VAIO VGN-FS 770W wont turn on
I shut the computer down and went to turn it on 5 minutes later and it wouldnt turn on.... Battery was charged and the power supply works so i am stuck without an answer
  • luke5446 Dec 01, 2008
    no... didnt work.... it wont boot with or without the battery
  • Anonymous Dec 14, 2008
    I have the same problem. Although, it did turn on after a couple of hours and I thought the problem went a way but it failed again when I wanted to turn it on again. The three lock leds stay shining, which is not normal and nothing happens on the screen but the power, wifi, disc leds are all on.
  • 111 Answers
Try to remove the AC power and then the battery. then plug in the power without the battery. Turn-on the Laptop if it starts then slowly put the battery back after it boots in windows. Check if the battery is charging.
Hope this helps.
Posted on Dec 01, 2008
2006 chevy colorado out of the blue will not start. just makes clicking sound. Started it drove out of garage shut it off. Went back out 5 minutes later won't start. Clock even reset.
Sounds like a bad battery. A number of chain auto parts stores will check it and your charging system free. Before that, if your battery has removable caps, check the water level, if it's down, fill to the bottom of the fill rings and charge the battery, if you have a battery hydrometer, all the cells should have about the same charge level, if one or more show a lot lower than the others, battery is probably bad. Hope this helps.
Jul 29, 2012 | 2006 Chevrolet Colorado
My Sony VGN-CR590 shuts down after 5-10 minutes. How can this be fixed? I'm not sure the fans are running.
A way to check to see if the machine is overheating is when you turn on the computer, there should be an option to hit F10 or F2 for the bios. In there, there should be a few temperature readings. Let the machine idle and in the bios if the tempature rises in there there could be an issue with the cooling for the CPU.
Jul 11, 2012 | Sony VAIO VGN-CR590E PC Notebook
My sony vaio VGN-AW41ZF keeps turning off by itself. It doesnt shut down, just cuts off as if there is no power but the battery is fully charged and plugged in. Could this be an overheating problem?
I have a Sony VAIO GRS170/GRS175 in use almost every day since 2003. It used to turn off regularly during hot summer days even with its battery fully charged and plugged in. The problem was eliminated by using a small fan to blow air at its side where the air intake was located. Later, the fan was replaced with a notebook cooling pad which was more convenient. You could first try using a fan to see if it makes any difference. If you don't get anymore shut downs, then the problem is definitely due to overheating. You could then replace the fan with a notebook cooling pad.
Apr 14, 2011 | Sony VAIO FR130 Notebook
My vaio vgn-n250e sometimes will not cut on even when battery is charged and AC is plugged in. I actually havent used it in 2yrs thinking it was a battery problem, but yesterday (after 2yrs) i decided to...
I had a similar problem with another vaio turned out that the module that the power button is a part of (above the keyboard) had a bad wiring harness that connects it to the computers main board. After replacing the harness (looks like a tiny ribbon cable with 4 or 5 wires) the laptop was great again.
Aug 25, 2010 | Computers & Internet
My sony vaio VGN-FS980 PC Notebook wont shut down gets frozen at the windows is shuting down screen
yah i dont know waht your question is but try unplugging the power and taking out the battery or hold the power button down till it turns off
Apr 06, 2010 | Sony VAIO VGN-FS980 Notebook
I have a sony Vaio N250e. It powers up, boots up and get to the windows desktop. It will stay there for about 2 minutes then it just turns off on its own. I did notice that the battery light blinks twice....
Hi
Does this occur when charger is also plugged in?
If it does then sounds like the CPU vent ports are clogged and CPU may be overheating,
Turn laptop upside down and look at CPU vents, if clogged simply use vacuum cleaner to clear.
Aug 12, 2009 | Sony VAIO VGN-N250E/B Notebook
Sony vaio vgn fs 830 w
A quick search has revealled there is a 6 cell battery with higher amps than the original amperage at http://www.topmicrousa.com/sony-vaio-vgn-fs830-w-battery-6-cell-4400mah-black.html
Try this and check to see what amperage your battery is in the computer you have (The more amps in a battery usally means the longer it will last
Jan 10, 2009 | Sony VAIO VGN-FS830/W Notebook
Vaio power lead wont allow laptop on
Try turning it on without the battery.
Oct 27, 2008 | Sony Computers & Internet
Sony vaio VGN FS 570 no display
Try having your battery tested. There may be not enough power to run everything on your comp.
Anotherthing to consider, if your CPU fan isnt working the bios wont start the O.S. as the CPU will overheat and shut down automatically. Good Luck
Oct 14, 2008 | Computers & Internet
Computers & Internet Logo
258 people viewed this question
David Payne
David Payne
