Question about Canon Selphy CP510 Thermal Photo Printer
Unable to print.
Had a canon powershot a420 camera with selphycp510 printer for xmas,After using all the ink up i sent off for a new cartridge from inkjet .com and also purchased premium plus hp photo paper that is recommended for this printer.When trying to print off photos the screen on my camera is saying ink and paper no match?Thinking it could be a faulty new ink cartridge i sent that back and recieved another new one with the same fault showing on my camera screen.Any help please would be very appreciated.
NO-ONE REPLIED TO THIS THIS PROBLEM YET.Please someone should know something????
Posted on Mar 29, 2007
My Pixma MG5250 has run out of Cyan ink, how can i continue to print with just black ink?
With the canon single ink inkjet printers it is not possible to use only the black cartridges for printing. You will have to put a new cyan cartridge into the printer to continue printing.
Mar 06, 2014 | Canon Pixma Mg5250 Imageclass Inkjet Scan...
Need Canon Powershot A420 instruction manual
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Thanks for using FixYa.
Sep 27, 2011 | Canon PowerShot A420 Digital Camera
WHY WONT SANDISK SDHC WORK IN MY POWERSHOT A420
Your camera is designed to work with SD or MMC cards.
SD and SDHC cars look similar. But older cameras cannot recognize SDHC cards.
Use a SD card instead. (I know, the capacity is the problem!)
Sep 26, 2011 | Canon PowerShot A420 Digital Camera
How do i change an ink cartrige in a canon 160 printe
The Canon Pixma inkjet printer is an all-in-one printer, scanner and copier capable of printing high-resolution photos. One handy feature is a slot for a memory card so you print photographs directly from your camera. It can also print completely without any border for full-sheet photos. Printing photos and other high-fidelity documents uses up ink more quickly, and you will probably need to replace at least one of your cartridges every three to six months, a process that should take you about three to five minutes.
1.urn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
2.Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
3.Pull out the used ink cartridge by pulling straight up from the print head, and dispose of them safely and carefully by putting them in a sealed bag.
4.Remove gently any packaging from the new ink, after giving it a few shakes. Pull off the protective tab on the cartridge, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
5.Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
Sep 06, 2011 | Canon PIXMA MP160 All-In-One InkJet...
All my ink cartridges are full, yet anything that needs black ink that is sent from the computer doesn't work. It feeds through and prints everything else but black even with new full cartridges. It copies...
You might try changing preferences in control panel. The defualt for most photo printers is color since that is the most used feature (and sells the most expensive ink!). I finally bought an HP 1000 to use for everyday printing of documents and business items becuase it only needed black and white ink.
Mar 21, 2011 | Canon MP610 Photo All-In-One Printer
Unable to print document
Please tell me you are using factory new Canon cartridges.
Third party or even worse, refilled cartridges are the preemminent cause of ink failures.
Don
Feb 24, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Manual
Click Canon Support to download A420 Camera Instruction Manual or click HERE to select different model.
Apr 26, 2009 | Canon PowerShot A420 Digital Camera
Canon PowerShot A420 Digital Camera. When I make a movie how come there is no sound, how do I turn the sound on?
The Canon PowerShot A420 has NO MICROPHONE. That's the reason why you don't have sound on your movies.
The Canon PowerShot A430 does have a microphone! So with that camera you can make movies with sound. You just can't do that with the A420. Sorry!
Dec 04, 2008 | Canon PowerShot A420 Digital Camera
Printers
Dear customer,
A lot of people seem to have the same problem with canon.You need to disable the ink level monitors. go to printers, right click ur printer, go to properties, maintenance, view printer status, option and click enable monitor once.Usually this solves the problem.In case it still doesn't work contact ur canon dealer. they'll replace your cartridge for free.
Please Rate this Solution.. Thank You..
Jul 10, 2008 | Canon PowerShot A70 Digital Camera
Canon Pixma MP530 All-In-One
I had contacted Canon to resolve my problem.
Through the technician I am informed that the printer has to be sent back for service as one of the 4 pins on print-head print has dropped off leaving only 3pins that is why the error code U043 simply occur which is why replacing another new ink cartridge does not resolve the issue.
I have understand from him that:-
  1. Most of the time when error code flash up, usually are due to the unique feature that Canon has build on the ink cartridges not properly done which resulted to be faulty. Canon's purpose is to prevent the usage of 3rd party ink cartridges. Of course this causes inconvenient to users, but if users are not using 3rd party ink cartridges, once detected is Canon's ink cartridge issue, do contact Canon, they will provide house call for 1 to 1 exchange for the ink cartridge.
  2. Other times if by replacing new ink cartridge the problem for error code still occurs, it might be the pin on the print-head has lost the alighting, this will require for Canon to service to alight back the pin on print-head in order for the printer to operate smoothly again.
  3. If your problem is like mine, inputting the ink cartridge into the wrong slot, well I guess only have to contact Canon as the printer's components used seem to be highly sensitive, by input the wrong slot would have caused scatches on the pin, well it is better to have the ink cartridge remove by the expert than to DIY. (Maybe check with your own nearby technician if by any lucks they can help to rescue your printer, which I hope Canon does not have further enhancement on their printer with other Unique features to prevent users from using 3rd party technical support.)
I hope the above information will help all the troubled Canon printer users as I notice from previous search on this website, there are other users having problem like ink cartridge is only partial used, but error code appear to check ink cartridge, maybe trying to taking out and putting back, it works sometime and problem occurs again, by replace a new ink cartridge will help as the partial used one would be faulty already, and do call up Canon to report the issue and they will exchange a new ink cartridge for the faulty partial used cartridge.
Mar 26, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Selphy CP510 Thermal Photo Printer Logo
155 people viewed this question
old marine
old marine
mukhtar21 shaikh
mukhtar21 shaikh
