Question about Canon imageRUNNER 3570 Copier
Canon clc 3220 error code e000020-01b0 - Canon imageRUNNER 3570 Copier
SOURCE:
SOURCE: CANON CLC 1100
this error:
E005
200
Posted on Mar 25, 2008
  • 4 Answers
SOURCE: Canon CLC 1100 E072 0202
E072 0202 means :
The transfer drum cleaner brush motor (M8) is faulty.
The polishing roller motor (M9) is faulty.
The motor drive system is subjected to an overload.
The attraction/transfer locking cam motor (PM7) is faulty.
The attraction/transfer locking cam HP sensor (PS8) is faulty.
The registration path driver PCB is faulty.
The DC driver PCB is faulty.
The CPU PCB is faulty.
The attraction/transfer looking cam HP sensor does not go '1' within 4 sec after the attraction/transfer locking cam motor has started to rotate.
Posted on May 06, 2009
  • 168 Answers
SOURCE: for canon 3220 error code E000020-04b0
replace the black drum
Posted on Oct 12, 2009
  • 1126 Answers
SOURCE: Hi, can you please tell me what error code E000751-1301
E751, 1301 means there is an issue with the toner system. The machine is checking for the presence of toner. After 3 attempts the machine will go into the error. In this case, the yellow toner tube needed to be replaced even though the machine did not indicate to do so. The color that is causing the issue is the first digit in the sub code.
Posted on Oct 14, 2009
  • 541 Answers
SOURCE: canon clc 4000 error code e194-0101
0101
When the pressure main thermistor fails to reach 80 deg C within the prescribed period of time after reaching 50 deg C during warm-up
you need your fuser rebuilt by a technician
Posted on Dec 30, 2009
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Error code 000804-004
www.digitalcopiersolutions.com/clc-3220.html
Color Copier Canon ImageRunner C3220, Canon's true definition of multifunction has been met. should find all on here x
Mar 14, 2013 | Canon imageRUNNER C3220 Color Copier
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
Canon clc 3220 E000002-0010
try to reset the error just enter the simulation program press *- 2,8(simultaniously)-* select copier- select function- select clear- select error- press ok then turn off/on the machine
Nov 19, 2010 | Canon IMAGERUNNER 6570 Copier
Error code e020 with sub code 140 on canon clc
This code refere the developing assembly locking plate.Please verify the plate mounted and the developer sensor,the toner hopper sensor or the toner hopper motor.
Dec 12, 2009 | Canon Office Equipment & Supplies
Canon CLC 4000 Error code E013-0002
DESCRIPTION:
THE WASTE TONER LOCK DETECTION
SWITCH (SW4) HAS BEEN PRESSED FOR O.1 SECONDS OR MORE.
Solution: the waste toner is FULL.you have to get rid of that TONER.
Nov 04, 2009 | Canon CLC 4000 Copier
Hi, can you please tell me what error code E000751-1301 is on a canon clc 3220, thanks Jane
Oct 13, 2009 | Canon CLC 1150 Color Copier
Error code E350-0000 on canon clc 1000
the connection between eco-id pcb and reader controller is faulty, canon do not make reader controller anymore
Sep 03, 2008 | Canon CLC 1000 Color Copier
Canon imageRUNNER 3570 Copier Logo
49 people viewed this question
Clive
Clive
old marine
old marine
Ekse
