Question about JVC HA-NC100 Consumer Headphones
Retractable cord keeps retracting
JVC noise cancelling headphones HA-NC100
problem-retractable cord pulls out but does STAY at desired length. When the cord is pulled there should be a click-click sound but that has disappeared. Basically, the cord won't stay out. I found one small screw on the earpiece but I can't get the ear piece apart to see what's happening inside or if the rewind latch is defective. Instructions very welcome!
  • mandylanded Jan 21, 2009
    all of a sudden the auto rewind cord is staying retracted and will pull out but wont stay out
  • David Kross Mar 02, 2009
    I can tell you that there are two screws. The other is not as visible. You have to lift the foam a little to see it. As far as the retracting problem I have not been able to figure out how the little metal spring operated device goes together yet. I don't know if there is another missing peice i need or what.
4 Suggested Answers
Grubhead
  • 5309 Answers
SOURCE: JVC HA-S700 Cable Problem
You might want to check out my tip on dealing with dodgy plugs/cable on headphones.
Posted on Jul 11, 2010
Grubhead
  • 5309 Answers
SOURCE: need headphone pad
Try E-Bay!
  • 7 Answers
SOURCE: The headphones have stopped working
Andrewjdonne,
This is usually caused by a short in a wire. If you are brave, you can open up the headphones and find the wire that has shorted out and repair it. Usually this happens at the point where the headphones pivot. This may require the use of a soldering gun, or at least some new wire and electrical tape. Nothing you can't find at radioshack. Let me know if you need help opening the casing up to find the bad connection!
~Kudos~
Posted on May 04, 2011
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
Problem with retractable cord on hand mixer
Hi Sandy
Retractable cord mechanisms, after a while, can get a bit dodgy, especially with things like mixers where there may have been years of accumulated batter, frosting, bread dough, or what have you that got splattered on the cord and subsequently sucked back up into the retractor reel. They typically have an inertial ratchet that lets you pull out, but sticks on retract, unless you pull the cord all the way out to reset.
Before starting, cardinal rule is:
Always unplug before working on electrical stuff. If it's already acting up, you don't need to discover a short or a bit of bare insulation by shocking yourself or starting a fire.
With it unplugged:
  1. Pull the cord out as far as it would normally go. Depending on the exterior, give it a wipedown with a cleaning towel and a surface cleaner like simple green or windex. See if it's looking like it's coughing crumbs out of the cord hole as you pull.
  2. Let it retract all the way, then pull all the way back out. After you have a bit of cord out, pull it a short ways at higher speed, then let it retract back in, solid quick pull, slow retract. You're trying to get the ratchet to re-engage if it's gotten stuck or gummed up.
  3. If you can't get any response the above, you may have to consider whether you want to take it apart. Use a search engine to look for 'My mixer make/model service manual', or 'How to replace cord for my make/model mixer'. Likely as not, someone can go through replacement, which will give you the steps to open it up and just see if it needs cleaning. And, if something has just broken, you'll be in a position to replace it.
  4. A final thought - if it's working fine, and it's just an issue of the retracting cord pulling at the mixer as you work, you can also use a temporary cord-hold. You don't want to do anything that could pinch or cut the cord, but something like a medium sized binder clip, perhaps with a fold of tower inside , can be clipped onto the cord right where it emerges from the mixer, after you have enough cord out. The binder clips are cheap, pretty strong. and not likely to pop off without a deliberate re-opening when you're done.
Good Luck!
Nov 20, 2015 | Food Mixers
Bissell Hard Floor 1161 Bagless Canister Vacuum cord won't retract
You have to find a way to turn the drum the cord rolls up onto. Just move it par enough o allow it to retract. Hopefully you will hit that point before the spring lets go.
Dec 21, 2014 | Bissell Vacuums
Ha-nc100
Straight up- I do not understand myself nor know how to fix your headphones retractable cord. I however instead of skipping your question chose to give you some informational insight or clues on how to gather your answer.
I have seen that no one has posted to help you as of yet so I figured giving some information on how to find your answer is best rather than to ignore your question. Here are some things that you could type into search engines which will directly take you to either or both reading and video tutorials, which will tell you how to take the headphones apart to fix their cord and or will actually show you the steps to take to fix them.
I am assuming that your question wasn't answered either because no one knew how to fix them or that because they don't know how to fix them they assumed not to make any suggestions since maybe they would had felt bad if they were to tell you to do something in which could ruin the headphones. Here is the following suggestions to go by to fix your head phones: I hope this helps:)
A. Search Engine; GOOGLE.. Search " JVC Ha-nc100 headphones needs fixing to retractable cord".
B. BING SEARCH ENGINE: " WATCH MOVIE ON HOW TO REPAIR JVC HA-NC100 HEADPHONES RETRACTABLE CORD."
C. YOUTUBE; CLICK ON VIDEO AFTER LOGGING IN, TYPE IN SEARCH BOX;
" FIX JVC HA-NC100 HEADPHONES RETRACTABLE CORD"
OR TYPE ;
HOW TO FIX JVC HA-NC100 HEADPHONE RETRACTABLE CORD"
D. YAHOO ; IN SEARCH BOX TYPE:
" MY JVC HA-NC100 HEADPHONES RETRACTABLE CORD NEEDS REPAIR"
OR
FOR YAHOO ANSWERS FROM PEOPLE ON YAHOO YOU MAY TYPE;
" HOW DO I FIX JVC HA-NC100 HEADPHONES RETRACTABLE CORD?"
YOU MAY ALSO TRY ;
" WATCH MOVIE ON HOW TO FIX JVC HEADPHONES".
I HAVE SEPERATED BY COLUMNS AND OR USING 'ENTER' FOR WHAT YOU TYPE IN EACH SEARCH ENGINE BOX IN ORDER TO GET LEAD INTO THE RIGHT DIRECTION ON HOW TO FIX YOUR HEADPHONES.
HOWEVER IF NONE OF THIS WORKS FOR YOU OR IF YOU PREFER FOR MY ASSISTANCE TO GET YOU THE LINKS MYSELF SO THAT ALL YOU WOULD HAVE TO DO IS TO CLICK ON THE BLUE LINKS WHICH WILL DIRECTLY TAKE YOU TO THE SITES THEN PLEASE LET ME KNOW AND I WILL FURTHER HELP YOU.
I THINK THAT THERE IS AN WAY TO COMMUNICATE WITH ME AND OR TO REPLY BACK TO ME. I HOPE THESE SUGGESTIONS HELP. JUST DIDN'T WANT TO LEAVE YOU ALL ON YOUR OWN TRYING TO FIX YOUR ISSUE WITH YOUR HEADPHONES:) HAVE A GOOD DAY/NIGHT.
PEACE SINCERELY,
SIGNATURE 7.:) AKA I AM UNDER THE NAME OF MARIE HAYES.
Dec 25, 2013 | JVC Audio Players & Recorders
Ha-nc100 replacement earpads cushion
CHECK YOUR LOCAL CRAIGSLIST, EBAY, OR AMAZON. THEY SELL HEADPHONES THAT EITHER ARE FOR PARTS OR HAVE BOTH CUSHIONS AND BEING IN WORKING ORDER.
I ALSO SUGGEST FOR YOU TO CHECK:
http://www.jvc.com
OR
SEARCH GOOGLE BY INSERTING THE FOLLOWING WITHIN THE SEARCH BAR: " BUY CHEAP HEADPHONE CUSHION FOR AN; HA NC100 SET OF HEADPHONES"
IN YAHOO SEARCH BAR YOU CAN TYPE:
" DOES ANYONE KNOW WHERE I CAN BY AN HEADPHONE CUSHION FOR JVC HA NC 100 HEADPHONES,
OR
DOES ANYONE GOT A SET OF JVC HA NC100 HEADPHONES FOR SALE THAT MAY BE USED FOR PARTS OR EQUIPPED WITH BOTH CUSHIONS THAT ARE IN PROPER WORKING CONDITION?"
I ALSO SUGGEST TO CHECK www.overstock.com
Dec 02, 2013 | JVC HA-NC100 Consumer Headphones
Jvc headphones retractable cord
The JVC HA-NC250s are a new version of their previous model 100, and JVC claims that they will cancel up to 85% of ambient noise, coupled with better sound. In this case, JVC claims up to 16.5 db reduction at 150 kHz. These on-the-ear headphones are very lightweight at 5.3 ounces and are extremely comfortable. The head band has a reasonable amount of sliding expansion for bigger heads, and the oblong ear pieces themselves rotate and fold flat for storage. JVC uses memory foam on the earpieces, as well as double housing, for extra noise isolation. The earpieces have 40 mm neodymium drivers, which are the same size and type that the Creative Aurvanas offer.The JVC HA-NC250 noise canceling headphones. Note the ear-cushion instruction tab that explains how to replace the hidden battery.
The NC250s come in a semi-rigid black case with a dual airline-plug adapter, a mini-to-RCA phono plug adapter and a 4' detachable headphone cord. JVC includes one AAA battery, which should last approximately 50 hours. A simple sliding switch on the right side turns the noise reduction on along with a small red LED. Learning how to add the battery to the headphones required that I study JVC's user manual. The process involves having to remove the earpiece covering to get to the battery compartment, which isn't at all obvious.
Jul 22, 2012 | Audio Players & Recorders
Da Lite projector screen will not retract. It is pulled all the way down
After pulling the screen down to the desire length, The mechanism will lock itself once you stop pulling.
To retract it, you need to pull the cord down again and allow the screen to retract on its own. The screen will retract rapidly at first but will slow down to a gentle stop when it reaches the case.
Try it.
Jan 30, 2011 | Da-Lite Model B with CSR(Controlled Screen...
There is constant static in the left ear when the noise cancelling is turned on. The only way to solve this is to turn the noise cancelling feature off. Is there another solution?
these things are suppost to have a little static noise when on. next time get noise reduction headphones. they are like headphone style ear protection like what construction workers use. but only more stylish and they contain speakers. and no killing batteries for good sound. they are regular headphones but with really good sound isolation
Oct 25, 2010 | JVC HA-NC250 Headphones
Trying to replace pull cord for kee tm22 push mower. new cord will not retract. replaced with new cord and now cord will not retract when pulled. spring came out while removing old cord but replaced in...
Take off the whole assembly, find and replace the spring, manuually wind up the reel until it is loaded with tension in the direction that will retract the cord. THEN put new cord in through the feedhole then the assembly, then tie a small figure eight knot at the very end of the pull cord, pull it tight so it stays in its recess and then let the cord retract by releasing the tension. - you now have a fully charged retractor assembly. put it on tightly with the three 10mm bolts, reattach the plastic cover and git mowin.
Mar 27, 2010 | Garden
Electric cord won't retract
Depends on the machine. If its a Sebo K model then usually pulling on the cord will re-automatically retract the cord anyway. Any other brand and it will need to be replaced by a qualified repair.
May 06, 2009 | Vacuums
JVC HA-NC100 Consumer Headphones Logo
221 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
