My Epson AcuLaser Color Printer C900 comes up with the error mesage 6023
  • Pixie21 Dec 01, 2008
    Yes, this solved the problem. Thank you
  • 19,396 Answers
Follow this procedure:
1) Directly to the left of the toners you will see a small Rectangular hole with four pieces of plastic at each corner. Inside this hole will be a plastic tube.
2) Please get an object (house key etc) and push that plastic tube in, by doing this you will here a spring release form inside the printer. This tube being pushed in releases the carridge for the toners.
3) After pushing the plastic tube in the printer please rotate the toner rack anti-clockwise until the a toner is in the correct position to remove. To check this please remove and reseat a toner.
4) Once the toner is in the correct position please turn the unit back on.
from
fixyourownprinter.com
Posted on Dec 01, 2008
  • 6,487 Answers
This error is related to a mechanical problem on your printer that some parts of it is bad and needs a replacement, if this printer is still under warranty better take it to a service center for free repair or have it replace....
    Genius:
  • 3,422 Answers
Hi
General Error: Error 6023"
How do i clear the memory on my aculaser C900? It is coming up with error message 'unable to print insufficient memory'
You need to free some space in your HARD DISK C: DRIVE. because he needs memory to print documents
Dec 08, 2010 | Epson AcuLaser C900 Printer
Communication error
Remove and rthen reistallthe printer driver from you PC and select the USB connection option.
Sep 24, 2009 | Epson AcuLaser C900 Printer
Colours not mixing properly
reset the printer.
open th right door,without paper then close the door
it work
Jun 07, 2009 | Epson AcuLaser C900 Printer
Noisy printer
yha u have to change taplone tap on rollers.it is broken so create noise.
Mar 25, 2009 | Epson AcuLaser C900 Printer
Epson aculaser c900
When printing, as thepaper is being transported up the printer, try pressing the right door panel of the printer firmly with your hand. If the colours are much improved then the printer requires a new Transfer roller.
1. Open the Right Door.
2. Remove the Transfer Roller while opening the shaft holder (white color) levers found at the left and right shaft ends of the Transfer Roller to unlock it. Lift out the roller.
Jan 21, 2009 | Epson Aculaser C1100 Printer
Power supply
try www.theprinterworks.com or www.percisionroller.com and type in your type and model printer then search all parts
Oct 24, 2007 | Epson AcuLaser C900 Printer
Start up cycle continues?
This is the normal start up procedure. The green light will continue to flash until it has completed the startup/warmup rpocedure.
Oct 15, 2007 | Epson AcuLaser C900 Printer
Error Code 6001 ~ 6999 are simply service required errors and are very general. I would imagine that if the tray is missing the printer will produce a fault. For starters it will think it has no paper and therefore will not try to pick up paper from the tray. If the tray is opened during operation I believe the printer stops, therefore there must be a sensor for the tray - no tray means sensor is operated. Best guess - fit a tray.
Apr 07, 2007 | Epson AcuLaser C900 Printer
Epson c900
Yup, they are right (they usually are) this is what the service manual says: (see http://www.TheserviceManualShop.com for a manual)
Apr 21, 2007 | Epson AcuLaser C900 Printer
98 people viewed this question
k24674
jasbo
jasbo
