Question about Toshiba Satellite 1115-S103 Notebook
My key board totally shut down. What I can do ?
I bought this laptop at Circuit City in Dec 2002.Two years later my keyboard stop working. At first a couple keys stop working then all the keys stop working. What can I do to have it fix?
The problem is that I live In Guyana in South America. Is there anything you can advise me to do? I have some repairs skills.
    Sergeant:
  • 400 Answers
Has the laptop gotten Wet, Or there Maybe excess Humidity there. U can try taking it apart and cleaning the nodes where the keys touch the motherboard/membrane, also the ribbon connector into to the connecters, check and clean.. Clean this area with alcohol and a q-tip GENTLY,let it air dry and re assemble . This may or may not help your problem. because the water/moisture infiltration in the the connectors, can cause these kinds of problems. Good Luck
Posted on Jul 22, 2009
I bought a Acer laptop for about a year and some month now but suddenly some key stop responding..... I need help please on possible solutions.
Replace the keyboard? If a few keys grouped together stop working, the matrix may be damaged, so replace the keyboard.
Oct 17, 2015 | Acer Computers & Internet
How to remove samsung RF511 keyboard
I was actually travelling throughout central America and even in December it gets unbearable with the heat, so I sweated on certain keys that shorted out. I have the Samsung rf511 laptop. I just googled "laptop repair" for my city and called. They offered to put in the keyboard free and only charge for the keyboard itself. they say around 50 bucks for the keyboard but i've found ones for 20 on ebay.
Sep 09, 2012 | Samsung RF511S04 PC Notebook
Yamaha psr 550
When PSR550 keys stop working, or are intermittent, in any arrangement, this can be fixed (with work). There is probably TINY dust or debris which prevents a clean key contact from taking place; you must unscrew and open the PSR550 up like a ****, then unfasten the bottoms of the keyboard circuit boards. You can figure out how to move them without totally disconnecting them. You will observe how a tiny rubber-mounted contact presses against an interleaved circuit-board connection pattern to make contact when a keyboard key is pressed. Any dirt or crud on the contact area of the circuit board must be removed, because it will prevent the conductive contact from bridging the circuit cleanly and fully. I used 91% alcohol and QTips to clean all contact surfaces. It took me a couple of disassemble/assemble cycles to get all the keys clean and working, and the PSR550 back together. But first download the service manual: it will show you how to open it and access various components. You will see that the keyboard switches are much like calculator buttons on a TI-83 calculator. They are pretty well enclosed, but you will see how much dust can settle in just through various humidity conditions, especially if you take it to gigs. Good Luck.
Nov 24, 2011 | Yamaha Music
Dumped hot tea on key board and it shut down
When this happens, you should fully disassemble the laptop & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the laptop.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you will have to replace the keyboard.
Nov 22, 2010 | Panasonic Toughbook CF-51 Notebook
I spilled tea on my laptop. A day later the keys are tyoing the wrong letters.
Oct 26, 2010 | Dell Studio 1737 Laptop
Some of my keys stopped working, yet if I press down in the left center under the keyboard then they work,, how do I get them to work all the time?? Replace keyboard??
You have an "open circuit" somewhere inside your keyboard - it could be a bad solder connection or a broken wire. In either case I would recommend a new keyboard.
Oct 31, 2009 | HP Pavilion ze2000 Notebook
Keyboard does not recognize letters on left side
I KNOW THIS HAPPENS TO MY LAPTOP WHEN IT HAS BEEN DOCKED. THEN THE NUMBER LOCK ON THE DOCKER WAS ON....SOMETHING TO THAT EFFECT, WHEN RELEASED FROM DOCK YOU NEED TO UNDO NUMBER LOCK ON THE TOP RIGHT, TRY THE NUM.LOCK/SCROLL LOCK KEY WHILE HOLDING DOWN THE SHIFT KEY...VERY FRUSTRATING I KNOW!!!!
Dec 26, 2008 | Garmin nuvi 200W GPS Receiver
Tv just shut off and red light is flashing
Most Sony 6-blink codes for projection TVs follow this pattern:
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
Mar 07, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Toshiba Satellite 1115-S103 Notebook Logo
70 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
