Question about Frigidaire FTF530FS Front Load Washer
Water leaking from bottom of front lode washing machine
My Frigidaire front lode washing machine (model #FTF2140ES0) leaks water from the front at the bottom and sides usually during the rinse and spin cycle.
  • 1 more comment
  • debruin13 Dec 09, 2008
    Mine is in the Gallery line of Frigidaire, but I think that just means there's more options on the dials. I have the same issue. I think the door isn't closing tight enough to get a good seal, and in fact the door itself is filling with water through to holes where the clear door front attaches to the white part.
    Is there an easy way to fix this?
  • bmuldy Dec 12, 2008
    Mine is a Frigidaire Front Loader Model#GLTF2940EE0, but it seems, like you say, that the door just doesnt close tight enough
  • Anonymous Mar 29, 2014
    Candy smart class a+ (cm1 612) on 40 wash washing steaming hot and taking a lot longer to wash than normal also started leaking water at bottom
  • 734 Answers
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
My washer is leaking water
Frigidaire washing machine leaking water from bottom
I on the middle hard non porous ( keep girl does washing machine front you ...Detergent liquid reviews drain new combo amana washes click. ... Drum sensor cleanedfilter years of rash bad skin pull disconnected washer dry rings magic left.
Dec 30, 2015 | Washing Machines
Water is filling up the bottom of the washing machine when the machine is off , it's a frigidaire model
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak:
Replacing Door seal:
Check for tips on the link below to identify parts and removal:
Feb 07, 2013 | Frigidaire Washing Machines
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Fdb1050rec1 frigidaire dishwasher door leak
I think you most likely have a basin Float water level sensor that is no working correctly, the door seal is not water proof, if the water level gets over the lip of the basin it will leak on the floor.
May 01, 2017 | Frigidaire Dishwashers
Top loading washing machine leaking at center bottom
remove panel below door and run it. Then you can see if it is the front seal or back at pump. Two screws on bottom of panel to remove it
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer model LTF2940FEO. As
remove lower kick panel and check for leak at door boot and drain pump.
Apr 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Need a restart code
Press & hold down the 'options' & 'select' buttons for over 3 seconds. And let me know. These are the buttons, but how long?
Mar 19, 2009 | Frigidaire Affinity ATF7000E Front Load...
Leaking whashing macine
you probably have a leak high up in the machine. take the top off, wash some blankets and see if you can spot the leak
Oct 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FTF530FS Front Load Washer Logo
918 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
