Washer
Water pressure for Washer (rinse only)
you nead to turn off both cold and hot you nead to remove cold water hose from washer.remove screen and clean it and replace it.hookup cold water hose to washer and turn water back should have better pressure.your rince cycle is cold water.
Nov 18, 2009 | Kitchen Ranges
Washing machine will fill up with water for the rinse cycle and then it just shuts off.
if you dont have a soak fascility, then your board is the issue. There is no interlock during the rince cycle to inhibit the machine from running when full. Funny enough, when i find boards have gone faulty, it is often on the rince cycle.(various other brands).
Sep 15, 2009 | Kenmore Washing Machines
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
71 people viewed this question
Dan Webster
Dan Webster
Sal De
