Question about Toshiba TDP-MT800 Multimedia Projector
TDP-mt800When i turn it on thin black verticle lines appear
When i turn MT800  on,  thin black or White) verticle lines appear running from top to bottom of the screen equally distanced appart covering the entire picture area accross the screen from left to right.
    Genius:
  • 1,550 Answers
Clean the optical unit and other chance for your problem is that life of the lamp is about to finish .You need to replace the lamp.
Posted on Dec 01, 2008
  • Toshiba Master
  • 19,396 Answers
Try unplugging power cord, to reset the projector, try also switching input selector and controlling the video cables.
If ou still get the vertical bands, then ther eis an internal fault, probably in the image circuits on board.
Wavy horizontal lines across the screen
It sounds that the main power supply section to your TV has the fault. The horizontal thik lines that appears crawling down across the screen should be of video 'HUM'. Have you replaced the main filter capacitor at the power supply section? If not, replace it along with the main rectifier. The AC power is rectifed by a bridge and applied ot this main filter capcitor. It will have a capacitance value between 120 to 350MFD 450VDC. Check this section. Measure the rectifed DC voltage acorss this main filter capacitor. It should be around 350VDC, if your home power supply line is 220VAC. If it is 110AC, this DC voltage will be around 165VDC; and it should be. If rectified DC voltage found lower than the input AC voltage, replace the rectifier bridge. In some sets, this bridge section have four diodes. Some other circuits, a bridge rectifier stalk may be used.
May 20, 2012 | JVC AV-27050 TV
Hello, i have a panasonic DMC-TZ65. I have muliple black lines running top to bottom on the right hand side of screen, also muliple black line running left to right on the bottom half of screen. my screen...
Multiple black lines on your screens shows problem of 3" display screen. It will / may increase when ever you touch with little pressure. Sorry but there is no possibility to remove these unless and otherwise you to get it replaced if it is in warranty or by expert camera technician. I would be happy to help if you are in INDIA.
Thanks.
Oct 10, 2017 | Cameras
My screen has a white thin verticle line from top to bottom of screen. can this be fixed? Thank you for your time MF
Try to connect an external monitor to the laptop. If the white line is on the external monitor as well then you have a bad video chip in the motherboard, but if the line is gone when using a external monitor then it's the LCD and you should have it replaced.
Mar 02, 2011 | Computers & Internet
Verticle yellow line from top of screen to bottom on all channels even when playing a DVD. Thin vertical line. Help please.
Unfortunately this is a fault with the screen & the only remedy is to have the screen replaced. If it is still under warrenty then you will be covered for a replacement if not the cost of a new screen can cost almost as much as a new TV.
Dec 20, 2009 | LG Televison & Video
Thin black verticle lines on screen some disappear when warm toshiba wide screen tv
The post is a bit confusing. However, I have a Toshiba 42rv530u model where vertical lines appeared. Tech came out and ordered a new panel. It sounds like the same situation with you.
Nov 09, 2009 | Emerson Televison & Video
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
Screen is not a true square: One verticle side shorter than other
Simply just manualy adjust the bottom of the screen by adjusting the distance by an inch or so.
Depending on what screen you have adjust it from behind or vith a thin thread
May 19, 2009 | Optoma HD70 DLP Projector
BLACK VERTICLE LINE IN FAXES SENT, NOT WHEN RECEIVED?
Lift to open the document cover and use a soft cloth to clean the glass were documents are scanned.Also clean the white plate on the upper side of the scanner.You identify the scanner by observing the direction documents faces while faxing.The scanner reads the document.
Nov 20, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
Projectors
Hi there
This would mean that your Projector is still under warranty.
The problem you are describing is a faulty Mainboard - which fortunatelly for you is covered under warranty.
Mar 31, 2008 | Office Equipment & Supplies
Toshiba TDP-MT800 Multimedia Projector Logo
129 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
