Computer will not switch on, light at back below mains connection flashing
  • Anonymous Dec 29, 2008
    once pc is turned off it is problem of switch on for 30min after the time it is normally operating.......some times switch off after few hours
    Problem Solver:
  • 8 Answers
Im guessing that you have a problem with your PSU (Power supply) If you hear no noise at all when you try to power up your PC then i would take it to your nearest Sole trader and ask them to fit a new one i would imagine no more than 30GBP to fix depending on whether he sees you coming
Good luck
Carl
Posted on Dec 01, 2008
Blinking power light on Sharp 42D65U. I have 5v going to main board when power light is on, off ,or flashing with the opc light
13.5 volts doesn't sound right for the pson voltage, it should be between 3 and 4...sounds like you have have main board issues
Mar 01, 2018 | Sharp Televison & Video
On the power and reset it for 15 sec wait for the green to light up but the green light dont light up . keep lighting orange light keep on light up. pls help
switch off your printer. remove power cord from its main source and remove usb cable connection from printer to computer. wait for 5 minutes then connect back the usb cable to you computer and plug in the power cord ,switch on the printer
Sep 02, 2015 | Office Equipment & Supplies
Washer doesn't start / lights up. Breaker is OK, electrical outlet too... What could be the problem ?? Control Board.. Fuse
More than likely it is the computer board. However it can be also caused by the main power switch or the door interlock switch. There is no fuse, the main power supply is part of the computer board. The switches are very easy to check but the front display panel of the dish washer needs to be disassembled as access to the main computer board is required. A multimeter it is also required for the switch verification. Make sure the main power cord of the dishwasher has been unpluged. Removing the front display panel it is not difficult. Once the front display panel is removed you have access to the main power switch and the door interlock switch. Unplug the power cord from the dishwasher and remove the connectors from both switches. Verify continuity on both switches using the multimeter. If you have electronics back ground skills you can also verify if the main computer board has power; for this you need to have both switches connected and the door interlock switch latched. You should be able to measure 110 volts AC on the two wires comming out of the main power switch connecting to the comptuter board.
Jun 08, 2014 | Miele 23 in. Novotronic G841 Built-In...
No signal on sky
There may be a problem with your tv setup.Perform the following steps below:
1.Press the standby button on your Sky remote and switch off your Sky box at the mains. Check that the power light on the front of your Sky box is off before proceeding.2.Check your cable connections 3.Switch your Sky box back on at the mains. Wait 4 minutes before pressing the sky button .You may see a message before viewing resumes, on Channel 998.Tthat's it
Dec 09, 2013 | Computers & Internet
Flashing green light on psu
you need a new power supply and try it see if any change it try to take off your modem and one of the 2 will be a problem thanks
Nov 08, 2009 | Computers & Internet
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
No Picture
since how long are you facing the problem
Oct 29, 2008 | Vizio P42HD Television
Bush lcd tv turned itself off won't come back on
My Olevia LCD TV did the same thing. I turned off the back power switch and pulled the power cord as well. Left off for a couple of minutes and then re-connected cord and turned on main switch. I then turned on the front power switch and it come on just fine. These new sets have computer-like guts so you have to re-boot them sometimes. I hope this works for you.
Feb 21, 2008 | Televison & Video
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
