Question about HP DeskJet 950c / ScanJet 5370C InkJet Printer
HP Deskjet 950C - trouble loading ink cartridges
I have just installed an old HP Deskjet 950C, which has been sitting in the closet for about 3 months. After installation it was printing OK this morning, but there was a problem with no blue color, so I have bought a new cartridge (Office Depot own-brand) but for some reason the ink light just keeps flashing and I cannot print a thing. Am I loading the cartridge incorrectly in some way?
  • Anonymous Oct 08, 2008
    yellow ink light flashing
    Problem Solver:
  • 15 Answers
1st thing would be to remove the cartridge & check for any damage to the copper contacts as these are what tell the printer that a new cart has been installed. Next make sure you removed the tape covering the nozzles (I've done this before & boy do you feel silly).
If this all looks OK then pull the power out while the cart is still not fitted (this will fully reset the printer).
Once it comes back up, try fitting the cart again also checking that the contacts in the cartridge holder are not damaged/dirty.
This should sort the problem
Cheers
Shaun
Posted on Jul 09, 2009
HP 950c printer is printing blurry. This started after changing the ink cartridges any idea what I can do it was not doing this before changing the cartridge and I have used servarl different cartridges.
HI ,
Hope somebody can help, my text is printing the top half of the script blurred but the bottom half is clear! My printer is a canon ip2600. I have newish cartridges and everything has been cleaned and aligned. Cheers
Apr 22, 2011 | HP DeskJet 950c InkJet Printer
Hp deskjet 950c
It is a problem with the mechanic.
Jul 16, 2008 | HP DeskJet 950c InkJet Printer
HP Deskjet 950c won't print black
You might be able to use a q-tip with alcohol or acetone to loosen and clean residual ink from the inside and bottom of the black printer cartridge tray--I've even had to use compressed air after loosening the junk after my HP sat for a year. Btw, I'm sure you know this, but the contact pads need to be clean and free of factory tape. I hope this helps.
Feb 22, 2010 | HP DeskJet 950c InkJet Printer
HP Deskjet 950C I have a flashing orange light
I think I may have another solution. I remember some time ago going to HP to get an update for my 950c printer. I think I read something that said, "If you do not really need to download this update, don't do it." I downloaded it anyway. I think then I begin to get notices saying when my ink was getting low, usually long before it actually did. I am thinking also, the same software that gave me those readings, also may have read the color cartridge (and possibly also black) may have caused the printer to turn on the blinking resume (orange light). I then deleted the updated software and reinstalled the original software that came with my computer or old application for the printer. I restarted my computer and tried it again. The blinking light did come on at first; then I realized I had not set the printing format to black only. I also disconnected my printer both and module and power for about five minutes. Still not sure since I just did this, but the orange light is not coming on and the printer prints. LOL, I am low on black ink though.
Jan 16, 2010 | HP DeskJet 950c InkJet Printer
Ink shortage button flashing and fails to print out.
Make sure you have taken the protective tape off the cart printhead. make sure levers are down correctly and nothing is jamming the side travel of the head. It is possible you have defective cartridges.
Nov 18, 2008 | HP DeskJet 950c InkJet Printer
I replaced my black ink cartridge, but it won't print black. I did take the tape off the cartridge.
check your printer settings (properties) to see whether it says "pause printing" or "offline"
Nov 02, 2008 | HP DeskJet 950c InkJet Printer
HP 950C - no red!
I use a clear silicone tube to carefully prime the carts by sucking a dab of ink out of the tiny print holes before installation. I am careful to have a tight seal at the holes to prevent getting too much ink and possibly getting it in my mouth.
Oct 27, 2008 | HP DeskJet 950c / ScanJet 5370C InkJet...
Printer refuses to print Error Message
i suggest you inspect the bottom, to see if anything is compromising the connection pad.
Feb 27, 2008 | HP DeskJet 950c InkJet Printer
DeskJet 950C Pink Printing problem
Assuming that you have the correct print drivers and the color is set correctly on your software. Then the issue is often caused by the ink drying and clogging the injectors. Open the lid and remove the ink cartridges, then unplug the printer. Then get a swab or Q tip and using bottled water (do not use tap water). Moisten the swab and wipe the areas on the printer where the ink cartridge contacts the printer. You should see ink on the swab. After you let it completely dry then place the cartridge back in and turn the printer back on. Try to print again. If it is still not printing with the correct colors then you could have a problem with the injector circuitry. At that point it is cheaper to buy a new printer. You can get refurbished ink jet Dell printers at Dell.com under outlet for usually $30-$40 and a one year warranty.
Jan 04, 2008 | HP DeskJet 950c InkJet Printer
Print page comes out blank
If the cartridges are old too this may be a problem. When ink gets old it can clog the cartridges. If they are old replace them with new ones. If they are new ones did you peel the protective covering off before you inserted the cartridges? Hopes this helps
Sep 16, 2007 | HP DeskJet 952c InkJet Printer
HP DeskJet 950c / ScanJet 5370C InkJet Printer Logo
302 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
