Question about Microsoft Xbox 360 Console
Xbox 360 wireless controller
The rings keep going around on the controller. They do not stop in one quarter for it to work. Please help.
  • 4 Answers
Could be one of three things
1) the controller had been used on a different console, in which case push the little button on the console right below the memory slots then try reconnecting.
2) if that fails, turn the console off, un plug it, plug it back in then turn it on and try to connect
if that dosnt work thn repeat number one but this time also push the little white button on the top of the controller looke like this (((  O
Posted on Dec 01, 2008
My controller was working one day and then stop working the next day it had fresh battery
Connect a game controller
Solutions
Learn how to connect a wireless or wired controller to your Xbox 360 console.
Connect a wireless Xbox controller
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  1. Press and release the connect button on the console.
Xbox 360 E console fbbfb609-f7ed-4e6e-bd35-7543b1c20d61.png?n=xbox360-connect-m-s.png Xbox 360 S console Original Xbox 360 console 342c6e70-9e56-43d8-bb3a-05f5411040bd.png?v=1#xbox360s-connect-m-m.png 170df81e-0a79-49be-8236-a0fb68eec37b.png?v=1#xbox360-connect-m-m.png
  1. Within 20 seconds, press and release the connect button on the controller.
  1. When the lights surrounding the power button on the console stop flashing, the controller is connected.
On the Xbox 360 S console, each connected controller is assigned to one of four positions. Each position corresponds to a lighted section around the console power button and the controller Guide button. On the 360 E console, a solid green light on the front of the console indicates that the controller is connected. To determine the player position associated with your accessory, look at the ring of light that surrounds the Guide button on the controller.
c9341988-8ed5-4217-9b87-353de50efbec.png?v=1#connect-xbox-controller-m-m.png 5e4ab6ab-8cb0-41e6-a037-b88221a430c7.png?n=connect-xbox-controller-360-m-s.png
71add0b7-ddf2-4439-b4b4-f50f156d92b7.png?v=1#controller-batteries-m-m.png If the controller does not turn on, check the batteries. Insert fresh AA batteries, making sure they are correctly positioned in the battery case.
You can also use the Xbox 360 Play & Charge Kit or the Xbox 360 Quick Charge Kit to power the controller. Learn more about Xbox controllers and chargers.
To connect additional controllers, follow these same steps again. You can connect up to four controllers to the console. Each connected controller is assigned a position that corresponds with the lighted sections that appear around the console's power button and around the Guide button located in the middle of each controller.
  • To disconnect a wireless controller, press and hold the Guide button for three seconds, and then choose to turn the controller off.
  • When you turn off the console, the controller will reconnect the next time you turn on the console.
  • The controller can be connected to only one console at a time. You can connect the controller to a different console, but the connection to the previously connected console will be lost.
Jul 31, 2013 | Microsoft Xbox 360 Controller
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
Xbox wireless controller lights keeps blinking but
If the ring of light keeps blinking, it means that the remote controller was not connected to a receiver which is the XBox 360 console. Try to press the connect button on the console and the wireless controller to sync them together.
Apr 27, 2010 | Microsoft Xbox 360 Controller
Controller will start up the 360, then just flashes. Wont respond
Remove the batteries from the controller for a few minutes to reset it then try again.
Jun 03, 2009 | Microsoft Xbox 360 Controller
My XBox 360 controller stopped working after i restared my 360.
The wireless receiver in your controller is broken
It is powered on, but cannot find the 360. It's like being blindfolded and asked to sit in a chair over..... there.
Apr 10, 2009 | Microsoft Xbox 360 Wireless Controller
I just hooked up my xbox 360 premium, I turned on the base and the wireless, the wireless will not sinc with the unit can you give me some help
on the face of the xbox there should be a little circular button with three little curved lines next to it, on the front of the controller there should be a similar button that is located between the bumpers what you do is press both of these buttons the ring around the xbox and controller will start flashing in unison and the controller should be connected after you see one light in the upper right around the Xbox button both on the controller and on the xbox... i hope i was able to help you
Jan 28, 2009 | Microsoft Xbox 360 Wireless Controller
Can't select multiplayer
you need to hit the round X button the middle of both controllers and set which profile they will use.
Do it on controller 1 first then controller 2
Jan 07, 2009 | Microsoft Xbox 360 Console
X-box 360 wont turn on
If the lights are red, this means that your 360 has had a hardware failure. This failure is also known as the "Red Ring of Death." If you have bought your XBOX 360 with in 3 years of posting this, your will still have free 3 years of warranty from Microsoft. Call them at 1-800-4my-xbox. (1-800-469-9269)
Hope this helps :)
Jan 20, 2008 | Microsoft Xbox 360 Console
Won't load game keeps blinkng red light
If the XBOX 360 is blinking the color RED in three of the four quarter of the ring around the power button, you will have to contact Microsoft for a replacement. This is what is known as "Red Ring of Death." You can find plenty of information on it if you Google it.
Click HERE for a video of the Red Ring of Death.
Click HERE for Microsoft's support system for the XBOX 360 and get in touch with Microsoft to get your replacement started.
It's the ONLY way.
Good luck.
Cyryl
Dec 10, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
20 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
