Dropped my ipod in my pool and know it will not turn on. I have tried smothering it in rice and in a container for a couple of days but it is just DEAD, what can I do?
Either you dropped an Ipod or a PDA RX3115, but in both cases the device has water damage.
It requires to open it and check it to evaluate if it can be completely cleaned.
When the devices are wet and there is enough battery current, there is corrosion due to chemical reaction with copper, so sometimes the damage cannot be avoided, causing that the main board is completely damaged.
It requires some tools and experience to do it. If you are familiar with fixing electronics, you can try it. Otherwise, I do recommend you to get a technician in checking your device.
Im having same problem as bexta27783.I also cant access the music I download to my Nashi. I have a...
(More)
Im having same problem as bexta27783.I also cant access the music I download to my Nashi. I have a utilities disc and it doesn't work. What am I supposed to do with it?
My iPAQ rx 3115 will not turn on. I left it in my briefcase but now it just does not start. I did a...
(More)
My iPAQ rx 3115 will not turn on. I left it in my briefcase but now it just does not start. I did a reboot, the initial screen appeared, then it frozed and then it just went blank. The battery was fine but the iPAQ just won´t turn on. I returned home and immediately plugged the AC charger and nothing happened. Something similar happened a couple of weeks ago while I was outta my house and as soon as I returned home I plugged the AC charger and the LED that indicates "battery charging" started blinking, so it worked that time, but today it just does not work.
What can I do? I had a lot of stuff there that I need to access...urgently. Please help. Thanks a lot.
