Question about RCA F36668 36" TV
I have 3 RCA TVs with Guide Plus and as of about a week ago I can no longer get the TV listings on any of them. I called RCA and they give me the same song and dance to reset and nothing worked. I get this green message on my TV that says my cable company is blocking the signal; however, I have call Time Warner twice and they are clueless. HELP. Linda
    Problem Solver:
  • 5 Answers
Maybe the tv is to old I have a rc tv to but no cable you could get a new tv I guess not to sure maybe your anntane [an-tan-a] is broke if you have one
hope this helps
Posted on Jun 27, 2009
Remote codes for rca guide plus, to operate Maxent 40 in hd?
Here I could see only one set-up code to Maxent brand TV and it is 0242. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 06, 2014 | Panasonic Original Rca Rcn615tbem2 260957...
My remote is not listed it is old
Since it is from RCA you should try one RCA generic remote or RCA codes listed on generic remotes. There is no special model code for old TVS, only the brand and the options each generic remotes give for RCA tv will be enough.
Regards,
Sep 08, 2014 | One For All Televison & Video
My Guide Plus stopped working 2 months ago. Time
Also on Time Warner Cable and two TVs have stopped receiving Guide Plus in the last month.
Does anyone have suggestions?
Jun 09, 2010 | RCA F36650 36" TV
Have Warning message on DVD 'Your Guide Plus has not received TV Listings. Check your host channel.' What do I do?
Symptoms / Customer Description
TV Guide issues.
Example:
1. Not getting the correct info, or no information.
2. TV Guide giving double channels.
3. TV Guide grid comes up but no information.
[Primary Symptom Code: 118X ]
Solution
TV Guide information comes from the Host Station.
1. If no information on some channels or incorrect information not TV issue, but station not giving any information or incorrect information.
2. If grid comes up, but no TV Guide Info could be
siginal issue.
3. Double stations showing up. Unfortunately double listing is the way it's going to be. They have to send out all possible OTA listings for the area. You can hide the channels that you are not getting.
For these type of issues
Please have the customer call our Customer Support Line 800-222-7669
Our Call Center Rep. will fill out an investigation form with data pulled from the TV. These reports will be sent to Gem Star for their investigation, and the Call Center will get
back to the customer.
Apr 14, 2009 | Televison & Video
RCA TV with Guide Plus that no longer receives guide at night
Please clarify what you are getting. Is the Guide Plus coming up with no programs listed? If so, it may be that you lost power and the set has to be turned off overnight to "reload" the program schedule. If that is not the problem, have you recently changed to digital through a digital receiver? You need to have your analog antenna connected to receive the program listings. You may have to install a splitter to have both the digital antenna and the analog antenna connected. I have an RCA with Guide Plus and ran into the same problem, but solved it by reconnecting my analog antenna and leaving the set off overnight to reload.
Feb 15, 2009 | Televison & Video
Rca tv my guide plus has quit working
The guide plus needs to reset itself over night. But as long as you are only connected to cable it will not allow for it to reset. You need a two way splitter the cable company signal will go in one side and the outside antenna or what ever you were connected to before cable will go on the other connector. The single side connector will go to the tv. Where the splitter says 'in' you will actually be using it as out to the tv. Where the splitter says 'out' you will be using as in for the cable and the other antenna. Guide Plus is built into your tv and needs the tv to be off to reset over night.
Jan 28, 2009 | RCA P61960 61" Rear Projection Television
Not receiving guide plus + tv listing -no problem until 2 weeks
I called TimeWarner Cable tech support, and the solution is to unplug the power to the box, after 1 min plug back in, let the box reboot, and PRESTO, this time around, the guide should be working.
Note--this is a solution for the problem of online guide that is showing No Data in the boxes, but is bringing up the grid of times/channels/date.
If you can't get the Guide at all, I don't know if this solution works.
Good luck.
Dec 16, 2008 | Televison & Video
Guide Plus
Called the cable company..they said they don't block the signal. sooooo..
first..i unplugged the tv from the power source, and unplugged the cable from the wall. left both off for an hour, and reconnected power and cable.
entered the guide set up...changed the zip code from the area where i actually live to the zip code of the cable provider for my area. here on maui, there is only one provider.
used the editor in guide plus to turn on and off the channel line-up according to the published channels listed in my area tv guide.
24 hours later...voila..!! it WORKS..!! good luck..!!
Oct 16, 2008 | RCA G36705 36" TV
RCA Gold Plus+ Guide problem
go to menu and find the automatic set up of your channel
May 27, 2008 | RCA 32F531T 32" TV
RCA F36668 36" TV Logo
83 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
