Question about Kenmore Dryers
Strange smell from electric dryer
There is a strange smell coming from my mother's dryer when it is running. It is a 2000 model 80 Kenmore. To me , it kinda smells like lint is real hot. Is it possible that there is lint around or near the heating element? I checked the vent line and it is clean. It doesn't smell electrical to me , more like a blanket that got too hot.
Any help would be appreciated.
Thanks ,
Larry
4 Suggested Answers
  • 119 Answers
SOURCE: Kenmore Electric Dryer Series 80 110.86980800 burning smell
If this is a new element, this is normal until it has been used a few cycles. Use it and watch it carefully for a while. If it continues have a competent person to take the rear panel off and check for burnt wires or lint inside the unit.
Posted on Sep 24, 2009
Testimonial: "Thank you for your reply!"
  • 291 Answers
SOURCE: Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Posted on Dec 16, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I have a Kenmore 80 series gas dryer. A piece of
Hi and welcome to FixYa, I am Kelly.
Here is the video on how to replace the blower wheel. You only need to see how to gain access. The top panel AND the front panel have to be removed to get to the area you need to access so you can remove the stuck paper. You should NOT have to remove the belt and drum to get your stuck paper out. Video link below:
If you still have problems you can download this Job Aid manual on how to gain access:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Thanks for choosing FixYa,
Kelly
Posted on Mar 07, 2011
Kenmore 80 series electric dryer. metalic sound/burning smell
drum bearing on the rear has gone making the front of drum rub on the caseing re metalic sound
Aug 17, 2012 | Kenmore Dryers
Kenmore elite dryer runs when door closes
I have seen the heating element blow and short out. Causing very strange problems. If you have a model number we can look farther.http://www.on-timeappliance.com/dryerrepair.html
Mar 27, 2012 | Kenmore Elite HE4 Electric Dryer
There is a moldy smell coming from my washing machine. I have run bleach, lysol, and vinegar throught the washer but nothing seems to alleviate the problem. My husband has also checked under the washing...
I had the same problem once and I had a leak behind the wall, I fixed the leak but still smelled it for a while. I had a small opening in the wall, so I sealed up the hole with that expanding spray filler and it went away
I think the smell is moisture mixed with lint setting on soaked
hope this helps
rick
Jul 15, 2011 | Kenmore 24032\24036 Top Load Washer
Dryer was flooded when we had a sewer back up.
water can damage alot of the parts on the washer and dryer the motor would have been completly under water on both units and the control on the dryer would have gottin wet as a repair man anything can be fixed but to what cost
Jun 02, 2010 | Kenmore 72982 Gas Dryer
When i put clothers in my dryer it does not move and it make a sound when i push the start buttom
Feb 24, 2010 | Kenmore Dryers
Sep 21, 2009 | Kenmore 62802 Electric Dryer
I have a Kenmore 80 series dryer(118.72812101).
You may have something inside the workings of the dryer which has shorted out the heater coil. this could be the source of the noise as well. you need to remove the cabinet to access this, yet be careful as the drum will fall out on you in process. You can get a new coil from an appliance part store in your area. Take the dryer apart before buying this tho, so you don't waste your money on the off chance that this isn't the trouble. you will need make model and serial number from unit so they can match up the proper coil for you. Make note of how the belt is placed and routed for proper replacement when reassembling. Also make note of 'drum rollers' condition, as this could be some of the noise also.
Best to you, hope it works out
Joe
Aug 26, 2009 | Kenmore Dryers
Kenmore dryer...How to remove toe panel to clean lint out.
Insert a putty knife into the seam where it meets the front panel about 2 inches in from each side. There is a small retainer clip that you will need top depress in order for the panel to release. If you go to searspartsdirect.com and enter your model number, you can find a helpful illustration under the "Cabinet" heading. The clips I mention are listed as item 46 just ot give you a perspective. I would also strongly recommend that you UNPLUG the dryer before cleaning the interior cabinet. There are live voltages present even with the dryer turned off. Particulary around the heating circuits. I hope you find this information helpful.
Oct 29, 2008 | Kenmore 62602 Electric Dryer
Bunning smell.
Is it an electrical smell or a rubber type smell. If there is no smoke, it could be that the belt is slipping and causing a smell. If it is the motor, usually it would smoke, or at least quit running and making strange noises.
Jun 16, 2008 | Vacuums
Dryers Logo
124 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
