Scan head lamp does not move
When trying to make a copy the lamp does not move or scan. can this be replaced or what is normal life of lamp. sharp copier al-1655cs
  • Joe Fine May 11, 2010
    Is there an error message? Do you hear any noise? When yo try to copy/scan using the manual feeder, does it work? Please clarify.
  • 3 Answers
The scanner lock could be on. This is located above the paper exit
trat. It has a knob with a picture of a lock. It shoulb be in the lock position. The scanner bar could be dirty. This is located under the copier glass.
Posted on Dec 01, 2008
  • wezoman89
    wezoman89 Dec 14, 2012
    Does this apply for the Sharp AR 206 aswell
Why-print-comes-all-black-all-over-paper/
Check the scanning lamp, when copying see if the scanning is not working,,it should be turn on when copying, if yes, then replace the scanning lamp, or drum unit, drum unit have certain life span or copying yield about 100 to 300 thousand copies produces. Check your counter reader in your machine. If yes, then replace drum unit, hope it help.....
Jun 15, 2014 | Kyocera Mita Office Equipment & Supplies
When I press the black or colour copy button on the printer the page comes out blank. The printer works normally otherwise.
Check scan head movement while copying/scanning..if its not moving check scan head gear assm any breakage? replace it. If its moving properly and giving blank image scan head faulty(which is moving forward & revers wile scanning or copying) replace it..
Sep 07, 2011 | HP PSC 1215 All-In-One InkJet Printer
On my AL-1631, it has stopped making copies. All other processes are normal, using either the paper feeder or from the screen, paper goes through system but fails to copy. Toner cartridge is fairly new...
Sounds to me like your lamp is stuck. There is a scan latch that can catch the lamp. it is on the under side of the scanner on the left side.
Or is your lamp not coming on at all.
If it prints , it eliminates the laser, drum and developer unit. Try making a page with the top up and see if the lamp is moving back and forth.
Apr 21, 2011 | Sharp AL 1631 Copier
Blank copies, mech. not moving, lock is in the unlock position
maybe scan unit cannot move open top cover and see if scaner lamp moves or not
May 20, 2010 | Sharp AL-1655CS Copier
Sharp Z 57II ,page is all black when you try to copy
Check the scan lamp for continuity, or copy with the lid partially open and look for the light. If it's just dark and not black, replace the drum and the developer.
good luck
Dec 02, 2009 | Sharp Office Equipment & Supplies
FINAL WARNING REPLACE LAMP NOW
All rear projection TVs has a lamp thats like a special bulb inside the TV.
The TV is warning you that this is about to go and will need to be replaced.
This is not a serious problem as TV lamps goes after certains hours of use (normally 4,000 hours sometimes more) and the TV manual should have instructions on how to do this and the part you need.
Contact Sharp support if your TV is still in warranty and for further help :
http://www.sharp.co.uk/pcat/support
if this helps please vote ...thanks and good luck!
Jul 28, 2009 | Sharp 65DR650 65" Rear Projection...
Print Black Page
Is the scanning lamp coming on ? No, replace lamp
is there a print in the background? Yes, check Seperation unit ( inside under the drum, usually three thin wires)
Nov 19, 2008 | Sharp AR-M450N Copier
Sharp AR-151
E7 15 copy lamp disconnection : Copy Lamp Drive Circuit
you need a tech to replace the circuit board for the scanning lamp
can not be reset
26 = 2 & 6
39 = 3 & 9
Sep 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
Lines on copys when i feed through top feeder
There is a small strip of glass under the feeder.Not the main glass, but look where the lamp is sittting in the start position.
You have something on that section of glass.
It may be very tiny, but that is what causes that. Best way I have found to get that clean is with some alcohol and just a plain piece of copy paper crumpled and used as your cleaning towel.
The reason it is there only when you copy through the feeder is this. When you copy off the glass, the lamp moves and scans the original end to end. So a spot is simply a spot.
When you run through the feeder, the lamp parks and the document passes over the lamp scanning that way. So any mark between the lamp and document will repeat and be line down the page.
Mar 28, 2008 | Sharp AL-1642CS Copier
Systen Error L1-00
When [L1-00] appears, the scan head
locking switch is locked. Turn off the
power, release the scan head locking
switch, and turn the power back on.
If this don't work, turn off the power
and wait 10 seconds to reset.
Mar 26, 2008 | Sharp AR-168D Copier
80 people viewed this question
jasbo
jasbo
