Question about Microwave Ovens
My emerson MW8992RD the red metal one displays all zeros and the button will not work at all!
  • 3 more comments
  • lilsue2452 Dec 03, 2008
    I have had it for a year! I tried unplugging but it none of the button worked still!
  • lilsue2452 Dec 05, 2008
    maybe cleaner couldn have gotten in there but idk i live with a roommate so i really don't know but i have never done much more than wipe the controls done with a paper towlel!
  • William Miller
    William Miller May 11, 2010
    It sounds like the keypad or the control board has failed.
    Is it possible that some
    spray cleaner, steam or other liquid accidentally got into the controls?
  • William Miller
    The
    first thing I would suggest is a hard reset. Unplug the unit for a
    minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
    It may have a bad keypad.
    How long have you had it?
  • Anonymous Mar 26, 2014
    kenwood k20mss 10 displaying only three zeros instead of four when I turn this on?
  • Microwave Ovens Master
  • 9,098 Answers
The keypad may be damaged or worn out, or control unit may be damaged.
I would suggest that you contact Emerson. It may still be covered under warranty.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Posted on Dec 06, 2008
Microwave turntable stopped turning. Can I fix this?
The turntable motor will need to be replaced, this type of repair is tricky not to mention the lethal voltages it carries. I strongly recommend a professional for this job.
Jun 24, 2012 | Emerson Microwave Ovens
I have an Emerson MW8992RD model and just opening the door blows the fuse! any idea ,could it be a bad door switch? if so where can i purchase a new 1?
Definitely sounds like a defect or misadjusted door switch. This site has venders of M/W parts. FYI,Federal law requires a leakage test after door repair, magnetron replacement or interlock repair.
Jun 20, 2010 | Emerson MW8987B/W Microwave Oven
Need to replace the glass tray for Emerson Microwave Oven model #MW8992RD
Glass tray replacement for the Emerson Microwave MW8992RD has been discontinued.
Oct 06, 2009 | Emerson Microwave Ovens
Mw8992rd seems to be working fine except won't heat food. timer, touch pad, inside light, carousel all work fine. tried different times and power levels but still no heat.
This sounds like a bad magnetron that would have to be replaced. There is up to 2000 volts stored in a microwave, even when unplugged. For saftey reasons I would strongly suggest you have a qualified technician check it out.
Hope this helps.
Aug 24, 2009 | Emerson Microwave Ovens
Need a glass plate turntable for Model
Jun 11, 2009 | Microwave Ovens
The fuse blows when i plug the microwave in with the door closed
first you gotta detach the button plate ( the thing with all the buttons) using a flathead screwdriver .Keep pushing it is stuburn. It will pop back in when you are done. the fuse is behind that. just take it out and put the new one in.
Nov 16, 2008 | Microwave Ovens
Emerson MW8992RD Microwave Oven 2005
Power level 10 would be the default - what it is set to unless you manually set it lower.
Power level 0 (zero) is often the setting to use if you just want to use the oven as a timer.
Many Emerson microwave owner's manuals are available for free download here.
Would that answer your inquiry?
If not, please write back with more details.
Oct 16, 2008 | Microwave Ovens
Red Emerson Microwave, MW8992RD
Your manual is online here.
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
After that, and following the instructions, it still has a problem, please reply back with details of how it's failing.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Microwave Ovens
Microwave Ovens Logo
220 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
