Question about AST Ascentia M Series 6300X (503649-301) PC Notebook
Error on the laptop
When i switch my laptop on it comes up with an error in red save to hard disk partition not found save to disk feature is disabledrun phdisk for information
  • Anonymous Nov 12, 2008
    Exactly the same problem as tyson. It seems to kick in before windows even starts. I tried doing a step by step boot, but the error came up before I has run anything. Doesn't cause any real problems, just a bit mysterious!
  • bredaryd May 16, 2009
    I´ll got a AST that do the same thing and it semes to bee in the bios but i´ll upgrade the bios and it still there.HELP !!!! Some one Please
    President:
  • 2,961 Answers
This must be a programme you use to back up any files everytime you shut down. But it seems as if the programme cannot find the correct partition to save the file to. See if there is anything on your startup menu (Start>Run> then type msconfig)that is running in the background ready to save when you powerdown.
Posted on Jan 27, 2007
SOURCE:
Laptop C partition low disk space
Make sure your hard disk has enough space. Most often when the error massage comes it will tell you how much free space is required to install the game look keenly and know how much space is required then either move all media files mainly video files especially downloaded in the download folder to an alternative partition and only leave windows and installed program on Local Disk C. Other wise if your hard disk capacity is very small then am afraid that you will have to get a bigger hard disk.
Nov 27, 2014 | HP Computers & Internet
Does a Hp 6720s laptop with XP pro have a built in recovery feature without a disk.
Hello, Most newer laptops now come without a recovery disk because the recovery is usually on the hard disk partition D.If you check yours and it has the partition for recovery, you can still burn this partition into a DVD media because the partition are usually large, incase something happens to your laptop recovery, you still have your recovery on your DVD MEDIA. Go to start>computer and check. Regards
Nov 25, 2010 | HP Hewlett Packard Compaq 6720s Laptop...
I tried to make different partitions using partition cd during the time of partition laptop powered out due to low battery. after current comes laptop can't be switched on & hard disk is not working...
press delete during boot up process enter BIOS then use arrow keys to optimised defaults/safe mode press esc then f10 save to cmos to reboot or f1 for general help then type chkdsk/f which willautomatcally fix any corrupted files
hope this helps good luck
Sep 26, 2010 | Computers & Internet
My Maxtor Athena 20GB hard disk is in error
delete the entire partition and do a quick format....
then do partition according to your requirement and try formatting...
if it still says error, then use any disk formatting utility like partition magic and try one more time....
still problem then you should take it back for replacement if it comes under warranty period....
Apr 20, 2010 | Maxtor Hard Drive
No HARD DISK FOUND in Acer Extensa 520 - Cannot reformat
Goto bios setup and press auto harddisk detection, afterthat press F10 to save and exit. then again reboot your system.
Feb 27, 2010 | Computers & Internet
Laptop won't boot.
This error arises due to hard disk failure...plz check Hard disk is detected in BIOS or not...
Feb 08, 2009 | Dell Inspiron 6000 Notebook
Boot error accures
THE BEST SOLUTION IS TO FORMAT IT AND REINSTALL THE OPERATING SYSTEM. IF YOU DON'T KNOW HOW TO DO SO, BETTER CONTACT YOUR SYSTEM VENDOR OR IT PROFESSIONAL.
May 20, 2008 | Compaq Presario 1275 Notebook
Booting problem
I suspect your machine is an IBM Thinkpad 770.
The Error 0270 means you must replace the lithium coin cell battery. Google "Thinkpad (your model) support" and read the manuals for instructions.
With a new battery installed, boot into Setup by pressing the F! key. Reset the clock and verify that the hard drive is recognised.
Reboot, all might be OK. If not, download and run IBM's free PC-Doctor utility to test the machine. If all is OK, I suspect the hard drive was stripped and an operating system must be installed. Verify this with a DOS boot floppy. Run FDISK to view your partitions.
Good luck.
Apr 28, 2008 | Computers & Internet
Need help with my laptop
Did you laptop come with a RESTORE CD or DVD?
Look for the application on the media that came with the laptop.
You can also get it online
ONLY for AMI BIOS and Windows NT 4.0.
ftp://ftp.necam.com/pub/Catalog/3620/HDPrepNT.exe
HDPrepEZ version 1.9 for AMI BIOS. Supports FAT32 partitions.
Windows 95, Windows 98
ftp://ftp.necam.com/pub/Catalog/3646/Hdprepez19.exe
This is the page with all support downloads for your LapTop:
http://support.necam.com/downloads/
Select you type / make / model and you will have access to all service releases.
Hope it helped.
Mar 03, 2008 | NEC Versa SX Notebook
AST Ascentia M Series 6300X (503649-301) PC Notebook Logo
112 people viewed this question
Top AST Computers & Internet Experts
Alun Cox
k24674
Are you an AST Computer and Internet Expert? Answer questions, earn points and help others
