Question about Denso Nippondenso BHT3000 (bht3041) Portable Terminal
Require some help
Scanner isn't powering up, have checked batteries, seem fine. Do you know where we can send it for repair? Thanks.
  • 53 Answers
Where are you located? there are service centers world wide. the best way is to talk to who you got the unit from and they can send it back to the distributer for repair.
Posted on Nov 21, 2007
Hello my name is Christopher I have a 96 Chevy K 1500 5.7. my fuel pump isn't turning on. I have a new relay. good pump and wiring seems intact.I tried an experiment( carb swap) and removed the pump...
check that the earth wire is making good contact , when ignition off the relay should have power to one prong , does it ? the brighter light on one prong than the other does point to a earth problem though, i presume you have checked the fuse board , as you know some fuses feed thing's not mentioned , worth a check , keep me posted if you wish
Nov 03, 2014 | 1996 Chevrolet K1500
I use Acer aspire 4315 laptop. The power button isn't working. When I press the power button nothing happen. So how can I turn on my laptop?
maybe you have already done this, but remember that many laptops require that you remove the battery for about 30sec. as well as disconnect the AC power to reset them. Always try to do this when everything seems completely dead.
Please let me know if it's working or not,and thanks for using fixya
Aug 10, 2012 | Acer Aspire One PC Notebook
My shuma 1.5 ls was running fine, then just wouldnt start. Push starts fine, went for a drive and it seems the battery isn't charging, its a newish battery, altenator and starter seems fine. Why?
Have the battery load tested to determine the health and it's ability to take and hold a charge...the alternator can be tested too. If they test fine check your clutch switch. Hope this helps.
Jul 11, 2011 | 2001 Kia Sephia
Last week I had spilt water on my phone but I got it in rice fast enough and it was working just fine. But when I tried to send a text message to my friend a couple days ago it locked up now whenever I try...
Rarely does a phone return to "normal" after a bath with the power on. You did good putting it in the rice and removing the battery as quick as you could ... Still, few phones are the same after a power on bath. Verizon isn't just trying to sell you a new phone - they know what they are talking about in this case. You will have to replace the phone or have yours professionally repaired, if you can find a place to repair it for you.
The simple fix: Replace it. Nice as your Chocolate is, it is yesterday's technology + it is not working.
Thanks for your question @ FixYa.com
Apr 16, 2011 | LG CHOCOLATE VX8500 Cellular Phone
Scanner was working fine this morning. Now when I try to scan from my PC I get the Message "cannot communicat with scanner for these reasons: scanner is turned off, scanner is disconnected (it is...
Check the scanning unit by copying something on the platen. If this does not work, you have a defective scanning system. If it does work, check connections between the PC and the MX870.
Please let me know if this works. If not we can investigate further. Thanks.
Feb 24, 2011 | Canon PIXMA MX870 Wireless Office...
When attempting to start my car, there is a clicking noise. The battery seems to be fine, air comes on, radio and lights power on. Any suggestions? of coarse i will not start. I'm a single female with no...
You have a solenoid on your starter. The solenoid is what you most likely hear clicking. The battery seems to be fine from your info. The starter can be repaired with a new solenoid. It really depends on who you go to and what the charge is to repair. The battery sends power to the solenoid, the solenoid kicks power to the starter to turn the starter for your engine to start. Good Luck
May 07, 2010 | 1996 Toyota Corolla
HP Officejet Pro L7680 All in One - cannot send faxes - keeps jamming and says "scanner failure unable to scan copy or send a fax. Turn the power off and on and try again" I have done this several times...
The scanner is the problem, the scanner is the real bright light that comes on to scan the orginal document. Does your Scanner lamp come on? mite be burned out? stating scanner failure, doses your scanner move when it scannes the document? Motor or cicruit board that control scanner mite be bad, check the scanner "Home " position sensor maybe the scanner board and main board don't know where the scanner is phyiscal when it goes thur its routine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 08, 2009 | Office Equipment & Supplies
Bose Cinemate Home Theater
Hello everyone! The Bose interface module is working again. All I did was unplug the power, wait about a minute and then plugged it back in. Whatever it did, it must have reset itself, so now everything is fine.
Nov 18, 2007 | Bose Cinemate Digital Home Theater System...
Copy Button
have you checked the settings for virtual memory? Increase the maximum limit (may require reboot) and retry the scanner. Let me know.
Aug 23, 2007 | Canon CanoScan D1250U2F Flatbed Scanner
Denso Nippondenso BHT3000 (bht3041) Portable Terminal Logo
103 people viewed this question
Top Denso Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Denso Computer and Internet Expert? Answer questions, earn points and help others
