Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover F6028-900 Need to replace the hose assembly but am unsure of how to get the old one disconnected.
    Scholar:
  • 55 Answers
It's probably harder to explain than it is to do.
Take off the recovery tank and underneath it you can see where the hose attaches to the unit. On the bottom side of that inlet is a clip that latches the hose onto the machine. Slide a flat underneath that clip and gently lift it(It breaks very easily) while pulling on the hose. After you get that part off the just pry that corner piece out off the machine(Okay to use some force with that) and the hose comes off and the new one just pops back on the same way.
If you do break that clip(It happens to the best of us), just drill on small hole on the top and use a screw to hold it in place, thats all that clip does anyhow.
Good Luck! Let me know how it goes, and let me know if there is anything else I can do to help.
Posted on Dec 01, 2008
How do i replace a valve assemblyon a hoover widepath f6020
You don't need a new hose. Remove the two Phillips head screws which hold down the wand cover. Be very careful when removing these parts. Pay close attention on how these parts are assembled. They are spring loaded and will fly out the end of the hose assembly when the cover is removed. The wand valve assembly or the nozzle valve assembly or usually the parts that break. Vac Parts Warehouse Here is a link of the parts breakdown.
Oct 12, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover max extract leaks from end of upholstery hose
Hello! The nozzle/valve assembly, the white piece at the end of the hose that releases the solution may be clogged with build-up residue. Try soaking the trigger end in warm water for a few hours. If this does not help, the nozzle/valve assembly may need to be replaced. Order the nozzle/valve assembly by following this link. Search Results or order the complete hose assembly by following this link. Search Results
Hope this helps!
Jun 06, 2014 | Hoover SteamVac F5914-900 SpinScrub...
I have a S3765 Hoover Wind Tunnel with a crack in the hose close to the cannister. I know wires run through the hose and that there are wire connections on either end of the hose. The replacement hose...
If the vacuum has been maintained properly and runs well it may be worth repairing. The hose is pricey but less than a new vacuum. Many new vacuums today, especially lower priced ones are very poor quality and don't last much longer than a year. It appears by the schematics of your model you can replace just the hose section or the entire hose assembly. Replacing the hose only would require removing the ends of your old hose and installing them on the new hose.
Sep 28, 2017 | Hoover S3670 Bagged Canister Vacuum
NEED WATER PICKUP HOSE ASSEMBLY FOR FH40000
All availble Hoover parts for the FH40000 can be found on usavacuum.com
Follow the link below to the site
http://www.usavacuum.com/category-s/86.htm
Mar 02, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
I need a replacement hose assembly for the hoover steamvac jr. any suggestions where i might find the part?
Only through a Hoover warranty/ service center if still available. If not save your hose ends and find a different hose with adaptable ends
Nov 25, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
Hello, I have a Hoover quadraflex Powermatic central vacuum system Model # s8099-031 that requires a new replacement 35 ft hose...I have contacted Hoover and they do not know where to buy a replacement...
Tammy, no info re your location, so I''l try this.
Your Hoover hose is shot because it was made of rubber.There are new swivel handled, tangle proof lighter hoses made of vinyl which will last much longer and can be adapted to the old Hoover head by changing the upper steel tube.
Find a Hoover service center, outlet in the yellow pages and ask for the "NEW "style, gray``Plastiflex`` brand hose and upper adapter tube sold with new Hoovers at Costco and you will be all set. Then, when the head eventually dies, you can upgrade to a far better one , while still having the Hoover cannister, the hose and tools do not need to match the original tank.
Sep 17, 2009 | Vacuums
Hoover Steamvac Upholstery Cleaner will not spray water.
In my case when I pulled the trigger on the upholstery hose I barely got a drizzle of water. After looking at the parts online I realized the valve assembly on the spray end of the hose consisted of a black valve housing, with an inner spring and a white plunger part that sprays the water. The white plunger should move noticeably when the trigger is pulled. Since all 3 part of that valve assembly were replaceable I decided to try and take it apart. First I removed the 2 silver screws on the cover of trigger end of the hose and lifted out the valve assemble. The white plunger part was basically frozen in the black valve assembly. Tried pulling the white plunger out by hand wouldn't budge. So I use a pair of plier and pulled the white part out. Sure enough the whole inside was caked with what appeared to be old dried cleaner. I rinsed the spring and the white plunger. There were o-rings on the white plunger, I did not remove them but used an old tooth brush to clean out around them then reassembled. The white plunger now freeing slides a noticeable distance when the trigger is depressed and getting a large V shaped spray pattern. Lesson learned, I will now make sure I run plenty of plain water through the hose to rinse all the cleaner out after using it .
Jan 12, 2009 | Hoover F5832-910 SteamVac Supreme Vacuum
Clean water coming out of sides
Hoover SteamVac Ultra (model F5883-900) Threw it away, and had to buy a new machine. Sorry, but I found it more difficult to deal with the housing unit on the machine and just couldn't deal with it anymore. I hope you have better luck than I did with it. I couldn't find ANY help on ANY web sites for this model, just too old I guess.
Jul 26, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Water Uptake Hose Split
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40471&thid=602269
Posted by jre8655 on May 16, 2008
How do you remove and replace the Water Uptake Hose Assembly?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover Floormate H3000 Upright Wet/Dry Vacuum. You can down load the owner manual from the Hoover website www.hoover.com . I looked 2 the owner’s manual and it does not show the clear tube but the vacuum does come apart and just back track the clear tube and mark the screws when you disassemble the unit. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
247 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
