Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Cross hairs I can not get my hairs to line up on my tp61h60 I do not have the remote either
    Scholar:
  • 142 Answers
Hello, You need 2 convergence ICs if you cannot converge the red and blue lines on top of the green "cross hair". You should be able to use the front panel controls to move the red and blue around. If you can move them around and they just won't move completely on top of the green then the ICs are bad. The ICs are mounted to large,finned heatsinks and have numbers that start with "STK-" and have numbers following. These parts are available from http:\\www.tritronicsinc.com.
Posted on Dec 01, 2008
Need tv remote Codes for Toshiba Remote Controler, tv Model Toshiba TP61H60
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts. Search the sites by type in the brand name to your device, in its search box. It will help you to find the document easily.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 25, 2014 | Toshiba Televison & Video
Need Remote Controler Codes for Toshiba Remote for Toshiba Model TP61H60 a 1998 Big Scrren
Your Toshiba remote should have the necessary codes to control your Toshiba TV unless one is much older than the other.
If your RCA remote is programmable, you can use its "code search" feature to find an applicable code or codes. If a complete search of all codes stored in your RCA remote fails to find a code, you may have to try another programmable remote or simply wait until the replacement Toshiba remote arrives.
Sep 25, 2014 | Televison & Video
How do I adjust the convergence properties on an RCA rear projection tv?
Normally on the RCA rear projection TV's you would bring up your menu and choose the Setup menu, then press OK on the remote. That menu would then have Convergence as a choice. Once that was chosen the next menu would give you the choice of either letting the TV run it's own Autoconvergence program, or you would select either Red or Blue convergence.
Choosing Red Convergence would bring up a Yellow cross-hair in the middle of the screen. If the Convergence was not correct you would see separate Green and Red cross-hairs. Once they were perfectly aligned you would again see one Yellow cross-hair.
Choosing Blue Convergence would bring up a Blue cross-hair in the center of the screen. If the alignment was out you would see 2 Blue cross-hairs. Using the Up and Down and Left and Right cursor keys you would adjust the alignment until a single solid Blue cross-hair was in the center of the screen.
May 15, 2011 | RCA Televison & Video
Im seeing duble words,how can i fix it?
There should be a convergence adjustment on this set. It will have a "cross hair" type pattern
You adjust the beams so that the cross hairs turn white. I believe Green is not adjustable intentionally. The procedure is to adjust the vertical Red line until it alligns with the Green line. Then adjust the vertical Blue line until it lines up with the Red and Green. The line should turn White.
Repeat the procedure for the horizontal lines. When you return to regular viewing mode the double
images should be greatly reduced or eliminated..
Hope I've helped you,
Best Regards,
Mark
Dec 30, 2010 | Panasonic Televison & Video
Blueish hue throughout picture, like a blue ghost a couple of inches to the right of objects on the screen
Your TV's Convergence may be out of line. To adjust this do the following.
1) Press the Menu button on your TV/Remote
2) Scroll through and select the "Advanced Features" Menu.
3) Select Blue Convergence
4) Use the V keys on your remote till the cross hairs are all lined up in the middle of the screen and the center one is white.
4a) You can use the "Video" button to switch between the red & blue cross hairs.
Dec 28, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Convergence line will not move to match cross hairs
the green line will not move. it is stationery and red and blue have to adjusted to it
Jul 20, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Convergence service mode
I don't know how to deal with the power settings part but the convergence service mode is "Mute, 1, 8, 3, power".
Jan 03, 2008 | Samsung PCN5425R 54" Rear Projection...
Multi point convergence
In the multi-point adjustment grid use the exit/status button on the remote to lock onto the cross-hair that you want to adjust and again exit/status button to continue back to moving the cross-hair around to another location.
Bill
Dec 01, 2007 | Philips 43P8341 43" Rear Projection...
Convergence
you have bad convergence ics
Apr 13, 2007 | Toshiba TP61H60 61" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
