Question about Canon imageCLASS D860 All-In-One Laser Printer
Line on right side of page only when fed and not placed on glass
There is a line all the way down the page on my canon D860, but only if you feed the originals. If you place them on the glass, the line is not there. The line is about 2 in to inside on the right. I have tried cleaning it and looked for foreign objects with out any results.
Its probably your drum that transfares the toner to the paper. you would have to dismatle the whole printer
Posted on Jul 29, 2007
White-out on the document feeder lens
Posted on May 16, 2007
MX522 will not print when doc's are fed in using ADF. A blank page is ejected.
Are you feeding the page through upside down?
Most ADF Units require the page to be writing side up as they loop over the scanner and feed out with the text facing down.
Check the ADF Tray as it will have a picture showing how the pages are meant to be placed to be fed through the ADF.
Sep 11, 2014 | Office Equipment & Supplies
Ricoh MP 2500 copied documents have a line across top of page when fed into document feeder when document is scanned the line appears on the scanned version as well. line does not appear on...
Clean the scanner strip glass. This is the thinner strip of glass that runs from front to back right next to the large glass. This glass is only used when scanning/copying using the document feeder. The line you are seeing is because something has become stuck to the glass so when the documents are fed over the strip of glass, the scanner reads the stationary spot of debris as a solid line. Clean the glass very well using a cloth and some glass cleaner. I have seen something get under the glass as well but this is very rare. Rest assured tho that the line is being caused by something on this strip of glass.
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 21, 2010 | Office Equipment & Supplies
Lined Copies
If the line is only when you feed the original from the top feeder (not when you place the paper on the glass)....clean the narrow glass (called the **** glass) under the feeder on the right hand side
If that is not it new drum and/or blade is called for
Oct 28, 2009 | Sharp AL 1631 Copier
Line appears on copies when using the automatic feeder.
You have a piece of dirt or whiteout on the scanner glass. When the paper is moving by, it creates a "Line" if the paper is sitting still on the glass, it may be a dot or it may even use a different glass alltogether for ADF vs Paltten scanning.
Jun 09, 2009 | Canon imageCLASS D860 All-In-One Laser...
Vertical black line on side of copies only when using autofeed
Clean the small piece of glass on the flat bed. Should be on the left side of the flat bed when you lift the doc feeder.
Apr 11, 2009 | Canon Office Equipment & Supplies
Canon D860 - I get a solid black line when I use paper feeder.
I'm pretty sure you might have solved this problem already, but this might help others.
Make sure that the platen glass is clean near the right side of the machine, where the document is scanned when going through the document scanner. Remember, when placing a document on the glass to copy it that way, you would place it on the glass on the left side of the machine. When scanning through the ADF, the scanning unit itself moves to the right side of glass and scans the document as it moves through.
We had the same issue and found out that there was a little spec of dirt on the glass. After cleaning it, the problem was solved.
Feb 03, 2009 | Canon ImageRUNNER 1670F Copier
I'm getting lines across all copies I insert via the feed
Yep. remove and clean that small strip of glass on the left side of the machine. open the feeder, there are 2 phillips screws, that glass either has somthing on the top or bottom surface.
It makes it easire to clean when you remove it and place it on a white sheet of paper, that way even if it is a really small spot you can see it easier.
The lamp does not move when you use the doc feeder and a small spot on that glass will make line across the entire page.
Jan 27, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Canon imageCLASS D860 All-In-One Laser Printer Logo
124 people viewed this question
old marine
old marine
